Avoid head-on collision? Forward facing LED strobe?
Old August 15th 12, 10:24 PM posted to rec.aviation.soaring
son_of_flubber
Default Avoid head-on collision? Forward facing LED strobe?
On Wednesday, August 15, 2012 4:52:11 PM UTC-4, BobD wrote:
It would be cool if you could interface it to the PowerFlarm and have it activate only when PF detected an aircraft within a mile of you.
Or you could keep the blink rate low until you visually see another glider, then boost the frequency and intensity. If both gliders had this feature, it would confirm when the other glider has you in sight.
One recurrent problem with a glider approaching head on is that you cannot read the tail number to give him a heads up on the radio. I guess you could always say "Glider approaching head-on" to get his attention. What would be a good "heads-up" radio call in this situation?
Strobe and nav led CGH Home Built 4 April 9th 10 03:32 AM
Glider Video Facing Backwards [email protected] Soaring 5 November 25th 08 02:59 AM
Some airmen facing longer deployments Otis Willie Military Aviation 0 January 16th 04 08:34 PM
