Crunch Alert (USA) - hugely serious but (apparently) non-fatal
Old May 1st 12, 07:49 PM posted to rec.aviation.soaring
Marc
Default Crunch Alert (USA) - hugely serious but (apparently) non-fatal
On May 1, 9:20*am, "Dan Marotta" wrote:
It seems like all modern gliders use the same or a variation of the same
mechanism for connecting and adjusting rudder cables and pedals. *You can
bet that, before my next flight in my LAK-17a, I'll be giving those parts a
very close look.
If your serial number is 141 or less, service bulletin
017A.5.52.005A already requires installation
of plastic tubes over the rudder cables where they pass through the
pedal attachment S-tubes, to prevent fraying. The tubes should be
visible, if the fix was applied...
Marc
Old May 2nd 12, 03:14 PM posted to rec.aviation.soaring
Dan Marotta
Thanks, Marc. Mine is S/N 119. I'm towing today (leaving for the airport
in 20 minutes) and I'll check that before pulling the tug out of the hangar.
"Marc" wrote in message
mechanism for connecting and adjusting rudder cables and pedals. You can
a
very close look.
Marc
Crunch(es) Alert (USA)... BobW Soaring 0 April 14th 12 07:23 PM
Crunch Alert... BobW Soaring 3 March 14th 12 03:00 PM
Japan's ATD-X stealth fighter suffers funding crunch Tiger Naval Aviation 10 September 6th 08 07:10 AM
Klewless newbie alert! (Was Troll alert! Why is "CovvTseTung" using multiple aliases here?) Maxwell[_2_] Piloting 76 August 22nd 08 04:07 PM
Breakfast cereal review: Quakers Oat Crunch Michael Baldwin, Bruce Products 0 December 22nd 06 03:40 AM
