On 6/13/2012 12:45 PM, Andy wrote:
On Jun 13, 6:31 am, John wrote: Needless to say, making sure the ballast is sloshed so the wings are balanced, the upwind wing is held a little low, and the wing runner is an olympic sprinter helps too. I recently couldn't persuade a wing runner to hold the upwind wing low with predictable consequences. John, Do you always takeoff with full ballast? In my ASW19 I always had full water or no water so a wing low cross wind takeoff was normal. With the 28 I'm never full and I'd rather be ballanced and stay ballanced than have the wing low. If the wing runner really understood what was going on then holding the wings level until start of the roll and then lowering slightly may work but I'm usually happy to find a wing runner that understands the need for balance and a fast run. What do other do for cross wind takeoffs with partial ballast? Andy Zuni experience, ~48 gallons max (more than I could ever effectively use), integral tanks with internal baffles, tailwheel, nose hook, negative flaps...my experience with (any, mostly partial) ballast was inertia was your friend in every case/situation...hence my vote in that ship was for max wingtip clearances. In every case, beginning the run with negative flaps, I obtained aileron control before any wingtip dropped. I always instructed my wingrunners to level the wings, remove their hands to *show* me wing weights were really equalized, and give me the longest run they could without holding back on the tip. (Once the water was equally distributed, I preferred to have them rest the wing bottom surface on the flat of their palm, & explicitly said I did NOT want them wrapping their fingers around the leading edge...simply run/sprint until the tug outsped their best effort. Obviously, gusty crosswinds dictated some degree of non-level-ness, but "close enough to level for practical purposes" was always the goal.) No connecting of rope until the glider was perfectly aligned with the runway. Elaborating briefly on the "never had any aileron control issues" claim, that was true even behind a 180 HP Super Cub at 5300' msl from a 4,400' strip. I *did* swear off any more fully ballasted T.O.'s from the strip behind that tug after my only fully ballasted takeoff there...non-existent fully-ballasted PTTT options prior to being able to execute a downwind return, and WAY too long 'in the crash zone' below return height. I should note my ship had the original stalky gear, which put a LOT of weight on the tailwheel (relative to many 15-meter ships), further making the ship less prone to weathervane in any event. YMMV, Bob W. |
ILS Runway 1, Visual approach runway 4 KMEI - Video | A Lieberma[_2_] | Owning | 0 | July 4th 09 06:13 PM |
ILS Runway 1, Visual approach runway 4 KMEI - Video | [email protected] | Instrument Flight Rules | 0 | July 4th 09 06:12 PM |
ILS Runway 1, Visual approach runway 4 KMEI - Video | [email protected] | Piloting | 0 | July 4th 09 06:11 PM |
737 runway accident video | WolfRat | Piloting | 7 | January 5th 08 06:14 PM |
Private Aero L-39C Albatros enroute to the runway | Tom Callahan | Aviation Photos | 0 | November 26th 07 05:14 PM |
