On Thursday, March 15, 2012 12:32:02 PM UTC-7, Bob Kuykendall wrote:
On Mar 14, 11:51*pm, WaltWX wrote: Does anyone have success finding an aircraft installed 406 ELT for a Schempp-HIrth glider (i.e. internal installed antenna somewhere in fuselage)? A quarter wave of 406.25 is about 6.9", so a quarter-wave whip antenna optimized for that frequency would stand about 7" tall. A dipole would be about 14" tall. It's probably a vertically-polarized signal, so you want the antenna standing vertically, and not horizontally. If your glider has a fiberglass fuselage, it is relatively transparent at the MHz frequencies, so you can use either an internal dipole or an internal quarter-wave whip with a ground plane. The dipole is probably the better bet. If it's an all-carbon fuselage, it is pretty much opaque to the MHz frequencies, about like an all-aluminum fuselage. No internal antenna could offer anything like reasonable performance. If the fuselage is primarily carbon, there may be a few places where you might make an antenna work. Sometimes the vertical fin or rudder are fiberglass or aramid; you might be able to put an antenna in one of those places. I used Jim Weir's design guide to design the internal 123 MHz dipole antenna in the rudder of Brad Hill's Tetra-15 sailplane, and it seems to be working pretty well. The turtledeck area might also be fiberglass or aramid, so you might be able to install something there. Thanks, Bob K. http://www.hpaircraft.com/hp-24 The tail area is a poor choice for an ELT antenna because the tail boom is quite likely to break in a crash, possible taking the ELT coax cable with it. Typically there is just really no good way to mount an ELT antenna inside a carbon fuselage. The turtle deck and nose deck areas don't have enough space for a vertical antenna and ground plane, even if they are RF opaque glass/kevlar. You might want to consider a 406 MHz PLB attached to the pilot/parachute harness. The PLB won't activate on impact, but then its not clear that ELTs will reliably active on impact either...especially for what may be 'low energy' glider impacts.... all ideally after starting with a SPOT tracker which can deliver many of the benefits of an ELT/PLB and quite a few the ELT/PLB cannot. I still like to also have a 406 MHz PLB since SAR organizations really do understand them and the old fashioned 121.5Mhz local homing beacon built into them can still be useful. Darryl |
On Mar 15, 8:02*pm, Darryl Ramm wrote:
On Thursday, March 15, 2012 12:32:02 PM UTC-7, Bob Kuykendall wrote: On Mar 14, 11:51*pm, WaltWX wrote: Does anyone have success finding an aircraft installed 406 ELT for a Schempp-HIrth glider (i.e. internal installed antenna somewhere in fuselage)? A quarter wave of 406.25 is about 6.9", so a quarter-wave whip antenna optimized for that frequency would stand about 7" tall. A dipole would be about 14" tall. It's probably a vertically-polarized signal, so you want the antenna standing vertically, and not horizontally. If your glider has a fiberglass fuselage, it is relatively transparent at the MHz frequencies, so you can use either an internal dipole or an internal quarter-wave whip with a ground plane. The dipole is probably the better bet. If it's an all-carbon fuselage, it is pretty much opaque to the MHz frequencies, about like an all-aluminum fuselage. No internal antenna could offer anything like reasonable performance. If the fuselage is primarily carbon, there may be a few places where you might make an antenna work. Sometimes the vertical fin or rudder are fiberglass or aramid; you might be able to put an antenna in one of those places. I used Jim Weir's design guide to design the internal 123 MHz dipole antenna in the rudder of Brad Hill's Tetra-15 sailplane, and it seems to be working pretty well. The turtledeck area might also be fiberglass or aramid, so you might be able to install something there. Thanks, Bob K. http://www.hpaircraft.com/hp-24 The tail area is a poor choice for an ELT antenna because the tail boom is quite likely to break in a crash, possible taking the ELT coax cable with it. Typically there is just really no good way to mount an ELT antenna inside a carbon fuselage. The turtle deck and nose deck areas don't have enough space for a vertical antenna and ground plane, even if they are RF opaque glass/kevlar. *You might want to consider a 406 MHz PLB attached to the pilot/parachute harness. The PLB won't activate on impact, but then its not clear that ELTs will reliably active on impact either...especially for what may be 'low energy' glider impacts.... all ideally after starting with a SPOT tracker which can deliver many of the benefits of an ELT/PLB and quite a few the ELT/PLB cannot. I still like to also have a 406 MHz PLB since SAR organizations really do understand them and the old fashioned 121.5Mhz local homing beacon built into them can still be useful. Darryl- Hide quoted text - - Show quoted text - I own a PLB also and have it with me for every flight (on my parachute). I believe that having the government looking for, and responding to, my emergency beacons (both 406 satellite with GPS coordinates and old fashioned terrestrial 121.5) is preferable to a commercial enterprise doing so. Also the recurring cost of a SPOT quickly overtakes the up front sunk costs of a PLB (zero recurring). But, of course, the PLB will not provide the tracking information that SPOT (and the Delorme device) can provide. Not to mention that PLBs are cheaper than ELTs. Questions - Why don't the PLB's have self-triggering on impact like ELTs? False/inadvertant or no triggering? As I understand the marine version of the PLB will auto-trigger (via moisture). Doesn't the possibility of a good trigger outweight the false/no trigger? Does this have to do with the fact the PLBs are handheld and maybe more prone to being dropped and then falsely triggering? |
