Texas Tragedy Info?
Old June 18th 12, 08:26 PM posted to rec.aviation.soaring
Bill D
Default Texas Tragedy Info?
On Jun 18, 12:35*pm, wrote:
On Monday, June 18, 2012 2:13:38 PM UTC-4, Ramy wrote:
On Monday, June 18, 2012 10:54:30 AM UTC-7, cuflyer wrote:
On Monday, June 18, 2012 9:37:03 AM UTC-4, Linwood wrote:
Anyone have any knowledge of the three fatality glider crash in Texas?
Glider type? Situation?
Linwood
Kid on his mother's lap - ? *Affecting control - ?
This is really ugly.
1FL
It was indeed the freaking tail dolly!!!
http://blog.chron.com/newswatch/2012...ash-under-inve...
Ramy
Nope- If the tail dolly was on, glider is still flyable. Most likely speculation on may part-#1 rule broken here which is FLY THE AIRPLANE.
I have seen a few tail dolly incidents or the years, and in every case, the pilot had to be told that the tail dolly was still on.
Other bad rule broken- NO unrestrained people in the glider- ever.
Terribly sad
UH
Probably true, but I've seen some monster Lark dollies which were so
heavy one person could barely lift them. Even with the CG in the
allowable range, the Twin Lark demands respect. It might not take
much weight on the tail boom for it to turn nasty.
This accident has all the earmarks of one which will drive changes to
the FAR's. The FAA has been grumbling for years the requirements to
get a Commercial-Glider or CFI-G are way too easy to meet. I think
fair warning is in order that we may see changes to Part 61.
My deepest sympathies go to the family and friends of the mother and
daughter.
Old June 18th 12, 11:23 PM posted to rec.aviation.soaring
JohnDeRosa
Very sad, especially so on Father's Day and with three members of the
same family.
Some other links with photos and video.
http://www.cbsnews.com/8301-201_162-...-glider-crash/
http://www.khou.com/home/3-family-me...=y&c=y&c=y&c=y
In image 2 of 8 at the KHOU site the (orange) tail dolly is clearly
visible in a picture taken at what might have been very soon after the
accident.
- John
Old June 19th 12, 02:41 AM posted to rec.aviation.soaring
Frank Whiteley
same family.
accident.
- John
Report verifying that the tail dolly was on the glider.
http://www.khou.com/news/local/Cause...159501035.html
Old June 19th 12, 04:35 PM posted to rec.aviation.soaring
Nigel Pocock[_2_]
If the tail dolly was left on the angle of attack on the ground run would
be less so it wouldnt lift off till a higher speed had been reached. Could
this have had any control effects on tow?
If the toddler was sitting on his mothers lap his feet would be straight
out in an ideal place to interfere with the stick. Bad bad idea.
Old June 19th 12, 05:40 PM posted to rec.aviation.soaring
Bill D
The IS28b2 manual calls for +10 degree flap for aero tow takeoff and
the normal technique is to lift the tail early so the dolly probably
had no effect on liftoff speed. If the dolly was light it very likely
didn't shift the CG enough to provide a probable cause or even a
contributory factor in this accident - the Twin Lark is a big, heavy
and stable bird. Most likely the dolly is significant only in that it
provides evidence of carelessness.
If you put a small child in the cockpit of a glider, they will almost
invariably start yanking, pulling and twisting everything they can
reach making them unsafe as passengers. A child in a mother's lap
would be able to reach everything except the rudder pedals.
Old June 19th 12, 06:06 PM posted to rec.aviation.soaring
soartech[_2_]
Are the wing runners trained to check for extra big orange things
hanging off the glider
before takeoff? I know it is not their fault, but at the critical
launch the pilot is helpless to
see this mistake.
Old June 19th 12, 06:26 PM posted to rec.aviation.soaring
BobW
see this mistake.
Making zero speculation as to root cause(s) of this tragedy, and considering
only the presence of the tail dolly at the start of aerotow, it's clear to any
informed soaring participant that this item was missed by at least one person
(PIC), and presumably two (wing runner).
I was "lucky enough" to witness a dolly-on takeoff prior to my solo (Phoebus
A; PIC's initial flight in it; it ended well), and the more experienced people
around at the time gave me a thorough exposure to all the myriad errors made
along the way to such a launch. The lessons were obvious...once they'd been
pointed out to me.
I've also begun one takeoff roll with my tail dolly attached (haste;
inexperienced wing-runner), realized ~when tuggie applied power I couldn't
remember having checked for tail dolly removal, listened (no joy one way or
the other), tried a tentative rudder input (inconclusive), pulled the plug
(listening to that little voice in my skull). There it was, on the fuselage,
in all its international orange glory. (What an idiot!)
Point being - others having already touched upon likely
CG/directional-stability issues associated with its presence - that every
reader who's hearing little voices in his/her head about the presence of the
tail dolly in this terribly sad instance ought to be actively listening to
that voice against the future day it may (will?) need to be acted upon.
Clearly, beginning a takeoff roll with the taildolly attached is an avoidable
mistake...even if in a very few designs it may be self-correcting (e.g. G-102).
Bob W.
Old June 19th 12, 08:13 PM posted to rec.aviation.soaring
see this mistake.
pointed out to me.
Bob W
A real risk also, and I say this without speculation in this case, is for some really helpful person to start screaming right away on the radio about the tail dolly. In a situation like this, it is FAR better to let the pilot get high enough to terminate the tow reasonably, than panic him into a low premature dangerous release. This also permits him to organize his landing allowing for the almost inevitable spin around the wheel groud loop.
UH
tragedy at Salida, Colorado David Kinsell Soaring 0 October 28th 07 03:16 PM
Lessons learned from the Oregon tragedy john smith Piloting 100 December 12th 06 04:34 AM
GA _is_ safer than some modes of transport. Was: Tragedy Jim Logajan Piloting 56 October 27th 05 11:51 AM
A tragedy - a Minden death today! David Bingham Soaring 25 October 28th 04 03:49 AM
The sea may be giving answers to a 64-year-old tragedy Seppo Sipilä Military Aviation 6 June 9th 04 02:29 AM
