Open Class Super-Ship from Windward Performance
Old August 3rd 12, 05:29 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Open Class Super-Ship from Windward Performance
On Aug 3, 8:48*am, Tony wrote:
how affordable is affordable?
It's designed to hit $100,000 in 2010 dollars. That includes
convertible gear (nose roller and tail dragger), basic instruments,
removable nose and tail ballast, and open trailer.
type certified or kit built?
Type certificated and built in series production. An experimental
glider of this size and shape would be economically and socially
unviable. This is a workhorse designed for operationality and
transposition rate, and engineered for ease of repair using common
composite materials.
There is also the ethical concern of carrying people who have not
necessarily made an informed decision to ride in a non-type-
certificated aircraft. I think that they deserve an aircraft that has
been tested to a higher standard than the typical kit aircraft.
going to be opening an engineering office in Wichita???
I hadn't thought of that. Didn't they used to make airplanes there?
Thanks, Bob K.
Old August 3rd 12, 06:00 PM posted to rec.aviation.soaring
Bob,
Why not LSA?
Marc
Old August 3rd 12, 06:06 PM posted to rec.aviation.soaring
Bob Kuykendall
On Aug 3, 10:00*am, wrote:
Why not LSA?
Marc, that's a good question. I think that by the time you develop an
aircraft that meets the LSA requirements, the extra effort to go to
Part 23 TC is not all that great. And the benefits are much greater
gross weight and no smoke-and-mirrors VNE. But I could be convinced
otherwise.
Thanks, Bob K.
Old August 3rd 12, 06:08 PM posted to rec.aviation.soaring
Tony[_5_]
On Friday, August 3, 2012 12:06:01 PM UTC-5, Bob Kuykendall wrote:
On Aug 3, 10:00*am, wrote: Why not LSA? Marc, that's a good question. I think that by the time you develop an aircraft that meets the LSA requirements, the extra effort to go to Part 23 TC is not all that great. And the benefits are much greater gross weight and no smoke-and-mirrors VNE. But I could be convinced otherwise. Thanks, Bob K.
there are export advantages to not being LSA...as Cessna has learned with the Skycatcher, with which they are pursuing Primary category certification so it can get certified overseas. Yes I expect you to be supplying the european market with trainers in 10 years
This will be the HP-48???
Old August 3rd 12, 08:12 PM posted to rec.aviation.soaring
Bob Kuykendall
The project name is currently "Aurora," for reasons I'll get into
another time. There is as yet no aircraft name or designation.
Thanks, Bob K.
Old August 3rd 12, 08:17 PM posted to rec.aviation.soaring
Bob Kuykendall
Currently it only has the project name "Aurora," for reasons I'll get
into later. There is as yet no aircraft type or designation for it.
Old August 3rd 12, 06:05 PM posted to rec.aviation.soaring
Tony[_5_]
On Friday, August 3, 2012 11:29:52 AM UTC-5, Bob Kuykendall wrote:
On Aug 3, 8:48*am, Tony wrote: how affordable is affordable? It's designed to hit $100,000 in 2010 dollars. That includes convertible gear (nose roller and tail dragger), basic instruments, removable nose and tail ballast, and open trailer. type certified or kit built? Type certificated and built in series production. An experimental glider of this size and shape would be economically and socially unviable. This is a workhorse designed for operationality and transposition rate, and engineered for ease of repair using common composite materials. There is also the ethical concern of carrying people who have not necessarily made an informed decision to ride in a non-type- certificated aircraft. I think that they deserve an aircraft that has been tested to a higher standard than the typical kit aircraft. going to be opening an engineering office in Wichita??? I hadn't thought of that. Didn't they used to make airplanes there? Thanks, Bob K.
Cool and Cool
You could always put a bid in for Hawker Beechcraft...get a nice 7000 ft runway, some big ovens for composites curing, and plenty of employees
Old August 3rd 12, 07:14 PM posted to rec.aviation.soaring
Just because it is a kit aircarft, Homebuilt, dose'nt mean it has not been tested. All of Windwards aircraft are tested to part 21 standards and beyond the reason for not certifing in the Standard Catagory is cost. With this thinking Bob there must be a lot of unethical people out there flying experimental aircraft, or the EAA is unethical, or building your own airplane is unethical, or you must be a left wing tree hugger to be flying that, what an electric airplane, you fly an experimental aircraft you must be a socialist.
