Colibri II thinks I have an engine
Old July 2nd 12, 12:50 AM posted to rec.aviation.soaring
Wojciech Scigala
Default Colibri II thinks I have an engine
Użytkownik akiley napisał:
I'm not sure how I upload my IGC to the group, but it's on OLC here. (Region 6, 6/27/20012, Aaron Kiley). ... Aaron
http://www.onlinecontest.org/olc-2.0...=olc&c=US&sc=6
Your guess was right, it was a noise spike.
Edit-Flight Properties-set "Pure Glider".
WojtuÅ›
Old July 2nd 12, 12:56 AM posted to rec.aviation.soaring
akiley
Is this OK for badge flights? Don't I have to prove I'm not running an engine? ..l Aaron
Old July 2nd 12, 02:21 AM posted to rec.aviation.soaring
Darryl Ramm
Oops obvious bad ENL glitches there. You should look at those and think back - were you opening the nearby vent window when they occurred?
You don't have an engine to run, so no you do not need to prove you are not running it. You are not even required to have an ENL capable flight recorder, b but you just happen to and its just recording some noise. Just save hassle and have the OO note that you don't have there are spurious ENL glitches in the file and that, indeed your glider does not have an engine.
Darryl
Old July 2nd 12, 04:07 AM posted to rec.aviation.soaring
akiley
OK, my bad. The Colibri was mounted near the side vent and I remember using my hand to divert extra air into the hit cockpit. Lesson learned.
....Aaron
Harris Hill, NY's amazing soaring conditions. and everyone thinks the [email protected] Soaring 3 July 18th 11 01:43 PM
Italians take note: An American in Paris thinks poorly of yourworkmanship. a[_3_] Piloting 1 June 27th 10 08:46 PM
737 thinks it's a DC-10? Kingfish Piloting 87 November 15th 07 07:16 PM
Is it just me that thinks this was stupid Bravo Two Zero Piloting 55 May 17th 07 06:30 AM
Mini Helicopter Thinks for Itself NewsBOT Simulators 0 February 18th 05 09:46 PM
