Ramy wrote:
It is like one fifth of the cost of a K6Bt... But wouldn't commercially available bluetooth adapter provide same functionality for similar low cost, such as http://www.usconverters.com/index.ph...ducts _id=228 That would work, but you need to provide some power source. It needs a 5V power source either via USB cable or external battery. The Flarm provides a 3V output, I guess that would not be enough to power the device. Kimmos and my device work with the 3V directly, that saves some hardware. I don't know if the K6-BT works similar. Chris |
At 09:32 22 March 2012, Chris wrote:
Ramy wrote: It is like one fifth of the cost of a K6Bt... But wouldn't commercially available bluetooth adapter provide same functionality for similar low cost, such as http://www.usconverters.com/index.php? main_page=product_info&cPath=65&products_id=228 That would work, but you need to provide some power source. It needs a 5V power source either via USB cable or external battery. The Flarm provides a 3V output, I guess that would not be enough to power the device. Kimmos and my device work with the 3V directly, that saves some hardware. I don't know if the K6-BT works similar. Chris Chris is right, that is the point. Also, if you use external display, this works nicely with that. -kimmo |
Power FLARM portable reports? | Andy[_1_] | Soaring | 2 | December 9th 11 03:58 PM |
Red Box FLARM update question | Martin Gregorie[_5_] | Soaring | 1 | June 11th 11 10:13 PM |
P-63 (?) Airacobra/Kingcobra power question | Ricky | Piloting | 75 | November 27th 09 12:35 AM |
Engine power question??? | [email protected] | Home Built | 24 | October 13th 07 02:40 AM |
Ship's Power (or portable GPS) Question | Kyle Boatright | Home Built | 9 | May 29th 07 03:17 PM |
