#11
On May 24, 7:54*pm, son_of_flubber wrote:
I've been told (and witnessed) that aerotow on CG hook is initially difficult for someone who has trained for aerotow with a "nose hook" (aka hook-forward-of-CG). *Suppose this CG-hook-newbie were to take winch tow training (with CG hook). *Would the winch training reduce the initial difficulty of a CG hook aerotow? Do the difficulties/danger of aerotow with CG hook go away completely with training and experience? What sorts of misadventures are reasonably attributed to aerotow on CG hook? I understand why CG hook is superior for winch tow. *No need to rehash that explanation. Our primary trainer is an SGS 2-33A, with the low forward tow hook, it likes to climb (kite) on tow and students learn to keep the nose down. After solo they transition to the SGS 1-26D. After they are rated, they transition to our Grob 103 on the nose hook. When they are ready for single seat glass, we'll do a few tows in the Grob on the CG hook. Big issue, on a CG hook the glider goes where it is pointed. No assistance from rope tension on the nose to help keep you pointed on the tow. We teach slack line recoveries to get the nose pointed at tow before the line comes taught. That training transitions to tow with the CG hook. Law of Primacy. If on the ground, a wing goes down and you are pulled to the low wing and can't correct, RELEASE! If you are in the air and get wide in a turn on tow, get your nose pointed back at tow. The glider will accelerate and faster means it wants to climb. If you've ever been on water skis you'll understand. T |
To put my reply in context I have 456 aero tow launches with CG hook in ASW19b and 243 aero tow launches with CG hook in ASW 28. Well, if you can manage ASW19b in aerotow using CG hook, you should not have any problems with anyting else. I think that in ASW19b the hook position is a typical compromise - works well neither in winch or aerotow. |
I agree it's very type-specific. My first CG aerotow was an LS4 with a
tailskid on a gravel runway. 10 yds of furious pedal work and then it all came together. On tow I could feel no difference from a nose hook as the LS4 has perfect manners. My tailwheel Open Cirrus is even easier, including launching (from short grass) with no wing runner and the wing down. I once aerotowed a K13 on the CG hook by accident - chatting to my pupil and didn't notice the wrong hook was selected. No problem on the ground run, but the offset CG hook meant that I had to fly the entire tow with some rudder. Other types may be harder to handle. An earlier poster said that only a stupid pilot would allow kiting, but the BGA experiments some years back demonstrated that stupidity would not be necessary. Take something like a K8, which pitches up aggressively when there is a strong pull on the rope. Add in strong thermals and a pilot who reacts a second or two late (say low hours or out of currency) and kiting goes out of control rapidly, leading to a tug upset. Most UK clubs won't allow a light, high-wing glider to be aerotowed off a CG hook (though experienced pilots might, or might not, be an acceptable risk). But a decent-handling glass glider should be perfectly manageable. Directional instability on the ground run? Fix it with the rudder and, if you can't, pull the bung. Perfectly safe enough. If you might hit another glider or run off the field, even if you pull the release, then you're launching from the wrong place. |
On Friday, May 25, 2012 9:36:16 AM UTC-5, Bill D wrote:
On May 24, 11:05*pm, b4soaring wrote: On Friday, 25 May 2012 03:54:00 UTC+1, son_of_flubber *wrote: Also, CG hooks can back release if you get a lot of slack in the rope. The manual may suggest a method for blocking the back release - make sure you remove it before winching. If the CG hook is functioning properly (i.e. no weak springs), it would take a LOT of slack to get a back release. So much so that you'd be in front of the tug and probably want to release anyway. Don't mess with the hook or you might make it malfunction completely. Uncommanded releases are not a problem. Actually they very well can be. I was piloting an IS-28B2 Twin Lark a couple of years ago behind a Super Cub during a 175 km transfer aerotow to another airport. We had to go over a pass and coming over the pass flew straight into serious rotor off a sharp mountain ridge bordering the valley we were entering. Keeping the glider in position behind the super cub was a handful (a Twin Lark flies a bit like tank depending on what you are used to), I did end up getting some serious slack at one point while perfectly pointed at the cub. The cable bow reached back (the bow being to the left and almost level with the glider) to about where I was sitting in the front seat of the glider when I heard the "clonk" of the back release, the very moment I was starting to get worried it might just do that while remembering that the back release was not blocked... The Twin Lark has a non-structural nose cone and the aerotow hook mounted just in front of the front rudder pedals. It is the same Tost hook as the CG hook installed and hence back releases unless you do something about it... I could have grabbed the released cable if it hadn't been for the canopy, it was right next to me before I banked away to avoid potential damage. The bow was never a danger to the glider and never went anywhere near the wing tip or something else it could have caught onto, so the back release was completely unwarranted in this scenario. An uneventful outlanding in unfamiliar terrain followed since we had plenty of altitude and I had a variety of fields to choose from but it was an all-nighter to get the trailer and crew there, load up the glider in the dark and get it to the destination airport through some serious mountain roads. I made sure with a metal angle blocking any backwards movement of the hook rim that this would not happen again... Markus Graeber |
