Thanks
My problem is that some one has found a supplement named S1A-77 to the Flight Manual of a 180 hp PA 18 that says that max glider weigth is 600 kg. Can any one send me or direct me to that supplement. It does not make sense...... We have been towing gliders 600 kg with PA 18 150/180 since the early 80ies. Robert |
At first blush I'd say that information was not from the USA. I don't recall ever seeing any US aviation restriction stated in kilos, but I could be wrong. Just a thought.
On Apr 22, 4:43*pm, Robert Danewid wrote:
Thanks My problem is that some one has found a supplement named S1A-77 to the Flight Manual of a 180 hp PA 18 that says that max glider weigth is 600 kg. Can any one send me or direct me to that supplement. It does not make sense...... We have been towing gliders 600 kg with PA 18 150/180 since the early 80ies. Robert OK, having nothing else to do this afternoon, I did some research. The 600kg number suggested a European sourced supplement. US STC's would likely be in SAE units. It appears there is a MOGAS STC issued in Switzerland to Wenger & Kaufmann for PA-18-180-M and PA-18-150 glider tugs. In pursuit of the STC the glider tow performance (takeoff roll, climb rate) was measured with a 600kg glider in tow. Since that is the heaviest glider tested, that became the limit for the STC. This may or may not the source of S1A-77 but it shows how it can happen. There are LOTS of different STC's for PA-18 around the world. This is a bit if a diversion but most recent European 2-seaters specify 600kg (Actually, 600 daN) weak links for aero tow. If these gliders are operated in strict compliance with their Approved Flight Manuals as required by FAR 91.9, 600kg would be the max load on the tug. I have been assuming (possibly in error) that you are in the US. |
On 23 Apr, 03:08, Bill D wrote:
On Apr 22, 4:43*pm, Robert Danewid wrote: Thanks My problem is that some one has found a supplement named S1A-77 to the Flight Manual of a 180 hp PA 18 that says that max glider weigth is 600 kg. Can any one send me or direct me to that supplement. It does not make sense...... We have been towing gliders 600 kg with PA 18 150/180 since the early 80ies. Robert OK, having nothing else to do this afternoon, I did some research. The 600kg number suggested a European sourced supplement. *US STC's would likely be in SAE units. It appears there is a MOGAS STC issued in Switzerland to Wenger & Kaufmann for PA-18-180-M and PA-18-150 glider tugs. *In pursuit of the STC the glider tow performance (takeoff roll, climb rate) was measured with a 600kg glider in tow. *Since that is the heaviest glider tested, that became the limit for the STC. *This may or may not the source of S1A-77 but it shows how it can happen. *There are LOTS of different STC's for PA-18 around the world. This is a bit if a diversion but most recent European 2-seaters specify 600kg (Actually, 600 daN) weak links for aero tow. *If these gliders are operated in strict compliance with their Approved Flight Manuals as required by FAR 91.9, 600kg would be the max load on the tug. I have been assuming (possibly in error) that you are in the US. I am in Sweden Thanks for your info Robert |
![]() Quote:
Can't agree that most recent European 2 seaters specify 600kg weaklinks for aerotow. The Duo Discus for example is 50% or so higher and the DG 1000 is higher again at 1100 DaN Having said all that here in New Zealand there are some operations that use PA-18 180s and they variously tow Duos and ASH 25s so they are well capable of handling the bigger ships subject to density altitude considerations Colin Last edited by Ventus_a : April 23rd 12 at 10:31 PM. |
On Apr 23, 3:20*pm, Ventus_a
wrote: Bill D;813718 Wrote: On Apr 22, 4:43*pm, Robert Danewid wrote:- Thanks My problem is that some one has found a supplement named S1A-77 to the Flight Manual of a 180 hp PA 18 that says that max glider weigth is 600 kg. Can any one send me or direct me to that supplement. It does not make sense...... We have been towing gliders 600 kg with PA 18 150/180 since the early 80ies. Robert- OK, having nothing else to do this afternoon, I did some research. The 600kg number suggested a European sourced supplement. *US STC's would likely be in SAE units. It appears there is a MOGAS STC issued in Switzerland to Wenger & Kaufmann for PA-18-180-M and PA-18-150 glider tugs. *In pursuit of the STC the glider tow performance (takeoff roll, climb rate) was measured with a 600kg glider in tow. *Since that is the heaviest glider tested, that became the limit for the STC. *This may or may not the source of S1A-77 but it shows how it can happen. *There are LOTS of different STC's for PA-18 around the world. This is a bit if a diversion but most recent European 2-seaters specify 600kg (Actually, 600 daN) weak links for aero tow. *If