A Rough Day Towing
Old June 2nd 12, 03:50 AM posted to rec.aviation.soaring
Brad[_2_]
Default A Rough Day Towing
I'm sure the release rope break with the rope over the wing slew that
glider sideways. The pilot could not see the damage to the leading
edge of the wing and flew 4 hours?? WTFO.
Helloooooooooooooooooo, captain CRUNCH, where are you????
Brad
Old June 5th 12, 01:25 PM posted to rec.aviation.soaring
GARY BOGGS
What size rope were you using? Was there an weak link?
Boggs
Old June 5th 12, 03:17 PM posted to rec.aviation.soaring
150flivver
Boggs
What type of release mechanism?
Old June 5th 12, 04:27 PM posted to rec.aviation.soaring
The glider's release mechanism is the standard Dick Schreder design.
http://www.soaridaho.com/Schreder/Co...k/Tow_Hook.htm
Here is a photo of the mechanism as it appears in HP-14T blue-prints.
http://www.soaridaho.com/Schreder/HP..._Tow_Hitch.jpg
This hook has been very reliable for the past 50+ years. The concept has
been copied and install on other sailplane designs including the 1-35A
"150flivver" wrote in message
Boggs
Old June 5th 12, 06:30 PM posted to rec.aviation.soaring
BobW
This hook has been very reliable for the past 50+ years. The concept has been
And also - at least conceptually/functionally - George Applebay's Zuni design
(though some may now/have-had Tost releases); I can't speak for
dimensionally/geometrically. Difficult (for me) to imagine a simpler release
mechanism.
I never had release a release problem in 106 HP-14 and 655 Zuni aerotows. Had
1-each back release in both ships, from BIG bows in the rope...as should have
happened.
Bob W.
Snip...
Old June 5th 12, 08:00 PM posted to rec.aviation.soaring
Dan Marotta
I think the rope is 3/8 polypropylene. The rope strength is within FAA
requirements for the gliders we tow. We use a weak link with a tost ring,
but not with the Schweizer. There's a Schweizer release on the tug.
"GARY BOGGS" wrote in message
Boggs
Old June 6th 12, 12:48 AM posted to rec.aviation.soaring
Brian[_1_]
I have been a bit concerned with the ropes some places use.
http://www.engineeringtoolbox.com/po...th-d_1516.html
shows the following minimum breaking strength
1/4 1125 lbf 80%= 900 lb minimum glider weight
5/16 1710 lbf 80%= 1368 lb minimum glider weight
3/8 2430 lbf 80%= 1944 lb minimum glider weight
I prefer towing behind 1/4" rope I have seen a few rope breaks with
1/4" all seemed warranted with a rope in good condition.
It seem to me that unless you are towing a fully loaded ASG29 or a two
place that 1/4 rope is probably what should be used unless of course a
weak link is used. And even then 1/4" rope should be adequate at the
200% rating or less.
Am I missing something?
Brian
Old June 6th 12, 01:44 AM posted to rec.aviation.soaring
Dan Marotta
Wear on the runway, UV degradation.
"Brian" wrote in message
Brian
Rough Landings on Ice C J Campbell[_1_] Piloting 1 March 8th 08 07:30 PM
rough running C-182 R&A Kyle Owning 10 November 16th 04 11:45 PM
PIREP: 2I3 (Rough River State Park, Falls of Rough, KY) Kyler Laird General Aviation 0 March 1st 04 12:11 AM
Rough Engine, please help John Clonts Owning 14 February 26th 04 12:09 AM
HELP! To buy or not...rough 63 aztec for $25,000 david Owning 27 January 15th 04 01:06 AM