John
Old August 3rd 12, 07:17 PM posted to rec.aviation.soaring
Tony[_5_]
On Friday, August 3, 2012 1:14:15 PM UTC-5, (unknown) wrote:
On Friday, August 3, 2012 9:29:52 AM UTC-7, Bob Kuykendall wrote: On Aug 3, 8:48*am, Tony wrote: how affordable is affordable? It's designed to hit $100,000 in 2010 dollars. That includes convertible gear (nose roller and tail dragger), basic instruments, removable nose and tail ballast, and open trailer. type certified or kit built? Type certificated and built in series production. An experimental glider of this size and shape would be economically and socially unviable. This is a workhorse designed for operationality and transposition rate, and engineered for ease of repair using common composite materials. There is also the ethical concern of carrying people who have not necessarily made an informed decision to ride in a non-type- certificated aircraft. I think that they deserve an aircraft that has been tested to a higher standard than the typical kit aircraft. going to be opening an engineering office in Wichita??? I hadn't thought of that. Didn't they used to make airplanes there? Thanks, Bob K. Just because it is a kit aircarft, Homebuilt, dose'nt mean it has not been tested. All of Windwards aircraft are tested to part 21 standards and beyond the reason for not certifing in the Standard Catagory is cost. With this thinking Bob there must be a lot of unethical people out there flying experimental aircraft, or the EAA is unethical, or building your own airplane is unethical, or you must be a left wing tree hugger to be flying that, what an electric airplane, you fly an experimental aircraft you must be a socialist. John
interesting...
I agree with Bob though, for a 2 seater to be successful as a trainer it really needs to be type certified, for many reasons including the ones that Bob points out.
Old August 3rd 12, 08:10 PM posted to rec.aviation.soaring
Bob Kuykendall
On Aug 3, 11:14*am, wrote:
* Just because it is a kit aircarft, Homebuilt, dose'nt mean it has not been tested...
Oh, yeah, I get that. Been there, done that, got the T-shirt:
http://hpaircraft.com/hp-24/update_10_dec_11.htm
That last run-on sentence makes the grammar a bit difficult to parse,
but I'll take a crack at it:
I didn't mean that those who develop, build, and operate non-
certificated multiplace aircraft are unethical. In fact, I have been
one of those people, and probably will be again.
I just happen to think that developing and testing multiplace aircraft
to a higher standard than single place aircraft has value for ethical
reasons that I have already stated: They often carry people who have
not made, and are perhaps not qualified to make, an informed decision
to ride in the machine. Therefore, the designer and builder hold an
increased obligation to protect the uninformed from the possible
consequences of such activity. Also, I happen to think, for a variety
of reasons outside the scope of this particular discussion, that this
is a bit more important for sailplanes than for powered aircraft.
I think that once you execute on this obligation to a degree
commensurate with what is at stake, you are about 90% of the way to
certification, so you might as well finish it off.
I have incredible respect for those who fought for and won our
privilege of building and operating amateur-built aircraft, and I have
a great deal of respect for the responsibility that is bound to it. I
think that the EAA is doing a good job of providing guidance and
protection for those who choose to exercise this privilege.
However, there have indeed been a few unethical people in experimental
aviation, and the sport has suffered mightily for it on occasion.
Folks who took deposits and returned only empty promises. Folks who
designed structurally inadequate aircraft that broke before even
reaching limit load. I intend to avoid, by whatever practical means,
being one of those people.
And, for the record, I am indeed a tree-hugging liberal, though not in
the strictest sense a socialist. More along the lines of a social
engineering-ist.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com
Should SSA Regional contests allow water in FAI class...15, 18, 20,Open class? Sean Fidler Soaring 25 December 16th 11 02:14 PM
52/1 Performance in a 15M ship at half the weight. SF Soaring 48 March 1st 09 06:24 PM
Intersted in Std Class Ship for Nationals in Uvalde Bill Elliott Soaring 0 April 10th 06 03:16 PM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
Super Cub towplane performance Marc Arsenault Soaring 1 July 11th 03 01:42 PM
