Cambridge 302 Utility app
Old June 7th 12, 01:44 PM posted to rec.aviation.soaring
Default Cambridge 302 Utility app
Has anyone written an Android app that replicates the Cambridge 302 utility?
Old June 7th 12, 03:59 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
It's making its way into XCSoar. It's not complete, has bugs.
Secure flight d/l to android device does work, but puts the flight log
in /logs rather than /flights which might confuse your scorer at a
contest. It uses a long file name format which can't be validated
properly using the (disgusting) dos based valicam2 utility which the
powers that be still use to validate flights for badge & record
purposes (minor: just rename the file, this has no effect on
security).
Waypoint database transfer doesn't work at all, will erase all
waypoints from the 302 if you force the issue.
Some, but not all setup options can be changed in the 302 via xcs,
don't recall which ones aren't supported.
-Evan Ludeman / T8
Cambridge 302 download utility unavailable. Copy anyone? Kurt Thams Soaring 6 April 30th 12 03:46 PM
Cambridge Utility software Bob 7U Soaring 4 September 5th 11 06:18 PM
Cambridge Utility Program Question Scott Alexander[_2_] Soaring 4 February 9th 10 07:34 PM
Utility program for PDA Oscar Goudriaan Soaring 4 April 10th 08 07:11 PM
Cambridge 302/Cambridge 3UTIQ255 utility/ WinPilot/iPAQ 4155 Nathan Whelchel Soaring 4 July 5th 04 11:22 PM