On Friday, March 16, 2012 8:48:32 AM UTC-7, JohnDeRosa wrote:
On Mar 15, 8:02*pm, Darryl Ramm wrote: On Thursday, March 15, 2012 12:32:02 PM UTC-7, Bob Kuykendall wrote: On Mar 14, 11:51*pm, WaltWX wrote: Does anyone have success finding an aircraft installed 406 ELT for a Schempp-HIrth glider (i.e. internal installed antenna somewhere in fuselage)? A quarter wave of 406.25 is about 6.9", so a quarter-wave whip antenna optimized for that frequency would stand about 7" tall. A dipole would be about 14" tall. It's probably a vertically-polarized signal, so you want the antenna standing vertically, and not horizontally. If your glider has a fiberglass fuselage, it is relatively transparent at the MHz frequencies, so you can use either an internal dipole or an internal quarter-wave whip with a ground plane. The dipole is probably the better bet. If it's an all-carbon fuselage, it is pretty much opaque to the MHz frequencies, about like an all-aluminum fuselage. No internal antenna could offer anything like reasonable performance. If the fuselage is primarily carbon, there may be a few places where you might make an antenna work. Sometimes the vertical fin or rudder are fiberglass or aramid; you might be able to put an antenna in one of those places. I used Jim Weir's design guide to design the internal 123 MHz dipole antenna in the rudder of Brad Hill's Tetra-15 sailplane, and it seems to be working pretty well. The turtledeck area might also be fiberglass or aramid, so you might be able to install something there. Thanks, Bob K. http://www.hpaircraft.com/hp-24 The tail area is a poor choice for an ELT antenna because the tail boom is quite likely to break in a crash, possible taking the ELT coax cable with it. Typically there is just really no good way to mount an ELT antenna inside a carbon fuselage. The turtle deck and nose deck areas don't have enough space for a vertical antenna and ground plane, even if they are RF opaque glass/kevlar. *You might want to consider a 406 MHz PLB attached to the pilot/parachute harness. The PLB won't activate on impact, but then its not clear that ELTs will reliably active on impact either...especially for what may be 'low energy' glider impacts.... all ideally after starting with a SPOT tracker which can deliver many of the benefits of an ELT/PLB and quite a few the ELT/PLB cannot. I still like to also have a 406 MHz PLB since SAR organizations really do understand them and the old fashioned 121.5Mhz local homing beacon built into them can still be useful. Darryl- Hide quoted text - - Show quoted text - I own a PLB also and have it with me for every flight (on my parachute). I believe that having the government looking for, and responding to, my emergency beacons (both 406 satellite with GPS coordinates and old fashioned terrestrial 121.5) is preferable to a commercial enterprise doing so. Also the recurring cost of a SPOT quickly overtakes the up front sunk costs of a PLB (zero recurring). But, of course, the PLB will not provide the tracking information that SPOT (and the Delorme device) can provide. Not to mention that PLBs are cheaper than ELTs. Questions - Why don't the PLB's have self-triggering on impact like ELTs? False/inadvertant or no triggering? As I understand the marine version of the PLB will auto-trigger (via moisture). Doesn't the possibility of a good trigger outweight the false/no trigger? Does this have to do with the fact the PLBs are handheld and maybe more prone to being dropped and then falsely triggering? The reason why PLBs don't impact activate is they are designed to be portable and be handled by consumers. You don't want to drop one or bump it in your backpack and have it go off without the user realizing. Also for best operation many PLBs require an antenna to be manually deplyed, and won't work very well without that, so impact activating them without first putting the antenna up may not make sense.. so you may get unintended alerts when you don't want them and not good performance when you do. The FCC and others were clearly worried about PLBs getting into consumer hands vs. the more regulated/expensive ELTs. That is apparently related to the reason that a PLB has a morse code "P" (dit dah dah dit) added to the 121..5MHz beacon signal in the USA (but not overseas)... its so those signals could be identified as coming from a PLB and presumably even more ignored by SAR organizations than 121.5MHz ELT beacons -- unless SAR folks knew somebody was missing with a PLB then hopefully seeing a PLB beacon would get SAR folks even more interested. Note its only the 121.5Mhz beacon parts of a 406 MHz ELT or PLB that I'm talking about being 'ignored' False 121.5 alarms from old ELTs happen a lot and SAR organizations just cannot always respond to them, and now the SARSAT/COSPAS satellite network does not monitor 121..5 Mhz at all. If you fire off a modern 406 MHZ ELT and PLB (which all also have a 121.5 MHz beacon final/local SAR organization homing) you *will* get attention from SARSAT and local SAR organizations, alerted initially from the 406 MHz SARSAT/COSPAS satellite network. Darryl |
homemade external/internal antenna for handheld. | gorgon | Home Built | 11 | March 20th 08 09:38 PM |
Why is it so hard to find # seats for aircraft??? | Adam Aulick | Home Built | 1 | August 3rd 06 10:28 PM |
Corrosion-proofing internal surfaces of aluminum aircraft | aa | Restoration | 0 | November 3rd 04 02:51 AM |
Where can I find aircraft videos.... | Marcin Marczewski | Piloting | 26 | May 17th 04 05:13 PM |
Where to find aircraft class info? | Mike Rapoport | Owning | 4 | July 17th 03 03:40 PM |
