On Monday, April 30, 2012 7:59:03 PM UTC-4, ursus wrote:
FLARM has developed a potential solution for the reduced range experienced with some PowerFLARM at the Seniors and Perry. To test this solution, a small number of modified PowerFLARM portable and PowerFLARM “Brick” units will be available for testing during the Mifflin contest. FLARM expects to have one or two representatives at Mifflin to help with testing. After the fix is verified, PowerFLARMs already delivered will be updated, and “Brick” production will commence (it is otherwise ready to go). To be certain that the fix works, FLARM asks that pilots flying with these PowerFLARM units at Mifflin: - Comply with detailed installation instructions to be provided, especially regarding antenna installation, - Load diagnostic software to be provided, - Provide diagnostic log files to FLARM after each and every flight. With the results from these tests, FLARM hopes to validate the fix and put this issue behind us ASAP… If you are flying at Mifflin and have time to help with this (including time to make a proper installation before the contest), please contact your dealer. If you are not flying at Mifflin, please do not inundate the dealers, Dave, and Lee with questions. We are well aware that we need to a better job of communication and documentation, but getting the initial installations running well has highest priority ! Thanks again for all your help and support ! Best Regards, The FLARM Team Reminder US PowerFLARM ‘A’ and ‘B’ port do NOT have the same connector due to an unfortunate FCC requirement. If you screw in incorrect antennas (with incorrect SMA sex), you *will* damage your PowerFLARM. |
Say what???
On Tuesday, May 1, 2012 9:15:47 AM UTC-4, Papa3 wrote: On Monday, April 30, 2012 7:59:03 PM UTC-4, ursus wrote: FLARM has developed a potential solution for the reduced range experienced with some PowerFLARM at the Seniors and Perry. To test this solution, a small number of modified PowerFLARM portable and PowerFLARM “Brick” units will be available for testing during the Mifflin contest. FLARM expects to have one or two representatives at Mifflin to help with testing. After the fix is verified, PowerFLARMs already delivered will be updated, and “Brick” production will commence (it is otherwise ready to go). To be certain that the fix works, FLARM asks that pilots flying with these PowerFLARM units at Mifflin: - Comply with detailed installation instructions to be provided, especially regarding antenna installation, - Load diagnostic software to be provided, - Provide diagnostic log files to FLARM after each and every flight. With the results from these tests, FLARM hopes to validate the fix and put this issue behind us ASAP… If you are flying at Mifflin and have time to help with this (including time to make a proper installation before the contest), please contact your dealer. If you are not flying at Mifflin, please do not inundate the dealers, Dave, and Lee with questions. We are well aware that we need to a better job of communication and documentation, but getting the initial installations running well has highest priority ! Thanks again for all your help and support ! Best Regards, The FLARM Team Reminder US PowerFLARM ‘A’ and ‘B’ port do NOT have the same connector due to an unfortunate FCC requirement. If you screw in incorrect antennas (with incorrect SMA sex), you *will* damage your PowerFLARM. |
Status US PowerFLARM shipments | ursus | Soaring | 14 | August 31st 11 01:24 AM |
Status PowerFLARM for USA | [email protected] | Soaring | 7 | July 14th 11 07:24 PM |
Status PowerFLARM for USA | Andrzej Kobus | Soaring | 0 | May 18th 11 01:43 AM |
Status PowerFLARM for USA | Andrzej Kobus | Soaring | 0 | May 17th 11 10:21 PM |