these gliders are operated in strict compliance with their Approved Flight Manuals as required by FAR 91.9, 600kg would be the max load on the tug. I have been assuming (possibly in error) that you are in the US. Can't agree that most recent European 2 seaters specify 600kg weaklinks for aerotow. *The Duo Discus for example is 50% or so higher and the DG 1000 is higher again at 1100 DaN Having said all that here in New Zealand there are some operations that use PA-18 180s and they variously tow Duos and ASH 25s so they are well capable of handling the bigger ships subject to density altitude considerations Colin +-------------------------------------------------------------------+ |Filename: Weak links.jpg * * * * * * * * * * * * * * * * * * * * * | |Download:http://www.aviationbanter.com/attachment.php?attachmentid=55283| |Filename: Weak links 2.jpg * * * * * * * * * * * * * * * * * * * * | |Download:http://www.aviationbanter.com/attachment.php?attachmentid=55284| +-------------------------------------------------------------------+ -- Ventus_a From the DG-1000 manual page 2.10: "6000 N + 600 N (1323 lbs. + 132 lbs.) for tow behind slow tow planes" Which I think would include a PA-18. The Duo allows a 700 daN weak link but that's not 50% higher. |
![]() Quote:
The cockpit placard for towing in the Duo specifies 910 daN as the maximum with out referencing the minimun allowed (700 daN) as stated in the flight manual. My mistake for not quoting the allowable range in my original post. I should also have said 'up to 50% or so higher" :-) The DG manual says regarding 'slow' tow planes, "for tow behind slow towplanes eg. Ultralight planes or touring motorgliders". Last time I looked a PA-18 150 or PA-18 180 was neither an ultralight or a touring motorglider Colin Last edited by Ventus_a : April 24th 12 at 07:19 PM. |
I did a lot of the fly off time for Dave Johnson when he was
developing his original STC for the first 180hp Cubs. The climb performance over a stock 150hp Cub was amazing. With the 150hp Cubs, we could not tow the 2-32's out of the Black Forest Gliderport (elevation 7200') when the temperature got much over 70ºF. With the 180hp, there really was no limitation on glider weights or density altitude for our ops requirements. We even towed a few gliders out of Leadville (10,000') several times, and flew fully loaded 2-32's out of Aspen, Gunnison, Durango, and several other high altitude airports without problems during Dave's annual glider caravans around the state of Colorado. That was something we couldn't do with the 150 Cub. One particularly rememberable tow was into the wave near Pikes Peak, when the wave wasn't really working. For whatever reason, the 2-32 pilot wouldn't release, and the tow was continued until I waved him off at 18,000' (Old days, Positive Control Airspace began at FL240 then). Steve PS |
Guys
This is not a question about weak links or the capability in practice. We have been towing gliders 600 kg with Super Cub 150/180 for more than 30 years. The problem is that someone recently found a supplement to the Flight Manual stating that the Super Cub is limited to tow gliders 600 kg and now wants us to put a 600 kg limit on all Cubs. (Yes I know..........) It seems that Piper never delivered a Cub with a tow hook so all installations are done on a National level with National approvals. Do you know of any such approval that you can direct me to? Especially in Europe. Thanks Robert |
Yet another corollary on Murphies Law:
The authorities will stuff it up in imaginative and contrary ways that belie rational belief... The others a Things will go wrong in the worst possible way Murphy was an optimist, and There is always one more idiot than you would have thought possible... Bruce On 2012/04/24 8:41 PM, Robert Danewid wrote: Guys This is not a question about weak links or the capability in practice. We have been towing gliders600 kg with Super Cub 150/180 for more than 30 years. The problem is that someone recently found a supplement to the Flight Manual stating that the Super Cub is limited to tow gliders600 kg and now wants us to put a 600 kg limit on all Cubs. (Yes I know..........) It seems that Piper never delivered a Cub with a tow hook so all installations are done on a National level with National approvals. Do you know of any such approval that you can direct me to? Especially in Europe. Thanks Robert -- Bruce Greeff T59D #1771 |
Towing with a VW | [email protected] | Soaring | 15 | December 7th 07 08:20 AM |
Towing with a 150 hp Pawnee? | [email protected] | Soaring | 5 | November 22nd 06 01:32 PM |
Towing to the airport | drano | Home Built | 3 | August 25th 06 06:17 PM |
Towing | Roger Fowler | Soaring | 6 | August 11th 05 04:25 AM |
FAA says towing ULV's is OK? | ken ward | Soaring | 4 | September 30th 04 03:12 AM |
