PowerFlarm @ Mifflin
Old May 18th 12, 11:37 PM posted to rec.aviation.soaring
Paul Remde
Default PowerFlarm @ Mifflin
"Andy" wrote in message
On May 17, 8:19 am, "Paul Remde" wrote:
Yes the rectangular displays for the PowerFLARM
Brick are also being used at Mifflin. The PowerFLARM Brick is supplied
with
either of the 2 displays shown in the links below - or without any display
Paul and other dealers,
My recollection is that the initial brick offering price included the
standard rectangular display, the Butterfly display was an additional
cost option, and there was no price quoted for the brick with no
display.
If that was true, is there now a new reduced price if no display is
wanted, or has the price with the rectangular display been increased?
I'm also curious to know if the brick being evaluated at Mifflin has
FCC approval. I could not find it listed on the FCC approvals site.
thanks
Andy
_________________________
Hi Andy,
There were 3 options available for the brick when orders were taken in 2010.
- Bare Brick with no display
- Brick with standard rectangular display
- Brick with Display57 which fits into a 57 mm instrument hole.
You can see all 3 options on my web site. The upgrade price to get the
round Display57 is still not firm. It has been estimated at $150, but may
be as little as $75.
http://www.cumulus-soaring.com/flarm.htm
I highly recommend getting a dedicated FLARM display at putting it as high
as possible on the panel - even if you can display FLARM traffic on a PDA or
SN10, etc.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
Old May 19th 12, 02:17 AM posted to rec.aviation.soaring
Whiskey Delta
On May 18, 6:37*pm, "Paul Remde" wrote:
snip
SN10, etc.
Best Regards,
Paul Remde
Is there a rectangular display mount that will "piggy back" onto a PDA
mount such that the display will be sitting just atop the PDA/PNA
device?
WD
Old May 19th 12, 04:50 AM posted to rec.aviation.soaring
Paul Remde
"Whiskey Delta" wrote in message
On May 18, 6:37 pm, "Paul Remde" wrote:
snip
or
SN10, etc.
Best Regards,
Paul Remde
device?
WD
Good question. Not that I'm aware of, but it would be easy to make a plate
and use 3M Dual-Lock fastener tape to make such a mount.
Paul Remde
Old May 23rd 12, 04:10 PM posted to rec.aviation.soaring
Karl Kunz
Paul, thanks for some good info. One more question, does the brick use the same stub antennas as the portable? If not, can the brick antennas be used with the portable (i.e. remotely)
-karl
snip
or
SN10, etc.
Best Regards,
Paul Remde
device?
WD
Paul Remde
Old May 24th 12, 01:02 PM posted to rec.aviation.soaring
Paul Remde
"Karl Kunz" wrote in message
-karl
___________
Hi Karl,
The Brick units are using a new antenna type. I don't have any photos of it
yet and haven't held one in my hands. I've heard it is a bit large, but
works great. I'm pretty sure it would work great with a PowerFLARM
Portable. But getting one of the Brick antennas for use with a Portable is
not the only fix required for the range issue. It is my understanding that
all Portable units will need to be sent in for hardware upgrades. But that
has not been finalized yet. I imagine it will be very soon.
I already have antenna extension cables for remotely positioning the
existing PowerFLARM Portable antennas. You can see links to them he
http://www.cumulus-soaring.com/flarm...FLARM-Portable
Best Regards,
Paul Remde
Old May 24th 12, 02:16 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
-karl
The brick has three antennas: a GPS puck, a TXP/ADS-B 1090 receiving
antenna (dipole) and a Flarm TX/RX antenna (dipole). The two dipoles
are physically similar, but have different connectors. Mounting, as
others have emphasized, is key to performance. I see flarm traffic
out to about 6 miles front and sides, 2 miles or so at 6 o'clock. I
have my antennas mounted using plastic stock cut from cheap Walmart
magazine organizers which is adequate for the moment. At some point
I'm sure I''ll be inspired to do something a little more robust.
Evan Ludeman / T8
Old May 24th 12, 02:44 PM posted to rec.aviation.soaring
Dave Nadler
On Thursday, May 24, 2012 9:16:13 AM UTC-4, T8 wrote:
I have my antennas mounted using plastic stock cut from cheap Walmart
Evan Ludeman / T8
Hey ! That's a very high quality bracket !
See ya, Dave
Old May 24th 12, 03:10 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
magazine organizers which is adequate for the moment. *At some point
Evan Ludeman / T8
See ya, Dave
It's high quality in terms of electrical properties, anyway :-).
-Evan
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
Day cancelled at Mifflin (again) Frank Paynter[_2_] Soaring 0 May 24th 11 07:36 PM
Day cancelled at Mifflin Frank Paynter[_2_] Soaring 0 May 23rd 11 05:30 PM
Day 2 at Mifflin Frank Paynter[_2_] Soaring 0 May 22nd 11 11:07 PM
Pre-contest day at Mifflin Frank Paynter[_2_] Soaring 0 May 21st 11 12:48 AM
