IGC Changes that would affect flyWithCE Flight Recorder (in a good way)
Old March 10th 12, 05:15 AM posted to rec.aviation.soaring
Marc
Default IGC Changes that would affect flyWithCE Flight Recorder (in agood way)
On Mar 9, 8:54*pm, fredblair wrote:
On Mar 8, 2:05*pm, urosp wrote:
My strong belief is that most pilots fly for fun and because of that
they do not need fully certified flight recorders (where the price is
at least 5 times higher). They would either like to improve their
flying, share flights with other pilots, attend on-line competitions
or simply record their flights.
But from the beginning I have received several suggestions that device
could be also certified as position recorder with NAC (National Air
Sport Control). Several people helped me and now flyWithCE Flight
Recorders are certified by NAC in Australia, Canada, Slovenia, United
Kingdom and United States. The device could be then used as position
recorder for Silver and Gold FAI badges.
On 2nd and 3rd of March there was and IGC Plenary Meeting in South
Africa where they decided that for Silver and Gold badges you do not
need extra altitude recorder and that GPS altitude will be accepted.
The difference with fully certified flight recorders is that pilot
should account 100 meter altitude margin for possible GPS altitude
error (for instance 1100 meter gain of height for Silver badge).
The new rule will be applied when updated Sporting Code will be
published.
If you wild like to know more about flyWithCE Flight Recorder and
flyWithCE Logbook software (which ships together with the device)
please visithttp://www.flywithce.com.
Best regards
Uros Podlogarwww.flywithce.com
Any idea when the Sporting Code will be printed, so that we can start,
officially using the Position Recorders?
Another question, in the above post, it says that you might want to
use an 1,100 meter gain for the Silver Badge to make sure for GPS
errors; how is the SSA Badge Dude going to know what the "real"
altitude is, if the only reported data will be the GPS altitude??
Updates to Sporting Code Section 3 are normally released on October
1. You must gain 1100 meters as measured by the GPS, rather than the
1000 meters that would be acceptable using pressure altitude. The
extra margin is intended to increase the likelihood that the
"geopotential" altitude gain (as measured by GPS) will exceed the
pressure altitude gain required by the Sporting Code...
Marc
flyWithCE tip #2: flyWithCE Flight Recorder and OLC urosp Soaring 0 February 16th 11 05:28 PM
flyWithCE tip #1: How can you view flights in flyWithCE Logbook? urosp Soaring 0 February 11th 11 06:39 AM
flyWithCE Flight Recorder John Godfrey (QT)[_2_] Soaring 4 November 13th 09 07:10 PM
FlyWithCe recorder woes Ferstlesque Soaring 3 June 29th 09 06:23 AM
New flight recorder - flyWithCE Flight Recorder uros Soaring 12 May 5th 09 08:31 PM
