Texas Tragedy Info?
Old June 20th 12, 03:30 PM posted to rec.aviation.soaring
Hartley Falbaum
Default Texas Tragedy Info?
It has not been mentioned (yet), but did the Lark have a CG hook, or a
nose hook?
Things can get out of hand quickly with a CG hook if attention is
diverted.
On Jun 20, 10:17*am, T wrote:
On Jun 19, 8:25*pm, Ben Brand wrote:
At 02:30 20 June 2012, Bill D wrote: Tail dollies and wing wheels, once removed are placed to the side,
forward of the wing tip where the pilot can see it, but far enough
away that the wing runner will not trip over it.
YES! *This is the way to do it. *When the pilot gets to "Dolly" on the
checklist, a quick look to the side confirms it is off. *It helps if
your dolly is a unique color not to be confused with another.
I'm new to gliding so excuse my ignorance, but shouldnt the D(olly) check
be done before you get into the plane or is there no standard on the ABCD
checks?
Rather than checking that the Dolly (or someone elses that looks like
yours) is on the grass to the side it would make more sense that you
confirm, regardless of whos Dolly it is... it isnt attached to the back of
your plane?
Some locations.. to save time on an active shared runway.. shared with
powered aircraft. If there are enough people for ground handling, the
pilot will get in and strap in before being pushed to the runway..
leave the tail dolly off for easier ground movement.
So the dolly may or may not be removed before the pilot gets strapped
in.
T
Old June 20th 12, 04:10 PM posted to rec.aviation.soaring
Bill D
nose hook?
diverted.
checks?
your plane?
in.
T
AFAIK, all IS28b2 Twin Larks have both a CG and nose hook.
Old June 20th 12, 04:12 PM posted to rec.aviation.soaring
Judy Ruprecht
nose hook?
diverted.
Based on Serial #71, formerly in use here in WI, the IS28B2 Lark ex-factory
standard equipment included both hooks.
Judy
tragedy at Salida, Colorado David Kinsell Soaring 0 October 28th 07 03:16 PM
Lessons learned from the Oregon tragedy john smith Piloting 100 December 12th 06 04:34 AM
GA _is_ safer than some modes of transport. Was: Tragedy Jim Logajan Piloting 56 October 27th 05 11:51 AM
A tragedy - a Minden death today! David Bingham Soaring 25 October 28th 04 03:49 AM
The sea may be giving answers to a 64-year-old tragedy Seppo Sipilä Military Aviation 6 June 9th 04 02:29 AM
