Hi Peter,
When you connected the Oudie-PS5a-1 to the PC, was it powered with 5V? It must be powered with 5V for the RS-232 voltage level converter to work. Best Regards, -- Paul Remde Cumulus Soaring, Inc. "vontresc" wrote in message news:28911584.1000.1333382053976.JavaMail.geo-discussion-forums@ynlp3... That was my initial thought as well. I tested the FP10 with my desktop and a serial cable, and all was well at 4800/8/n/1. The interesting thing was whan I tried the goddard cable with Condor on my PC, I got the same jibberish coming through on the oudie cable. On Monday, April 2, 2012 10:29:16 AM UTC-5, cfinn wrote: If it's jibberish, I would expect you have a mismatch in the data rates between the devices. On Apr 2, 11:10 am, "Peter von Tresckow" wrote: I was in the process of upgrading my panel with my new to me Tasman V1000/FP10. The vario did come with the Goddard Oudie connection cable (ps5a i think), and it was working fine at first, but now I am just seeing jibberish being transmitted when I go into terminal mode in see you on the Oudie. I have tried the Naviter cable, and the FP10 is working correctly as that cable transmits the data without issue. Did I possibly fry my goddard cable??? Thanks Peter |
The FP10 does supply the 5V for the PDA, and I did check that it has power.
I plugged my desktop into the FP10, and was able to receive serial data from the GPS (4800-8-n-1). I hgave also played with every conceivable baud rate setting on the Oudie, and still no joy. I fear I may have fried the Max232 ttl converter :-( Pete "Paul Remde" wrote in message ... Hi Peter, When you connected the Oudie-PS5a-1 to the PC, was it powered with 5V? It must be powered with 5V for the RS-232 voltage level converter to work. Best Regards, -- Paul Remde Cumulus Soaring, Inc. "vontresc" wrote in message news:28911584.1000.1333382053976.JavaMail.geo-discussion-forums@ynlp3... That was my initial thought as well. I tested the FP10 with my desktop and a serial cable, and all was well at 4800/8/n/1. The interesting thing was whan I tried the goddard cable with Condor on my PC, I got the same jibberish coming through on the oudie cable. On Monday, April 2, 2012 10:29:16 AM UTC-5, cfinn wrote: If it's jibberish, I would expect you have a mismatch in the data rates between the devices. On Apr 2, 11:10 am, "Peter von Tresckow" wrote: I was in the process of upgrading my panel with my new to me Tasman V1000/FP10. The vario did come with the Goddard Oudie connection cable (ps5a i think), and it was working fine at first, but now I am just seeing jibberish being transmitted when I go into terminal mode in see you on the Oudie. I have tried the Naviter cable, and the FP10 is working correctly as that cable transmits the data without issue. Did I possibly fry my goddard cable??? Thanks Peter |
Oudie for sale, Goddard PS5a-1 cable for sale | Sean Fidler | Soaring | 3 | April 3rd 12 02:51 PM |
Goddard PS-5a | Brad[_2_] | Soaring | 1 | February 19th 10 04:07 AM |
Goddard Cables & Power supply FS | Discus 44 | Soaring | 0 | February 1st 07 05:48 PM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | Home Built | 6 | October 15th 04 08:51 PM |
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) | Striker Cat | General Aviation | 0 | October 12th 04 05:11 PM |
