Power FLARM question
Old March 21st 12, 11:34 PM posted to rec.aviation.soaring
Mike C
Default Power FLARM question
On Mar 21, 5:29*pm, Chris wrote:
Hello Kimmo,
Kimmo Hytoenen wrote:
We are developing a simple and low cost device (we named it
SoarTronic to add Bluetooth communication of FLARM traffic
information into European version of FLARM units. It also allows
task declaration and log file download. It is connected into RJ45
connector, and it draws operating voltage (40mA) from 3.3 V that
FLARM provides for external displays.
This is a nonprofit project we started to get FLARM traffic
information available in our club gliders. Since club members have
many types of flight computers, Bluetooth was chosen as
communication method. Price for this device is 30 EUR + delivery
from Finland.
Just curious, are you using a module like this:http://www.brunwinkel.de/elektronik/ics/btm400_6b/
I just build a device at my own design that meets your description. As I am
working nonprofit too, there is no competition. If interested, we can share
information. I have a dealer in Hong Kong who sells the modules for ~8,- ?
with free shipping. With a MAX3232 for the RS232, printed circuit board and
casing, I think your price is realistic.
Nice featu as the module is programmable, I set it up with the
registration of the glider as Bluetooth name.
Regards
Chris
Will either one work with a VW1150 Canbus and transmit info two ways
between a Streak and Canbus that contains Powerflarm and smart vario
data?
Thanks,
Mike
Old March 21st 12, 11:53 PM posted to rec.aviation.soaring
Chris
Mike C wrote:
am working nonprofit too, there is no competition. If interested, we can
share information. I have a dealer in Hong Kong who sells the modules for
~8,- ? with free shipping. With a MAX3232 for the RS232, printed circuit
board and casing, I think your price is realistic.
data?
I cannot speak for the device offered by Kimmo, but it seems it works
similar as my design. As Kimmo mentioned, it should work with any device
that supports Bluetooth and can communicate with Flarm via the RJ45. The
Bluetooth is just a wireless extension of the serial data channel via RJ45.
Regards
Chris
Old March 22nd 12, 04:36 AM posted to rec.aviation.soaring
Sean Fidler
Kimo,
F2 and my email is smfidlerATgmailDOTcom
Old March 22nd 12, 05:11 AM posted to rec.aviation.soaring
How is the SoarTronic different from the K6 bt? The only thing I can see is
that it uses the 3V connection of the FLARM RJ-45 jack instead of the jack's
12V connection.
http://www.cumulus-soaring.com/k6.htm
I have tested a K6 bt with my iPAQ hx 4700 running LK8000 and my Android
Atrix running XCSoar. It works great in both cases.
http://www.soaridaho.com/
"Kimmo Hytoenen" wrote in message
. com...
from Finland.
If you think that this unit is useful with Power FLARM please let me
know. We hope to get 30 orders to cover the cost. Enclosed couple
links showing how to connect and use SoarTronic. These videos
show XCSoar runnig in Android phone, but it should work with any
device with BT, and with any flight computer SW.
http://www.youtube.com/watch?v=M7EkWwQhQzU
http://www.youtube.com/watch?v=OJPz65ePozo
http://www.youtube.com/watch?v=6WLD0td0pMo
Old March 22nd 12, 07:09 AM posted to rec.aviation.soaring
Kimmo Hytoenen
description. As I
interested, we can
the modules
for
printed circuit
with the
info two ways
smart vario
data?
it works
any device
the RJ45. The
via RJ45.
Regards
Chris
Chris,
You are right, in this device all components are well known, and
you can build a similar system out from Bluetooth module and
RS232/TTL level sifter. I actually did so, but the result did not
look like something that I would trust. Also other club members
told me that "nice, but who will maintain those if you are not
here?". So I decided to look for more professional solution. What
was on the market was quite expensive compared to technology
needed.
There is one technical improvement in this device compared
what has been on the market. If you have an external display
connected into your FLARM unit and you want to connect
SoarTronic type device into the same RS232 line with it, you
normally either disconnect the external display's TX line, or add
a switch to select if you what to declare tasks over Bluetooth
device (i.e. RS232 in not multidrop bus). With this "SoarTronic"
you do not need that switch, and these two animals can live
together in RS232 line - as long as they do not speak
simultaneously. This is idea of Simon. I also think that if you
have your FLARM connected to Variometer or VW1150, you can
add this device into the FLARM RS232/power cable. This device
does not have CanBus build in it, but you can connect any
RS232/bluetooth module in the RS232 connector of VW1150.
We have had many gliderpilots involved in this project. It
actually started as a spinn-off. We were (and still are)
developing an interface board to Sparkfun IOIO board, that
connects 4 RS232 lines to Android phone over USB, and
provides 12V/5V conversion for charging the Android device. But
that is an another story.
Old March 22nd 12, 08:26 AM posted to rec.aviation.soaring
Ramy
12V connection.
. com...
from Finland.
It is like one fifth of the cost of a K6Bt...
But wouldn't commercially available bluetooth adapter provide same functionality for similar low cost, such as http://www.usconverters.com/index.ph...ducts _id=228
I am also looking for a low cost bluetooth adapter once my powerflarm arrives. I already have one K6Bt for my 302 (works perfect), and rather not spending the same amount on another K6Bt.
Ramy
Old March 22nd 12, 09:32 AM posted to rec.aviation.soaring
Chris
That would work, but you need to provide some power source. It needs a 5V
power source either via USB cable or external battery. The Flarm provides a
3V output, I guess that would not be enough to power the device. Kimmos and
my device work with the 3V directly, that saves some hardware. I don't know
if the K6-BT works similar.
Chris
Old March 22nd 12, 12:01 PM posted to rec.aviation.soaring
Kimmo Hytoenen
same
http://www.usconverters.com/index.php?
main_page=product_info&cPath=65&products_id=228
needs a 5V
provides a
Kimmos and
don't know
Chris
Chris is right, that is the point.
Also, if you use external display, this works nicely with that.
-kimmo
Old March 22nd 12, 02:00 PM posted to rec.aviation.soaring
Tobias Bieniek
From what I've understood so far, there is one important difference between SoarTronic and the K6BT, which is baudrate switching. The K6BT has a protocol to let the connected software change the baudrate of the adapter and I haven't seen any other devices yet, that are able to do that. XCSoar has recently implemented that protocol which makes it easy to change the baudrate for IGC file downloads for example. The Flarm does not need this feature since it doesn't have to change the baudrate, but my DX50 (similar to LX5000) sends GPS data at 4800 yet the transfer mode for upload/download works at 19200.
Turbo
Old March 22nd 12, 02:17 PM posted to rec.aviation.soaring
Mike C
Mike C wrote:
description. As I
interested, we can
the modules
for
printed circuit
with the
info two ways
smart vario
data?
it works
any device
the RJ45. The
via RJ45.
Regards
Chris
Chris,
needed.
Still in for the IOIO board Kimmo.
Mike
Power FLARM portable reports? Andy[_1_] Soaring 2 December 9th 11 03:58 PM
Red Box FLARM update question Martin Gregorie[_5_] Soaring 1 June 11th 11 10:13 PM
P-63 (?) Airacobra/Kingcobra power question Ricky Piloting 75 November 27th 09 12:35 AM
Engine power question??? [email protected] Home Built 24 October 13th 07 02:40 AM
Ship's Power (or portable GPS) Question Kyle Boatright Home Built 9 May 29th 07 03:17 PM
