My Mistake! Sent Email to LXNAV and received rapid response from Uros to check NAV page on V7. The 'Use GPS Data' box was unchecked, which removed the GPS status indicator. Interestingly, the NMEA data was still being passed normally through V7 to OUDIE.
I have received very rapid email support from LXNAV whenever I have sent a message to them. Excellent support. Sorry to add to any confusion out there. |
I am having difficulties getting to like my V7
There are so many settings its a bit of a jungle.Aand changes only get saved if you remember to power it down using the knob (why?). So, many of my settings changes get lost as I forget, and just kill the power after landing. If you try and save your changes in the air then MC, bugs, ballast, altitude etc get lost so that is a no-no unfortunately This also means that you cannot pre-setup stuff like ballast on the grid and then power down to save batteries. This is really annoying cos the workload in a glider is so high these days that it is important to get as much stuff out the way as possible The V2.00 firmware upgrade wiped all my settings so now I am doing it again (doh!). I have no idea what it changed/fixed cos there is no release notice. But it took me a while before it finally sunk in that selecting thermal flaps was now putting the V7 into cruise mode! (fixed after finding the correct config setting eventually) The power down using the knob takes forever (after you have done it a few times). Firstly you have to hold it down for a few seconds and *then* it wants me to keep pushing for 3 more before shutting down....zzzz I miss a polar degradation setting. I know I can do it with Bugs but I want it permanent. So, I have selected an inferior glider from the list of polars, which is good enough I suppose, but it realy should be handled better. I miss a volume setup which changes the vario volume automatically with airspeed. It is 2012 and I am still having to adjust the volume in different phases of the flight! I want to see the glider battery voltage - in volts eg 12.3 . I have a Redbox, V7, Becker AR6201 and XCSoar onboard all with digital displays and yet I still cant see the voltage without compromising. Either I use 1 of the V7s configurable number fields (which I would rather to use for something else) or keep the Becker in 1 of its 3 modes. V7 - please display the volts in a dedicated field. I probably just need to tweak the settings some more, but I am having a hard time geting the V7 to behave somewhat like my old 302. (the 302 had its own issues of course) The averager number seems to be updated on a timer (say every 0.2sec). So it often jumps from value to value, missing some intermediate values. I believe this is wrong. I want to see all intermediate values as well to get a trend feeling. This should work OK since it is a time averaged value and so changes fairly slowly. In contrast, the push/pull diamonds on the right dance up down like a break dancer and really need to be filtered a bit more. Its a pity the V7 cannot offer a backup navigation facility a bit more advanced then the current "take me home functionality". If my Android PDA gives up the ghost then it would be nice to be able to continue round the task using the V7. I have a Redbox supplying NMEA to the V7. Why cant I put a WP list in the RB and select GOTOs from the V7. Or perhaps the V7 sniffs the declaration. OK, this is a bit more advanced wish. But it would be really great Could someone post a good Vario and Display setup for the V7 for flying tasks. What do you configure the Needle, number fields, etc for cruise and climb. I know somethings are a matter of taste, but others are must haves. What are your must haves? phase Cruise Climb needle netto vario big number ? average vario small number altitude altitude averager 20 sec smart filter ? other important settings? etc Peter |
On Monday, July 2, 2012 5:51:03 PM UTC-4, Rhubarb wrote:
There are so many settings its a bit of a jungle.Aand changes only get saved if you remember to power it down using the knob (why?). Because the idea is to set it up once (while on the ground) rather than to mess with the settings in flight. MC, bugs, ballast, altitude etc get lost so that is a no-no unfortunately I agree, these things should be saved. I think that ground elevation will be saved eventually - I suggested that and LXNAV seemed OK with that idea. This also means that you cannot pre-setup stuff like ballast on the grid and then power down to save batteries. Yes. Tell LXNAV. They're quite responsive. I miss a polar degradation setting. Me too. I miss a volume setup which changes the vario volume automatically with airspeed. It is 2012 and I am still having to adjust the volume in different phases of the flight! +1 I want to see the glider battery voltage - in volts eg 12.3 . There will be something like that in a future version (on a separate screen). Its a pity the V7 cannot offer a backup navigation facility a bit more advanced then the current "take me home functionality". Actually, if your GPS source sends waypoint coordinates, then the V7 will navigate to those. A Volkslogger with a task declaration would do this, for instance. That said, I don't waste the display on NAV data. On a separate screen (easy to get to), sure. And that's actually something that I think might happen in the near future. D |
Just an FYI for my fellow v7 users regarding updates....when the manual says use the 115k baud rate to do the update, it really means it!
