Socket Mobile Battery/Charger
Old July 29th 12, 02:16 AM posted to rec.aviation.soaring
Default Socket Mobile Battery/Charger
I have personally had success in plugging two low current devices in to a Socket Power Pack. I used a USB- 3 Outlet Splitter. Everything worked fine until I plugged in something with a higher current draw, then the splitter turned off and acted like it had been unplugged. Once I unplugged it and then plugged it back in, the two low draw devices worked fine. I think the limitation is mainly in the type of USB splitter that you use.
The two devices that I had were the NANO and the Collibri II. They worked fine together. Once I plugged in my phone (XC SOAR) it had issues and nothing got external power.
Basic battery charger question RS Soaring 5 March 19th 12 03:03 AM
Battery Charger [email protected] Soaring 5 February 5th 07 06:41 AM
Jim Weir - desulfating battery charger Ernest Christley Home Built 5 December 21st 06 10:28 PM
RG Battery Charger by Jim Weir in Kitplanes Kevin O'Brien Home Built 4 January 6th 05 01:19 AM
12 Volt DC input Battery Charger Michael I Green Soaring 5 March 14th 04 08:41 AM
