Cracks are bad news, right?
Old July 2nd 12, 01:26 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
Default Cracks are bad news, right?
It appears that a major cause of cracks in gelcoat is the difference in the
expansion coefficient of polyester gel and epoxy resin/glass. For this
reason my club discourages the practice of taking a glider into air which
has a temperature of less than -20 deg C. Giving the airframe a cold soak
and then returning it to warmer air quicly will cause substantial cracks
but only in the gel.
Having said that the gelcoat used on the Slingsby Kestrel did not seem as
baddly effected as many other gliders. Probably the worst culprit is the
Grob 102/3
At 11:18 02 July 2012, John Firth wrote:
One of the best, most informative and authorative threads
I have read; reassuring!
John F
An old, no longer bold pilot. (PIK 20E)
At 23:21 01 July 2012, BobW wrote:
On 7/1/2012 8:23 AM, JJ Sinclair wrote:
Remember the crack in the engine mount that failed and brought down
airliner? How about the B-52 that taxied onto the runway, applied full
power and the left wing fell off! This all started as a crack near the
spar
after an air-refuling mishap. Would you fly a wood sailplane with
cracks
in
th skin? No way, don't walk, run away from that puppy! Would you fly
an
aluminum ship with cracks in the skin? That old girls been rode hard
and
put away wet, right? Fear of cracks is in our DNA. Remember; Step on a
crack and break your mothers back?
So now you find a crack in the skin of your fiberglass sailplane. Bad
news,
right? Actually no. Fiberglass sailplanes are covered with a thin
layer
of
rock-hard gelcoat that was placed over a flexible structure. I
remember
DG-400 at Minden, that had been flown extensively in wave conditions.
It
was literally covered with cracks. The wings had cord-wise cracks
every
half inch on both sides of both wings. This ship was flying regularly
and
was considered airworthy.
Yeah, but I got a crack coming from the corner of my spoiler box, is
my
wing going to fall off? Nope, when your wing skin was laid up in its
mold,
the fiberglass cloth wouldn't fit tightly into the corners and around
edges of your spoiler box, so filler and extra gelcoat was applied all
around the spoiler box to allow the cloth to smoothly overlap the box.
The
corners of the box are stress concentration points and cracks will
quite
likely appear there. How deep do these cracks go? All the way through
gelcoat and filler, but they stop when they reach the fiberglass cloth
because they are gelcoat cracks migrating IN from the rock-hard
coating,
NOT cracks in the fiberglass migrating OUT!
Once again, this is just my humble opinion, but it was formed after 40
years of grinding out your cracks and finding no structural issues.
JJ
Thanks for bringing your "street cred" to this arena, and, for having
intestinal fortitude offer an empirical, repair-based opinion, JJ! Even
if
it
gores FUD-based oxen...
FUD = Fear Uncertainty Doubt
My own aerospace-engineering-degreed opinion/conclusion mirrors yours.
(FULL
DISCLOSU 1) I never made my living in the airplane
structural-analysis
field; 2) the following discussion assumes "first generation glass"
ships,
simply because they're the "floppiest" of the composite birds, due to
relative lack of stiffness of glider-specific, structural fiberglass
compared
to carbon. What follows blends critical-thinking and empirical
observation,
underlain by a reasonably decent engineering understanding of the
materials
involved and typical physical properties. It is a GENERAL discussion.
The
devil is always in the details. YMMV, of course...)
There are LOTS of 1st-generation, non-carbon-reinforced, gliders out
there
in
used glider land. Likely, most have experienced gel-coat cracking at
various
times in their lives, regardless of whether they originally arrived with
"the
good gelcoat" or "the less-good gelcoat." Probably, by now, most have
had
gelcoat cracks at some time in their lives.
The key element - as JJ noted - is the underlying structure is MUCH more
flexible than is any sprayed-in-mold gelcoat. Think chocolate-coated
vinyl
bar
stock. Yeah, it's an awful analogy, but you get the idea...what's
underneath
will bend - without breaking - far beyond what unmelted chocolate will
withstand in its crack-free state. Want another analogy? Think plastic
paint
stirring stick. How do you clean 'em once paint on 'em has dried? If
you're
lazy like me, you simply bend 'em back and forth to crack the paint
film,
then
peel. I've never yet broken a plastic paint stirrer.
