Chest parachute? (need more room in my Discus A !!)
Old May 2nd 12, 09:54 PM posted to rec.aviation.soaring
Derek Mackie
Default Chest parachute? (need more room in my Discus A !!)
On May 2, 1:41*pm, John Cochrane
lbs.http://www.highenergysports.com/hg_eparachutes.htm
As I remember from my mis-spent youth in hang gliders, though, these
parachutes are *not designed for a free-falling pilot. A broken hang
glider doesn't fall that fast.
Ballistic parachute to bring the glider down too?
Trading the discus A for a B or CS might be an easier solution!
John Cochrane
Also from my mis-spent youth - the chest mounted parachutes that we
used to use (I still have one somewhere) was hand-deployed. That is,
you peel it off your chest, look for a hole in the tangled rigging and
throw it as hard as you can. There is no pilot chute or D-handle,
which makes them light and compact, but, YOIKS! A lot of guys went to
ballistics.
It would seem to me that a headrest pack might be your most reasonable
solution, but I would want to practice getting out to see what body
motion you need in order to not snag anything if you need to leave.
If it was me, I'd try getting on a treadmill for a while, maybe give
up pizza and beer. Then when that failed, I'd start looking for a
jumbo-sized glider. :-)
Derek
Old May 2nd 12, 10:18 PM posted to rec.aviation.soaring
C-FFKQ (42)
Derek
Give up pizza and beer? Are you an anarchist?
As for the jumbo-sized glider, there were only 10 Glasflugel 604's made, and you can't have my Kestrel
Old May 3rd 12, 02:23 AM posted to rec.aviation.soaring
Bruce Barnard[_2_]
Not familiar with SH, but in Schleichers many remove the seat backs.
Chutes are as hard as a rocks anyway so losing the seat back is not
much of a comfort loss, only a headrest loss. Certainly much better
than quitting beer. Hard to believe a good natured Canadian would
suggest you quit beer.
Old May 7th 12, 06:15 AM posted to rec.aviation.soaring
Paul[_9_]
much of a comfort loss, only a headrest loss. *Certainly much better
than quitting beer. *Hard to believe a good natured Canadian would
My Discus doesn't have a seat back. So this won't be an option. Thanks
for the suggestion anyway.
Regards,
Paul
Old May 7th 12, 06:14 AM posted to rec.aviation.soaring
Paul[_9_]
*lbs.http://www.highenergysports.com/hg_eparachutes.htm
John Cochrane
used to use (I still have one somewhere) was hand-deployed. *That is,
throw it as hard as you can. *There is no pilot chute or D-handle,
which makes them light and compact, but, YOIKS! *A lot of guys went to
ballistics.
up pizza and beer. *Then when that failed, I'd start looking for a
jumbo-sized glider. *:-)
Derek
Derek,
Thanks alot for that. I think a headrest chute might be the way to go.
I'm only 71 kg (156 pounds, 11 stone), but at 183 cm it would be nice
to have a little more room.
Regards,
Paul
I just have to get it off my chest. Clem Aviation Photos 85 July 27th 07 08:53 AM
??Build rolling tool chest? Michael Horowitz Owning 15 January 27th 05 04:56 AM
Discus 3 or Super Discus? Mirek Soaring 1 June 13th 04 09:28 AM
Discus CS and Duo Discus Wing Inspections Nolaminar Soaring 0 October 24th 03 01:15 AM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
