Compare/Contrast: CG hook on aerotow vs. CG hook on winch
Old June 2nd 12, 03:13 AM posted to rec.aviation.soaring
Don Johnstone[_4_]
Default Compare/Contrast: CG hook on aerotow vs. CG hook on winch
At 15:59 01 June 2012, Mike the Strike wrote:
I'm not sure that the advice to keep hold of the release on tow would be
advisable in more turbulent environments (like Arizona) where unexpected
glider movement could cause an unintended release.
Mike
Should have made it clear, it is only necessary to have your hand on the
release during the ground run and take off for both aerotow and winch
launch, once airborne and stable you can just keep your hand near the
release as normal. I use the looped paracord so I have some slack in the
sytem anyway.
CG Hook for 1-26? [email protected] Soaring 1 October 29th 06 02:21 AM
Tow hook [email protected] Soaring 2 September 27th 06 03:16 AM
Elfe S4 Winch hook Derek Wilson Soaring 0 July 21st 05 12:07 PM
Tow Hook 337 for a 150-150 1JH Soaring 3 July 19th 05 07:35 PM
CG hook & Low Tow Ray Lovinggood Soaring 2 July 25th 03 07:20 AM
