On Wed, 02 May 2012 08:44:16 -0500, lynn wrote:
So how about it you legal beagles out there--just how does an aircraft owner get their oxygen system serviced legally? Lynn, OK. I'll bite. I don't think I'm a "legal beagle", but I am a bit of an FAR-nerd, so I'll expose myself to collective ridicule and attempt to answer your question completely. The first question to ask (as others have pointed out) is whether your oxygen tank is considered (legally) to be part of your aircraft or not. If the tank is not listed in your operating limitations section as a piece of required equipment, and has not been included in any subsequent 337 forms as something that is installed in the aircraft, then it is not part of your aircraft. In general, if something is not part of your aircraft, then the FAA does not care about who inspected it or how it was inspected. If it is not installed as a part of the aircraft but is carried aboard the aircraft, then it is "cargo." The FAA has regulations about carrying oxygen cylinders as cargo, but these apply to inaccessible cargo areas of transport-category aircraft. So, on a private, Part 91 flight the FAA does not care about what type of oxygen tank you may have aboard. On the other hand, the Department of Transportation (DOT) does have regulations about the transport of compressed gas cylinders. I am not an expert on DOT regulations, but to my knowledge these regulations are not specific to aviation oxygen (as opposed to any other type of compressed oxygen). Therefore, any place (dive shop, welding supply shop, etc.) that is certified to test and inspect compressed gas cylinders according to the DOT requirements should be able to inspect and test your cylinder. There is nothing "illegal" or shady about this. It's a DOT regulation, so any shop that meets DOT requirements (see below for discussion of these requirements) can legally certify your cylinder (whether or not it's used in aviation). If (and I highly doubt that this is the case with your Pik 20) the oxygen cylinder is required equipment, then the manufacturer would be obliged to publish inspection criteria and servicing instructions, and then you'd be obliged to follow these procedures. In the absence of any specific guidance from the manufacturer, the Aircraft Maintenance Technician (e.g. A&P or IA) performing maintenance or inspection of the oxygen system would follow the FAA's procedures as outlined in AC 43.13-1B "Acceptable Methods, Techniques, and Practices - Aircraft Inspection and Repair". In Chapter 9 this Advisory Circular describes how an AMT should inspect and service installed oxygen cylinders, to wit: 9-51. SERVICE OXYGEN CYLINDERS. REQUIREMENTS (Ref 49 CFR 173.34 e, 16). Standard-weight cylinders must be hydrostatic tested at the end of each 5-year period (10 years if it meets the requirements in 49 CFR 173.34 e, 16). This is a Department of Transportation (DOT) requirement. Thesecylinders carry an ICC or DOT 3AA 1800 classification and are suitable for the use intended. Lightweight cylinders must be hydrostatic tested every 3 years, and must be retired from service after 24 years or 4,380 pressurizations, whichever occurs first. These cylinders carry an ICC or DOT 3 HT 1850 classification and must be stamped with the approval after being inspected. (Ref. 49 CFR 173.34 e, 15). Note that the FAA's guidance refers to 49 CFR which is the Transportation code. The rules in 49 CFR 173.34 are pretty long, but your question concerned who can do this inspection, not necessarily how it is done, so I'll dispense with quoting the "how" and focus on the "who". 49 CFR 173.34 (e) (2) (i) says:" "No person may mark a cylinder with a test date or retester identification number,or otherwise represent that a DOT specification or exemption cylinder has been retested under this section, unless that person holds a current retester identification number issued by the Associate Administrator for Hazardous Material Safety and operates in compliance with the terms of the retester identification number issuance letter." So, to finally answer your question of "how does an aircraft owner get their oxygen system serviced legally?" I can offer this explanation. If you have an installed oxygen system, all servicing must be done according to the manufacturers instructions and/or AC 43.13-1B. 43.13-1B says that the testing and marking of these cylinders must be done according to 49 CFR 173.34, which in turn specifies that the hydrstatic testing and marking can only be done by someone who holds a current retester identification number. So, the AMT would be obliged to take the cylinder to someone who holds this retester identification number. This could be an aviation-specific shop, or not. As long as they hold this identification number and are operating under the terms of the issuance letter for this number, then they can certify the tank. Your A&P would then note this inspection in the aircraft logs, and everyone is happy. On the other hand, if the oxygen system isn't an installed system, then there is no legal requirement under the Federal Aviation Regulations (anymore than there is a requirement for you to inspect a duffel bag or any other item of cargo). However you still need to comply with 49 CFR 173.34 since the tank will be carried aboard an aircraft as cargo. In this case, you should seek out someone who holds a retester identification number as prescribed in 49 CFR 173.34 (e) (2) (i) and ask them to inspect and certify your tank. Then, you're good to go. I hope this is "legal-beagly" enough. --Stefan -- Stefan Murry |
If the tank is "portable", and you will be having it hydro tested
locally, I suggest NOT using a welding supply place unless they test on-site. If they throw a bunch of bottles in a truck to send off for testing, your nice bottle will not come back looking the same. bumper |
On May 5, 10:06*am, bumper wrote:
If the tank is "portable", and you will be having it hydro tested locally, I suggest NOT using a welding supply place unless they test on-site. If they throw a bunch of bottles in a truck to send off for testing, your nice bottle will not come back looking the same. bumper Yep, welding supply shops can be tricky. Once I was on a errand to pick up a refilled (large type) O2 bottle. While I waited for my turn at the counter, I noticed a truck being unloaded at the dock. It was loaded with green O2 bottles - none of which showed the blue "Aviation Oxygen" sticker. Since I couldn't see any Aviation Oxygen bottles, I told the counterman I wouldn't be surprised if he couldn't fill my order. "No problem", he said, "Watch". He opened a drawer, retrieved a sheet of blue Aviation Oxygen stickers and slapped one on the nearest green bottle. "Now, he said, "I can sell you an Aviation Oxygen bottle - that will be $115." "How much would it be without the sticker?" "$35", he said. It's surprising how honest people can be at times. |
Wasn't it P.T. Barnum who said, "There's a sucker born every minute"?
