Socket Mobile Battery/Charger
Old July 29th 12, 01:45 AM posted to rec.aviation.soaring
Dan Marotta
Default Socket Mobile Battery/Charger
Possibly, but it depends on the device that's feeding the socket. For
example, My Cambridge 302 outputs 5v on the serial line but only 500mA (so
I'm told). It is not enough to charge my Dell Streak 5 - only enough to
slow down the discharge. To remedy that situation, I modified a car charger
intended for mobile GPS or cell phones (5.17v output) and connected it
directly to my ship's DC bus (with a fuse and on/off switch, of course). It
will charge the Streak in flight very quickly.
I'd suggest you do likewise. Get a car charger that puts out 5v and a USB
extender cable. Cut the cable and connect the red and black wires to +
and - respectively. It'll supply what you need.
"John" wrote in message
I'm not sure if this can support it or not so I'm asking:
Can you plug a USB adapter into the Socket and charge multiple USB devices
into the Socket for charging simultaneously? (for example: Socket-4USB
Adaptor-2 Phones
thanks,
John
Old July 29th 12, 03:34 PM posted to rec.aviation.soaring
Dan Marotta
.... Or modify something like this:
http://stuntcams.com/shop/gopro-char...ter-p-173.html
Open it up and attach red and black wires to the appropriate terminals (it
should be apparent) and use a panel mounted switch to connect/remove ship's
power. It should also have an internal fuse which will be obvious when you
open it. If not, use an inline fuse of 5 amps or so.
Or... you could wire in a cigarette lighter adaptor and simply plug the
thing in. It will easily feed two devices through a splitter.
"Dan Marotta" wrote in message
charger intended for mobile GPS or cell phones (5.17v output) and
connected it directly to my ship's DC bus (with a fuse and on/off switch,
of course). It will charge the Streak in flight very quickly.
devices into the Socket for charging simultaneously? (for example:
Socket-4USB Adaptor-2 Phones
thanks,
John
Old July 29th 12, 03:44 PM posted to rec.aviation.soaring
Dan Marotta
....Or this:
http://www.getusb.info/review-usb-car-adapter-charger/
It looks to me like the end cap of this one will come off and mount directly
to your panel giving you two USB power ports. How simple is that?
ship's power. It should also have an internal fuse which will be obvious
when you open it. If not, use an inline fuse of 5 amps or so.
(so I'm told). It is not enough to charge my Dell Streak 5 - only enough
to slow down the discharge. To remedy that situation, I modified a car
USB extender cable. Cut the cable and connect the red and black wires to
+ and - respectively. It'll supply what you need.
thanks,
John
Basic battery charger question RS Soaring 5 March 19th 12 03:03 AM
Battery Charger [email protected] Soaring 5 February 5th 07 06:41 AM
Jim Weir - desulfating battery charger Ernest Christley Home Built 5 December 21st 06 10:28 PM
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 01:19 AM
12 Volt DC input Battery Charger Michael I Green Soaring 5 March 14th 04 08:41 AM