Gelcoat (or paint or any other coating atop the glider's structure) is
present
for essentially 3 reasons: 1) aerodynamics (maximizing laminar flow runs
requires a smooth surface); 2) looks (few people would purchase an
un-coated
composite glider even if it was the laminar equal of competitors,
because
to
most eyeballs, uncoated would look "unpretty"); and 3) UV protection (UV
degrades essentially everything!). Rank 'em in whatever order is
important
to
you...
In a nutshell, there tends to be two schools of thought concerning
gel-coat
cracks. One tends to be FUD-based, one does not.
If cracks per-se concern you, then limit your future-ownership-searches
only
to ships in pristine, uncracked condition. Be prepared to pay
accordingly.
If you're comfortable with input such as JJ's and the thought process
underlying posts as this, your selection will be considerably larger,
asking-price range considerably less exotic, and ship performance
little-degraded, in sport XC terms.
Dick Johnson had a saying: "Air has fingers, but no eyes." He meant
exterior
looks were unimportant viz-a-viz surface smoothness, when considering
ONLY
laminar flow. He also very kindly measured clean and "buggy" performance
numbers for just about every 1st-generation ship you might find for sale
out
there. Number freaks - and many wannabee-XC pilots - obsess over the
differences; for all practical purposes few weekend sport pilots will
ever
have the ability to detect 'em. *Discussing* numerical performance
differences
is great fun, but of little real-world effect on one's ability to go XC
and
have huge amounts of fun doing so.
Summarizing - the preceding mostly addresses issues arising from the
relative
stiffnesses of 1st-generation-glass glider *structure* vs. that
structure's
protective coating.
What follows seeks to address two concerns - oft expressed - implying:
1)
a
direct causal possibility that gel-coat cracks propagate directly INTO
fiberglass, and 2) crack-enabled UV degradation is imminently
life-threatening
to Joe PIC.
Some things to bear in mind: 1) ALL the structural fiberglass is 100%
encased
within the resin matrix; 2) any NON-structural fiberglass is similarly
encased; 3)I've yet to hear a plausible theory for how a gelcoat crack
can
propagate across the interface into the underlying (relatively
soft/non-brittle) resin substrate; 4) "all-fiberglass" composite ships
don't
routinely suffer from fractured wings, regardless of gelcoat condition;
5)
cracks that don't propagate into the substrate will not allow any UV to
propagate either; 6) 1st-generation glass ships are designed to
stiffness
criteria, not strength criteria.
That last is significant to the extent that 1st-generation composite
glider
wings are considerably stronger than they need to be in a pure G-load
sense,
simply because were they not, no one would buy the ships because their
(flutter-limited) Vne would be ridiculously/unusably low. I suspect
somewhere
on YouTube is a video clip or two of German flutter tests of gliders.
Even
to
paid test pilots, the footage is impressive!
But back to "propagating cracks" and "the UV concern"...
Propagating cracks - Ask any experienced glider repairman how many crack
situations they've seen that they believed to have propagated DOWN/into
structure from the gelcoat, as distinct from the other direction. If I
read
JJ
correctly, his answer appears to be "Zero." When I asked another
well-known
western glider repairman the same question, his answer was, "Zero."
Further
he
knew of zero gliders relegated to the scrap heap from UV
degradation...as
distinct from "refinish cost/relative value" considerations. His glider
build/repair experience then spanned nearly 3 decades.
My conclusion is the cracks you need to worry about do NOT come from
routine
assembly/flight loads.
I know "UH" sometimes is on RAS, and would welcome him sharing his
experience
in this matter.
UV - Pretend you know of a 1st-generation glass ship missing "huge
areas"
of
gelcoat atop both wings...meaning, UV CAN directly access the structure.
