Just an FYI for my fellow v7 users regarding updates....when the manual says use the 115k baud rate to do the update, it really means it!
I update my v7 via my Oudie, which I had set at a baud of 19k, along with the Nano I use as a FR. Since they were all talking nice to each other, I figured to not rock the boat and attempted to do the 2.00 update at the lower speed rate figuring it might just take a bit longer. Bad plan on my part....here's what I found out. The first of the 2 firmware files updated w/o a hitch, but the 2nd update didn't seem to be installing properly. Be advised you are apparently performing two "separate" updates when performing these...the first one is for the v7 and another file upgrades the vario indicator itself. If you look on the v7's "about" page, you'll see two different lines detailing what firmware each of these separate items is running. After attempting at the low baud rate, I had one line reading "1.96" and another reading "2.00"...when both should have read "2.00". I finally gave up trying to preserve my settings, did the upgrade at the 115k rate and it went off w/o a hitch...after which I was able to get everything talking to each other again. As to the up thread discussion on a nav option with the v7, I have mulled over the idea of getting a Colibri II FR in lieu of using my Nano. It has all the FR capabilities of the Nano with the added bonus of being a rudimentary nav system with a display were the primary to croak. Rob |
On Tuesday, July 10, 2012 12:54:19 PM UTC-5, RAS56 wrote:
Just an FYI for my fellow v7 users regarding updates....when the manual says use the 115k baud rate to do the update, it really means it! I update my v7 via my Oudie, which I had set at a baud of 19k, along with the Nano I use as a FR. Since they were all talking nice to each other, I figured to not rock the boat and attempted to do the 2.00 update at the lower speed rate figuring it might just take a bit longer. Bad plan on my part....here's what I found out. The first of the 2 firmware files updated w/o a hitch, but the 2nd update didn't seem to be installing properly. Be advised you are apparently performing two "separate" updates when performing these...the first one is for the v7 and another file upgrades the vario indicator itself. If you look on the v7's "about" page, you'll see two different lines detailing what firmware each of these separate items is running.. After attempting at the low baud rate, I had one line reading "1.96" and another reading "2.00"...when both should have read "2.00". I finally gave up trying to preserve my settings, did the upgrade at the 115k rate and it went off w/o a hitch...after which I was able to get everything talking to each other again. As to the up thread discussion on a nav option with the v7, I have mulled over the idea of getting a Colibri II FR in lieu of using my Nano. It has all the FR capabilities of the Nano with the added bonus of being a rudimentary nav system with a display were the primary to croak. Rob Rob, I think you need to go ahead and get the Colibri II and then donate the unneeded Nano to one of the student pilots at your home field... ![]() Robert |
![]() Rob, I think you need to go ahead and get the Colibri II and then donate the unneeded Nano to one of the student pilots at your home field... ![]() Robert Hey Robert, think so? ;-) There's no doubt that that Colibri is a nifty looking piece of gear, definitely worth a closer look in the off season...could maybe work a deal with you for the Nano then if you're interested. Then again, I'm running into more and folks that fly with multiple loggers "just in case"... Get that PPL out of the way and then start making plans to come up to Dalhart with us next year! Regards, Rob S. ZAP |
LXNAV V7 - Reviews? | David Reitter | Soaring | 10 | October 21st 14 12:41 AM |
New LXNAV LX9000 Overview Video | Paul Remde | Soaring | 0 | April 21st 12 01:33 AM |
LXNAV V7 | Paul Remde | Soaring | 2 | November 2nd 11 12:31 AM |
LXNAV Nano and LX 9000 Overview Videos Available | Paul Remde | Soaring | 3 | February 28th 11 01:58 PM |
HELP! Need offical Blanik L-13 Canopy Strap | John Scott | Soaring | 4 | March 3rd 08 05:03 AM |
