(For USA readers.)
Take your current FAR book (I like the ASA brand) to your mechanics and show them FAR 91.409 (b) under "Inspections". The key words in the regulation are "for hire in an aircraft". It says nothing about "rented" aircraft. The towplane is not "carrying" the passenger that is in the glider. The glider wings do that work. If the glider is used "for hire" then it will need a 100 hour inspection, so keep accurate daily flight logs. I am curious . . . what is the basis that your mechanics think the towplane must have a 100 hour inspection? Has your local FAA office sent them a memo? Is the club also using he towplane to carry passengers for hire or give flight instruction for hire? If so, then they are correct. For what it is worth, I have my mechanic do non-required or "preventative" maintenance every hundred hours or so, especially when I'm out of town and the towplanes are sitting dormant, like when I trailer my restored ASK-13 sailplane across the USA to the International Vintage Sailplane Meet (IVSM) on Harris Hill near Elmira, NY this June 30 - July 7. (A plug for a wonderful event!) Perhaps he will time the mags, change the plugs, replace brake pads, check flap rollers, change a tire or two, wiggle things . . . Don't be surprised at what they might find so budget for it (i.e. charge accordingly.) Identifying problems early will likely save you time and money on the required annual inspection. I figure my towplane does four takeoffs and landings in an hour. 400 or more cycles in one hundred hours. That's a lot of hot and cold cycles for the engine, wear and tear on everything else. That's more cycles than most general aviation airplanes NOT used for hire. Consider being prudent with your towplane maintenance but as far as the FAA is concerned, 91.409 (b) is the bottom line. Burt Marfa Gliders Soaring Center, west Texas USA |
Grob 103 3000 Hour Inspections | Jim Kellett | Soaring | 1 | October 20th 09 12:52 PM |
C-172 $20 / hour! C-210 $30 / hour! I found my new job... | Ricky | Piloting | 9 | February 14th 08 02:01 PM |
100 Hour Inspections | Judah | Piloting | 26 | December 1st 06 02:30 PM |
Homebuilt Inspections | john smith | Home Built | 8 | December 25th 04 02:20 PM |
Pre-buy inspections | Paul Folbrecht | Owning | 12 | March 1st 04 12:27 AM |