In
time (years? decades? testing definitely required...) the structure
would
degrade to where strength reduction would become measurably detectable.
That
said, I've never seen such a "structure-exposed" ship since first
setting
eyes
on a composite sailplane in 1972.
If you happen to know of or own such a ship, simply spraying a UV
barrier
would eliminate the UV issue (though the ship would still look cruddy
and
pay
an aerodynamic penalty from surface roughness).
My conclusion is "the UV concern" is in fact a non-issue with the
slightest
application of common sense.
My bottom line?
If it's good for your soul, limit yourself to, and do your best to
propagate,
crack-free gliders. They ARE beautiful!!!
Meanwhile, take care of any glider you're responsible for to the best of
your
ability...but don't lose sleep over gelcoat cracks you know are not
directly
due to a structural overstress condition.
Anecdotal tale...
Back in the early '90's my Club had a G-103A not get signed off for an
annual
because the (unfamiliar with glass gliders) A&P "got nervous about all
wing cracks." And there were LOTS of them. The small-radii leading edges
had
beaucoup spanwise cracks from root to tip, and, from nose to several
inches
back, on top and bottom. Both spoiler boxes had at each corner long
cracks
radiating well over a foot in length. The remainder of the top surfaces
had
various long, random, straight-to-arcing chordwise cracks bunched in
various
spanwise locations. Both bottom surfaces, from root to nearly tip, had
closely
spaced, mostly straight, chordwise cracks from nearly the leading edge
to
nearly the trailing edge.
JJ explains above why spoiler box corners typically radiate cracks. The
differences between top and bottom surface chordwise cracks were likely
due
to
the undersurface being mostly in tension vs. compression for the top
gelcoat.
The leading edge cracks were likely a result of gelcoat and filler being
thicker in that region.
The shop quoted $12K for partial gelcoat-removal/inspect/refinish of the
wings. By the time Club-labor sanded-to-inspection-depth the entire
surfaces
of both wings (unsurprisingly, no "into-resin-cracks" found, anywhere),
shot
on requisite, thin, pin-hole filling polyester "stuff" (I've forgotten
what
it
was, and we later sold that ship for one with a higher payload, despite
it
getting slightly lighter due to our work), and had an auto body shop
shoot
both wings with polyurethane, we had less than $4K into the refinish.
Looked
great. Flew the same. Nary a crack ever showed through the polyurethane.
Again, YMMV. Written from the perspective of someone who believes
information
trumps FUD...
Bob W.
Old July 2nd 12, 01:55 PM posted to rec.aviation.soaring
Terry Walsh
"Probably the worst culprit is the
Grob 102/3
Despite all their other reported issues Grob is famous for having one of
the more durable Gel coats Don.
Terry Walsh
Grob 102/3
John F
full
spar
cracks
in
an
and
a
news,
layer
of
remember
It
every
and
my
mold,
all
box.
The
quite
cloth
coating,
40
JJ
if
it
(FULL
structural-analysis
ships,
compared
observation,
materials
The
there
in
various
with
"the
had
more
vinyl
bar
underneath
paint
you're
film,
then
present
runs
un-coated
because
to
(UV
important
to
you...
gel-coat
only
accordingly.
exterior
ONLY
performance
sale
out
ever
differences
and
relative
structure's
protective coating.
1)
a
life-threatening
to Joe PIC.
encased
can
don't
5)
stiffness
glider
sense,
somewhere
Even
to
crack
read
JJ
well-known
Further
he
degradation...as
routine
experience
in this matter.
areas"
of
structure.
In
would
That
setting
eyes
barrier
and
pay
slightest
My bottom line?
propagate,
of
your
directly
Anecdotal tale...
annual
edges
had
inches
cracks
had
various
closely
to
due
to
gelcoat.
being
surfaces
shot
what
it
it
shoot
Looked
polyurethane.
information
trumps FUD...
Bob W.
Old July 2nd 12, 03:41 PM posted to rec.aviation.soaring
Grider Pirate[_2_]
Grob 102/3
Terry Walsh
Grob 102/3
John F
full
spar
cracks
in
an
and
a
news,
layer
of
remember
DG-400 at Minden, that had been flown extensively in wave conditions..