ABO - Hah! I only had one year of chemistry in college, but I do recall that an element is an element is an element. Oxygen is oxygen. "Bill D" wrote in message ... On May 5, 10:06 am, bumper wrote: If the tank is "portable", and you will be having it hydro tested locally, I suggest NOT using a welding supply place unless they test on-site. If they throw a bunch of bottles in a truck to send off for testing, your nice bottle will not come back looking the same. bumper Yep, welding supply shops can be tricky. Once I was on a errand to pick up a refilled (large type) O2 bottle. While I waited for my turn at the counter, I noticed a truck being unloaded at the dock. It was loaded with green O2 bottles - none of which showed the blue "Aviation Oxygen" sticker. Since I couldn't see any Aviation Oxygen bottles, I told the counterman I wouldn't be surprised if he couldn't fill my order. "No problem", he said, "Watch". He opened a drawer, retrieved a sheet of blue Aviation Oxygen stickers and slapped one on the nearest green bottle. "Now, he said, "I can sell you an Aviation Oxygen bottle - that will be $115." "How much would it be without the sticker?" "$35", he said. It's surprising how honest people can be at times. |
On Monday, May 7, 2012 12:08:34 PM UTC-5, Dan Marotta wrote:
Wasn't it P.T. Barnum who said, "There's a sucker born every minute"? ABO - Hah! I only had one year of chemistry in college, but I do recall that an element is an element is an element. Oxygen is oxygen. "Bill D" wrote in message ... On May 5, 10:06 am, bumper wrote: If the tank is "portable", and you will be having it hydro tested locally, I suggest NOT using a welding supply place unless they test on-site. If they throw a bunch of bottles in a truck to send off for testing, your nice bottle will not come back looking the same. bumper Yep, welding supply shops can be tricky. Once I was on a errand to pick up a refilled (large type) O2 bottle. While I waited for my turn at the counter, I noticed a truck being unloaded at the dock. It was loaded with green O2 bottles - none of which showed the blue "Aviation Oxygen" sticker. Since I couldn't see any Aviation Oxygen bottles, I told the counterman I wouldn't be surprised if he couldn't fill my order. "No problem", he said, "Watch". He opened a drawer, retrieved a sheet of blue Aviation Oxygen stickers and slapped one on the nearest green bottle. "Now, he said, "I can sell you an Aviation Oxygen bottle - that will be $115." "How much would it be without the sticker?" "$35", he said. It's surprising how honest people can be at times. .... Oxygen is oxygen. I was just studying with my 2012 Private Pilot Test Prep book and found a relevant and hopefully interesting passage: "Aviation oxygen should be used to replenish an aircraft oxygen systems... Oxygen used for medical purposes or welding normally should not be used because it may contain too much water. Specifications for Aviators' breathing oxygen are 99.5% pure oxygen and not more than .005 mg of water per liter of oxygen." |
On May 7, 12:42*pm, wrote:
On Monday, May 7, 2012 12:08:34 PM UTC-5, Dan Marotta wrote: Wasn't it P.T. Barnum who said, "There's a sucker born every minute"? ABO - *Hah! *I only had one year of chemistry in college, but I do recall that an element is an element is an element. *Oxygen is oxygen. "Bill D" wrote in message .... On May 5, 10:06 am, bumper wrote: If the tank is "portable", and you will be having it hydro tested locally, I suggest NOT using a welding supply place unless they test on-site. If they throw a bunch of bottles in a truck to send off for testing, your nice bottle will not come back looking the same. bumper Yep, welding supply shops can be tricky. Once I was on a errand to pick up a refilled (large type) O2 bottle. While I waited for my turn at the counter, I noticed a truck being unloaded at the dock. It was loaded with green O2 bottles - none of which showed the blue "Aviation Oxygen" sticker. Since I couldn't see any Aviation Oxygen bottles, I told the counterman I wouldn't be surprised if he couldn't fill my order. *"No problem", he said, "Watch". *He opened a drawer, retrieved a sheet of blue Aviation Oxygen stickers and slapped one on the nearest green bottle. *"Now, he said, "I can sell you an Aviation