ASK 21 Question
Old June 2nd 12, 12:58 PM posted to rec.aviation.soaring
chuck patterson
Default ASK 21 Question
Hi folks,
I have to remove the control surfaces from my K 21 for an upcoming
inspection. Does anyone know what size rivets I will need to reinstall
them? I can’t find the reference in my maintenance manual and the
flight manual is 60 miles away at the gliderport.
Thanks in advance,
Chuck
Old June 2nd 12, 01:37 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
On Saturday, June 2, 2012 4:58:06 AM UTC-7, chuck patterson wrote:
Hi folks,
Thanks in advance,
Chuck
Cherry Commercial (aluminum) MSP-32 .125 grip
Aircraft Spruce & Specialty has them
Cheers,
JJ
Old June 2nd 12, 04:24 PM posted to rec.aviation.soaring
Bill D
On Jun 2, 5:58*am, chuck patterson wrote:
Hi folks,
inspection.
What kind of inspection?
Old June 3rd 12, 12:51 AM posted to rec.aviation.soaring
Bob Kuykendall
JJ, there's a contradiction there somewhere. The MSPs are monel, not
aluminum.
Thanks, Bob K.
Old June 3rd 12, 01:44 AM posted to rec.aviation.soaring
The glider is due for a 3000 hour inspection. Schleicher requires the control surfaces to be checked for mass balance as a part of the inspection program.
Regarding the monel question, did I just order the wrong rivets?
Chuck
Old June 3rd 12, 05:51 AM posted to rec.aviation.soaring
aerodyne
Chuck
When in doubt, either drive to the airport to get the manual, or email
the factory and dealer for the correct info. RAS is a poor source for
approved data.
If it is a 3k inspection is that not per a factory S/B? if so it may
be on line.
In general drilling out a monel blind with a steel core is less fun
than Alum. YMMV
aerodyne
Question ?? Thomas Buyea Piloting 4 June 20th 07 07:52 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
OSH question Bill Chernoff Home Built 8 November 20th 04 01:07 AM
