Data logger
Old March 16th 12, 05:07 PM posted to rec.aviation.soaring
John Bentley
Default Data logger
I am need of a new data logger, My Cambridge 20 is no longer good for
OLC so now I must pay. I would like a IGC approved and I want it
simple, plug and play. Any suggestions?
Old March 16th 12, 05:24 PM posted to rec.aviation.soaring
Tony[_5_]
Default Data logger
On Mar 16, 12:07*pm, John Bentley wrote:
*I am need of a new data logger, My Cambridge 20 is no longer good for
LXNav Nano. so easy a cave man (me) can do it.
Old March 16th 12, 07:23 PM posted to rec.aviation.soaring
Paul Remde
Default Data logger
"John Bentley" wrote in message
________________
Hi John,
I highly recommend the LXNAV Nano. They are very popular, simple and
reliable.
http://www.cumulus-soaring.com/lxnav.htm#LXNAV-Nano
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old March 16th 12, 08:43 PM posted to rec.aviation.soaring
Ventus2NZ
Default Data logger
I second the LX Nano. Great little flight recorder.
Old March 16th 12, 09:01 PM posted to rec.aviation.soaring
Tim Murphy
Default Data logger
Will the nano talk to the Lnav or Mnav ?
Old March 16th 12, 10:51 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Data logger
Nothing can talk to an M-Nav except your fingers.
Old March 16th 12, 11:17 PM posted to rec.aviation.soaring
Paul Remde
Default Data logger
"Tim Murphy" wrote in message
Hi Tim,
Yes and no. The L-NAV needs GPS data for wind calculations. The Nano can
send that - no problem. But the L-NAV also would like to receive "distance
to destination" data. The Nano doesn't have a waypoint database and doesn't
do navigation, so it can't send distance to destination data out.
Therefore, the L-NAV wouldn't be able to show final glide data because it
won't know how far away you are from your destination.
The Naviter Oudie can send GPS data and distance to destination data to the
L-NAV. However, I don't see much point to that because the SeeYou Mobile
software on the Oudie is a better final glider computer than the L-NAV.
But it is nice to get GPS data to the L-NAV so it can calculate wind while
cruising.
The best thing to connect to an L-NAV is a GPS-NAV. Only the GPS-NAV can
send GPS data, distance to destination data, and destination airport
elevation data to the L-NAV.
Best Regards,
Paul Remde
Old March 17th 12, 12:38 AM posted to rec.aviation.soaring
Mike C
Default Data logger
The Nano is great. It is stand alone with no outside power required.
Keep your Cambridge setup, and use the 20 for navigation. At the end
of the flight just remove the Nano and plug it in to your computer to
download to OLC-very simple. BTW the Nano works very well with the
Blue Tooth connection-for future reference.
Mike
Old March 17th 12, 12:48 PM posted to rec.aviation.soaring
Kimmo Hytoenen
Default Data logger
GPS-NAV can
airport
GPS-NAV, Nano or FLARM as a back-up.
Old April 2nd 12, 03:04 AM posted to rec.aviation.soaring
bill palmer
Default Data logger
Here's one to check out :
a Garrecht Volkslogger + computer & software currently listed for $350
http://glidersource.com/cgi-bin/post.cgi?id=92
Parachute, Data Logger, Radio for sale jim finger Soaring 1 February 9th 10 10:28 PM
FS - Colibri Data Logger [email protected] Soaring 0 September 13th 08 02:00 AM
EW Data logger failure? nimbus Soaring 8 July 28th 08 07:06 AM
Cambridge 302 -or- Borgelt B50 plus data logger Romeo Delta Soaring 25 May 30th 04 09:50 AM
Colibri Data Logger reviewed TOM RENT Soaring 18 April 16th 04 10:47 PM