Oxygen bottle - that will be $115." *"How much would it be without the sticker?" "$35", he said. It's surprising how honest people can be at times. ... Oxygen is oxygen. I was just studying with my 2012 Private Pilot Test Prep book and found a relevant and hopefully interesting passage: "Aviation oxygen should be used to replenish an aircraft oxygen systems.... Oxygen used for medical purposes or welding normally should not be used because it may contain too much water. *Specifications for Aviators' breathing oxygen are 99.5% pure oxygen and not more than .005 mg of water per liter of oxygen." That information was true 100 years ago but it's about a century out of date. Oxygen today is made from a liquid air reduction process which produces chemically pure oxygen. This is what is supplied to all users. There's no incentive for the industry to deliberately produce contaminated oxygen. There is zero water in any compressed oxygen sold today. If you dig a bit further, you'll find specifications for welding and medical oxygen are far tighter than for 'aviation oxygen'. |
On Monday, May 7, 2012 2:11:21 PM UTC-5, Bill D wrote:
On May 7, 12:42*pm, wrote: On Monday, May 7, 2012 12:08:34 PM UTC-5, Dan Marotta wrote: Wasn't it P.T. Barnum who said, "There's a sucker born every minute"? ABO - *Hah! *I only had one year of chemistry in college, but I do recall that an element is an element is an element. *Oxygen is oxygen. "Bill D" wrote in message .... On May 5, 10:06 am, bumper wrote: If the tank is "portable", and you will be having it hydro tested locally, I suggest NOT using a welding supply place unless they test on-site. If they throw a bunch of bottles in a truck to send off for testing, your nice bottle will not come back looking the same. bumper Yep, welding supply shops can be tricky. Once I was on a errand to pick up a refilled (large type) O2 bottle. While I waited for my turn at the counter, I noticed a truck being unloaded at the dock. It was loaded with green O2 bottles - none of which showed the blue "Aviation Oxygen" sticker. Since I couldn't see any Aviation Oxygen bottles, I told the counterman I wouldn't be surprised if he couldn't fill my order. *"No problem", he said, "Watch". *He opened a drawer, retrieved a sheet of blue Aviation Oxygen stickers and slapped one on the nearest green bottle. *"Now, he said, "I can sell you an Aviation Oxygen bottle - that will be $115." *"How much would it be without the sticker?" "$35", he said. It's surprising how honest people can be at times. ... Oxygen is oxygen. I was just studying with my 2012 Private Pilot Test Prep book and found a relevant and hopefully interesting passage: "Aviation oxygen should be used to replenish an aircraft oxygen systems.... Oxygen used for medical purposes or welding normally should not be used because it may contain too much water. *Specifications for Aviators' breathing oxygen are 99.5% pure oxygen and not more than .005 mg of water per liter of oxygen." That information was true 100 years ago but it's about a century out of date. Oxygen today is made from a liquid air reduction process which produces chemically pure oxygen. This is what is supplied to all users. There's no incentive for the industry to deliberately produce contaminated oxygen. There is zero water in any compressed oxygen sold today. If you dig a bit further, you'll find specifications for welding and medical oxygen are far tighter than for 'aviation oxygen'. Well, I guess the source of at least some of the obviously widespread confusion is clear - our training materials are incorrect and/or just out of date and out of touch with technical reality. thanks. |
Bill:
In addition to being pure, bottled oxygen made from liquid air is also super dry -- all traces of water are frozen out in the process. So the old problem with oxygen not being dry is no longer an issue. |
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 01:33 AM |
Saturn I Liquid-Oxygen (LOX) Tank 6000382.jpg | [email protected] | Aviation Photos | 0 | April 10th 07 09:59 PM |
oxygen tank | Lignan Christian | Soaring | 10 | February 9th 06 10:52 PM |
filling Oxygen tanks | Bruce McFadden | Piloting | 40 | January 3rd 05 03:25 AM |
Filling oxygen tanks | Bruce McFadden | Owning | 49 | December 28th 04 11:41 PM |