I update my v7 via my Oudie, which I had set at a baud of 19k, along with the Nano I use as a FR. Since they were all talking nice to each other, I figured to not rock the boat and attempted to do the 2.00 update at the lower speed rate figuring it might just take a bit longer. Bad plan on my part....here's what I found out. The first of the 2 firmware files updated w/o a hitch, but the 2nd update didn't seem to be installing properly. Be advised you are apparently performing two "separate" updates when performing these...the first one is for the v7 and another file upgrades the vario indicator itself. If you look on the v7's "about" page, you'll see two different lines detailing what firmware each of these separate items is running. After attempting at the low baud rate, I had one line reading "1.96" and another reading "2.00"...when both should have read "2.00". I finally gave up trying to preserve my settings, did the upgrade at the 115k rate and it went off w/o a hitch...after which I was able to get everything talking to each other again. As to the up thread discussion on a nav option with the v7, I have mulled over the idea of getting a Colibri II FR in lieu of using my Nano. It has all the FR capabilities of the Nano with the added bonus of being a rudimentary nav system with a display were the primary to croak. Rob |
On Tuesday, July 10, 2012 12:54:19 PM UTC-5, RAS56 wrote:
Just an FYI for my fellow v7 users regarding updates....when the manual says use the 115k baud rate to do the update, it really means it! I update my v7 via my Oudie, which I had set at a baud of 19k, along with the Nano I use as a FR. Since they were all talking nice to each other, I figured to not rock the boat and attempted to do the 2.00 update at the lower speed rate figuring it might just take a bit longer. Bad plan on my part....here's what I found out. The first of the 2 firmware files updated w/o a hitch, but the 2nd update didn't seem to be installing properly. Be advised you are apparently performing two "separate" updates when performing these...the first one is for the v7 and another file upgrades the vario indicator itself. If you look on the v7's "about" page, you'll see two different lines detailing what firmware each of these separate items is running.. After attempting at the low baud rate, I had one line reading "1.96" and another reading "2.00"...when both should have read "2.00". I finally gave up trying to preserve my settings, did the upgrade at the 115k rate and it went off w/o a hitch...after which I was able to get everything talking to each other again. As to the up thread discussion on a nav option with the v7, I have mulled over the idea of getting a Colibri II FR in lieu of using my Nano. It has all the FR capabilities of the Nano with the added bonus of being a rudimentary nav system with a display were the primary to croak. Rob Rob, I think you need to go ahead and get the Colibri II and then donate the unneeded Nano to one of the student pilots at your home field... ![]() Robert |
![]() Rob, I think you need to go ahead and get the Colibri II and then donate the unneeded Nano to one of the student pilots at your home field... ![]() Robert Hey Robert, think so? ;-) There's no doubt that that Colibri is a nifty looking piece of gear, definitely worth a closer look in the off season...could maybe work a deal with you for the Nano then if you're interested. Then again, I'm running into more and folks that fly with multiple loggers "just in case"... Get that PPL out of the way and then start making plans to come up to Dalhart with us next year! Regards, Rob S. ZAP |
LXNAV V7 - Reviews? | David Reitter | Soaring | 10 | October 21st 14 12:41 AM |
New LXNAV LX9000 Overview Video | Paul Remde | Soaring | 0 | April 21st 12 01:33 AM |
LXNAV V7 | Paul Remde | Soaring | 2 | November 2nd 11 12:31 AM |
LXNAV Nano and LX 9000 Overview Videos Available | Paul Remde | Soaring | 3 | February 28th 11 01:58 PM |
HELP! Need offical Blanik L-13 Canopy Strap | John Scott | Soaring | 4 | March 3rd 08 05:03 AM |