On May 25, 7:20*pm, Markus Graeber wrote:
On Friday, May 25, 2012 9:36:16 AM UTC-5, Bill D wrote: On May 24, 11:05*pm, b4soaring wrote: On Friday, 25 May 2012 03:54:00 UTC+1, son_of_flubber *wrote: Also, CG hooks can back release if you get a lot of slack in the rope.. The manual may suggest a method for blocking the back release - make sure you remove it before winching. If the CG hook is functioning properly (i.e. no weak springs), it would take a LOT of slack to get a back release. *So much so that you'd be in front of the tug and probably want to release anyway. Don't mess with the hook or you might make it malfunction completely. Uncommanded releases are not a problem. Actually they very well can be. I was piloting an IS-28B2 Twin Lark a couple of years ago behind a Super Cub during a 175 km transfer aerotow to another airport. We had to go over a pass and coming over the pass flew straight into serious rotor off a sharp mountain ridge bordering the valley we were entering. Keeping the glider in position behind the super cub was a handful (a Twin Lark flies a bit like tank depending on what you are used to), I did end up getting some serious slack at one point while perfectly pointed at the cub. The cable bow reached back (the bow being to the left and almost level with the glider) to about where I was sitting in the front seat of the glider when I heard the "clonk" of the back release, the very moment I was starting to get worried it might just do that while remembering that the back release was not blocked... The Twin Lark has a non-structural nose cone and the aerotow hook mounted just in front of the front rudder pedals. It is the same Tost hook as the CG hook installed and hence back releases unless you do something about it.... I could have grabbed the released cable if it hadn't been for the canopy, it was right next to me before I banked away to avoid potential damage. The bow was never a danger to the glider and never went anywhere near the wing tip or something else it could have caught onto, so the back release was completely unwarranted in this scenario. An uneventful outlanding in unfamiliar terrain followed since we had plenty of altitude and I had a variety of fields to choose from but it was an all-nighter to get the trailer and crew there, load up the glider in the dark and get it to the destination airport through some serious mountain roads.. I made sure with a metal angle blocking any backwards movement of the hook rim that this would not happen again... Markus Graeber I used to own a Twin Lark equipped for serious wave and flew it in some pretty darn turbulent Rocky mountain rotor. I never once got a back release. I suspect you have weak springs in the hook or some seriously draggy rope. |
On 5/25/2012 7:31 AM, Bill D wrote:
On May 24, 10:18 pm, Eric wrote: On 5/24/2012 7:54 PM, son_of_flubber wrote: No, and I suggest it may make you worse at aerotowing, because you learn to put the glider in a steep climb. "Kiting" on tow is a bad problem; "kiting" during a winch launch is normal operation. A pilot would have to be pretty stupid to let that happen. (Learning is where you ADD knowledge - not replace what was already there.) Learn winch launch - you WILL become a better pilot. Stupid, or poorly trained, or confused in an emergency. Still, I'm not aware that learning winch launching in any way prepares you for aero tow. The attitude and sight picture is entirely different, and you aren't flying formation. I've done mostly aerotows and some auto tows, and my experience was handling the glider took a different set of skills. A notable difference is the auto launch was easier as long as every thing went right - it took far less corrections compared to the aero tow. Learning to do winch launches so you are capable of doing winch launches is an excellent reason, but I think it's a waste of time if your goal is learning to do aerotow with a CG hook. The winch launch simply doesn't challenge the pilot in the same way a CG hook aero tow does. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
At 15:34 25 May 2012, T wrote:
If on the ground, a wing goes down and you are pulled to the low wing and can't correct, RELEASE! The above statement is probably the best advice you will ever receive, if I was picky I would make it even shorter, "If on the ground, a wing goes down, RELEASE!" Several years ago the BGA in the UK recommended that the hand was on the release at all times once the cable is attached (winch and aerotow). This means that the pilot cannot give hand signals for the take up slack/all out so the attachment of the cable is the indication that the pilot is ready for launch. If the pilot wants to stop the launch he releases. In flapped gliders I used a length of para cord attached to the release and looped over my wrist. I had reservations about this system but on balance it is the safest of the alternatives, early release prevents a bad situation becoming a disaster. |
To add to the chorus:
Any of the more-modern ships I've flown (70's glass/metal and newer) seem to fly just fine on Aerotow with a CG hook. There are three points to consider during the launch, in this order: 1) Wing position and cross-wind corrections. This has been covered by others in the thread well-enough; but I'd like to emphasize that starting with full downwind rudder helps a lot, at least in my experience. And, as others have said: The best thing to do is watch your first 50 feet of ground-roll. If it is going from bad to worse yank the release and come to a controlled stop. In my experience with auto-racing and flying, the worst situations always seem to happen when something starts to go wrong and a person tries to "save it" (by leaving their foot on the gas, or over-correcting, or whatever). Don't try that - just call it off and try again. 2) On liftoff - as you get rolling try to use forward-stick and stick- trim to get the tailwheel off the ground as soon as your rudder is effective. That'll give you better steering control on the remainder of takeoff *and* put the wing at a lower angle of attack (so you won't jump/kite as quickly). Be prepared to add forward stick as you come off the ground, and don't be shy about changing your trim multiple times on the takeoff and aerotow. I'm not yet a CFIG but I've been flying with a lot of new-to-XC pilots recently and I've noticed that a LOT of them don't trim on aerotow, during thermalling, or in many other phases of flight. Trim is your friend - the less you're pulling or pushing on the stick, the better control-inputs you can provide for roll & pitch excursions and the more relaxed you'll fly (making you better able to feel and focus on other things). 3) Throughout the launch and aerotow - USE YOUR FEET! Aerotowing with a CG hook means that you can pretty-much point the nose in any direction you want. I actually view it as a nice "bonus" and prefer towing with a CG hook for this reason (excepting the crosswind difficulties during the beginning of the ground-roll). But I again have found many newbies recently that don't think to use their feet on aerotow. Its far easier to make small corrections with a bit of rudder and slipping, than with big bank-angles on tow. Keep your feet active and don't be shy about using some rudder (within reason) to keep the glider behind the towplane and pointed in the direction you want. Just my $0.02, --Noel P.S. The back-release of the rope is a tricky thing on the ground in my DG-300; like others I find a bit of wheelbrake while taking up slack and just at the beginning of the roll is an effective "cure". |
On May 31, 7:05*pm, "noel.wade" wrote:
To add to the chorus: Any of the more-modern ships I've flown (70's glass/metal and newer) seem to fly just fine on Aerotow with a CG hook. *There are three points to consider during the launch, in this order: 1) Wing position and cross-wind corrections. *This has been covered by others in the thread well-enough; but I'd like to emphasize that starting with full downwind rudder helps a lot, at least in my experience. *And, as others have said: The best thing to do is watch your first 50 feet of ground-roll. *If it is going from bad to worse yank the release and come to a controlled stop. *In my experience with auto-racing and flying, the worst situations always seem to happen when something starts to go wrong and a person tries to "save it" (by leaving their foot on the gas, or over-correcting, or whatever). Don't try that - just call it off and try again. 2) On liftoff - as you get rolling try to use forward-stick and stick- trim to get the tailwheel off the ground as soon as your rudder is effective. *That'll give you better steering control on the remainder of takeoff *and* put the wing at a lower angle of attack (so you won't jump/kite as quickly). *Be prepared to add forward stick as you come off the ground, and don't be shy about changing your trim multiple times on the takeoff and aerotow. *I'm not yet a CFIG but I've been flying with a lot of new-to-XC pilots recently and I've noticed that a LOT of them don't trim on aerotow, during thermalling, or in many other phases of flight. *Trim is your friend - the less you're pulling or pushing on the stick, the better control-inputs you can provide for roll & pitch excursions and the more relaxed you'll fly (making you better able to feel and focus on other things). 3) Throughout the launch and aerotow - USE YOUR FEET! *Aerotowing with a CG hook means that you can pretty-much point the nose in any direction you want. *I actually view it as a nice "bonus" and prefer towing with a CG hook for this reason (excepting the crosswind difficulties during the beginning of the ground-roll). *But I again have found many newbies recently that don't think to use their feet on aerotow. *Its far easier to make small corrections with a bit of rudder and slipping, than with big bank-angles on tow. *Keep your feet active and don't be shy about using some rudder (within reason) to keep the glider behind the towplane and pointed in the direction you want. Just my $0.02, --Noel P.S. *The back-release of the rope is a tricky thing on the ground in my DG-300; like others I find a bit of wheelbrake while taking up slack and just at the beginning of the roll is an effective "cure". I like your analytical approach. You'll make a great instructor. |
I'm not sure that the advice to keep hold of the release on tow would be advisable in more turbulent environments (like Arizona) where unexpected glider movement could cause an unintended release.
Mike |
| Thread Tools | |
| Display Modes | |
| CG Hook for 1-26? | [email protected] | Soaring | 1 | October 29th 06 02:21 AM |
| Tow hook | [email protected] | Soaring | 2 | September 27th 06 03:16 AM |
| Elfe S4 Winch hook | Derek Wilson | Soaring | 0 | July 21st 05 12:07 PM |
| Tow Hook 337 for a 150-150 | 1JH | Soaring | 3 | July 19th 05 07:35 PM |
| CG hook & Low Tow | Ray Lovinggood | Soaring | 2 | July 25th 03 07:20 AM |
