"Roger Halstead" wrote in message
... It probably wouldn't be enough to push the gas half the height of the tank unless you were really moving. "Let me explain further", he says; while wondering why it is assumed that *all* planes carry their fuel in the wings. The Emeraude - a low wing aircraft - carries it's fuel in a nose tank. They can be configured for gravity feed. Mine has two fuel pumps plumbed in series, one electrical and one mechanical. These pumps add restriction to free fuel flow due to the check valves. In the event of vapor lock (can happen) or multiple pump failure (unlikely), gravity feed will not be adequate to overcome the flow restriction. Being a belt and suspenders kind of guy, who enjoys breathing, I am eyeing the system and trying to improve it where possible. Many aircraft with fuselage (nose) tanks have ram air inlets in their tank caps. My cap is not vented. The tank has a vent line which exits through the fuselage behind the wing. I am not concerned with multiple tanks (I do have a rear aux tank, but ignore that. They are not interconnected), So, may I repeat the original question? "The inlet area of the scoop is .84 inČ. There will be three 3/8" OD aluminum tubes inside the scoop through which the air will flow. Two of them are the vents for the front and rear tanks, while the third is the drain tube for the rear tank fill. (There is a fuel door on the top of the fuselage for the rear tank. The tube is intended to drain any liquid such as rainwater or fuel overflow from the area inside the door.) Any air entering the third tube will exit around the fuel door with only the friction loss from the tube to restrict flow." Thanks, Rich |