It
every
and
my
mold,
all
box.
The
quite
cloth
coating,
40
JJ
if
it
(FULL
structural-analysis
ships,
compared
observation,
materials
The
there
in
various
with
"the
had
more
vinyl
bar
underneath
paint
you're
film,
then
present
runs
un-coated
because
to
(UV
important
to
you...
gel-coat
only
accordingly.
exterior
ONLY
performance
sale
out
ever
differences
and
relative
structure's
protective coating.
1)
a
life-threatening
to Joe PIC.
encased
can
don't
5)
stiffness
glider
sense,
somewhere
Even
to
crack
read
JJ
well-known
Further
he
degradation...as
routine
experience
in this matter.
areas"
of
structure.
In
would
read more »- Hide quoted text -
- Show quoted text -
Yup. Grob gelcoat seems to be about the best I've seen. I'm partner
in a Janus C that had gelcoat literally blowing off of the top of the
wing. The bond had failed so completely that I didn't sand the
remaining gelcoat off, I SCRAPED/CHIPPED it off using a pnuematic
scraper (see the terrifying video on YouTube "Removing Failed Gelcoat")
(sorry, I can't provide a link right now). 5 gallons of PCL
PolyPrimer, lots of sanding, and gallons of PPG concept, followed by
more sanding and buffing. If it still looks good in 5 years, I'll
declare victory.
Old July 3rd 12, 01:58 AM posted to rec.aviation.soaring
Papa3[_2_]
I suspect any reputation regarding Grob gelcoat might have to do with the fact that so many of them are tied out all year long in harsh climates. Interestingly, there was a HUGE difference in the amount of gelcoat damage on my recent Grob refinish project between the SW side (sunny side) and NE side (shady side) of the fuselage. The glider is tied outside with the left side subject to sun pretty much all day, while the right side is not. Sunny side gelcoat was crazed in all directions, while shady side crazing was limited to fine lines in the direction of the finish sanding.
P3
Grob 102/3
Terry Walsh
declare victory.
Old July 3rd 12, 03:09 AM posted to rec.aviation.soaring
P3
BUT- If it had not originally been done in Scwhabelack it would be much worse.
Grobs surive abuse much better than most other types.
UH
Old July 4th 12, 11:34 PM posted to rec.aviation.soaring
Steve
On Jul 2, 7:58*pm, Papa3 wrote:
I suspect any reputation regarding Grob gelcoat might have to do with the fact that so many of them are tied out all year long in harsh climates. *Interestingly, there was a HUGE difference in the amount of gelcoat damage on my recent Grob refinish project between the SW side (sunny side) and NE side (shady side) of the fuselage. * *The glider is tied outside with the left side subject to sun pretty much all day, while the right side is not. * Sunny side gelcoat was crazed in all directions, while shady side crazing was limited to fine lines in the direction of the finish sanding.
P3
Grob 102/3
Terry Walsh
Yup. *Grob gelcoat seems to be about the best I've seen. *I'm partner
wing. *The bond had failed so completely that I didn't sand the
(sorry, I can't provide a link right now). *5 gallons of PCL
more sanding and buffing. *If it still looks good in 5 years, I'll
declare victory.
Has anyone looked into using the vehicle wraps (3M) instead of paint?
They seem to last OK on cars, trailers and boats. Would that be a
cheaper alternative?
Gel Coat Cracks or is it worse? [email protected] Soaring 13 June 30th 12 09:41 PM
Jim Payne Cracks 1,072 Miles! [email protected] Soaring 3 March 28th 08 10:32 PM
RV-4 Cracks guynoir Home Built 3 May 29th 04 07:29 AM
Large cracks have been found...Navy SH-2G Carlo Rotorcraft 1 November 26th 03 05:51 AM
Cessna 182: How can I fix cracks in tailcone bulkhead? Robert Bullock Owning 2 September 26th 03 08:43 PM
