I used Glide Navigator 2 for the entire flight. It worked great. When
I finished the flight, I pressed "quit program" and then for some reason it did not ask "do you want to transfer your flight log" like it has with before with a Cambridge model 10. XCSoar is downloaded on the PDA as well, but I cannot figure out how to download the flight trace with it. I also ran a USB cable from the GPS to my laptop to see if it could be done that way and the laptop would not recognize the GPS (despite the fact that when I plugged in the cable from the laptop it provided power to the GPs and turned the green light on.) Any thoughts? |
On May 31, 8:40*am, Scott Alexander
wrote: I used Glide Navigator 2 for the entire flight. It worked great. When I finished the flight, I pressed "quit program" and then for some reason it did not ask "do you want to transfer your flight log" like it has with before with a Cambridge model 10. XCSoar is downloaded on the PDA as well, but I cannot figure out how to download the flight trace with it. *I also ran a USB cable from the GPS to my laptop to see if it could be done that way and the laptop would not recognize the GPS (despite the fact that when I plugged in the cable from the laptop it provided power to the GPs and turned the green light on.) Any thoughts? Any logger will need specific drivers and software. If you have the latest version of XCSoar then there should be a download function with specific settings for the logger. Max will be better at helping with that. For the PC you will need to download drivers and the software from: http://www.imi-gliding.com/index.php...t&id=4&lang=en Then you can download the files. |
On May 31, 4:52*pm, Tim Taylor wrote:
snip Any logger will need specific drivers and software. snip Not necessarily true. The Ew MicroRecorder plugs in with a standard USB cable and automatically appears as a removeable HDD in 'My Computer' - at least it does on Windows PCs, unless they have an ark- ware version. The same is true of the Nano, but not of the Erixx. |
New flight recorder - flyWithCE Flight Recorder | uros | Soaring | 12 | May 5th 09 08:31 PM |
Erixx GPS Flight Recorder - Feedback? | Paul Remde | Soaring | 1 | December 23rd 08 12:16 AM |
Erixx flight recorder - opinions? | Wojciech Scigala | Soaring | 2 | November 3rd 08 02:27 PM |
OLC flight trace page | Brad[_2_] | Soaring | 1 | October 20th 08 05:12 PM |
Flight download | Steve Freeman | Soaring | 8 | June 19th 07 10:01 PM |
