Someone please correct me if I am wrong, but what I came up with is that you need the special cable and 3.3V power supply to upload the flarmnet file the butterfly display for the Brick version. Supposeably the next version of firmware for the flarm will allow you to put the flarmnet file on your thumb drive and insert it into the Flarm, The flarm will then transfer the file to the butterfly display.
I decided to just wait for the new firmware, if that doesn't happen I may look into making the cable to upload to the butterfly display. Brian |
Yes, that's correct.
The special cable is easy to manufacture from 2 boards, in case you want to go that route until the new firmware allows display updates through the USB stick. See here for my cable. https://sites.google.com/site/threeu...terfly-display 3U |
Having just installed the Core with the BF display I can share that it is absurd.
1. I have tried several USB sticks trying to update firmware but I don't think it is updating. 2. There is also no way to confirm that the setup actually set up. So is it working or not? 3. The entire Hex conversion process could be so much better but what you get from the manual is a lot of arrogant blather. (FCC stupid, Microsoft stupid, Power Flarm creators are genius, hex is your problem because PowerFlarm geniuses can't be bothered, etc.) 4. inscrutable operating manual. |
On Saturday, August 25, 2012 10:53:42 PM UTC-7, brianDG303 wrote:
2. There is also no way to confirm that the setup actually set up. So is it working or not? It is easy to see if the parameters specifications that you uploaded has been accepted by the brick. Include this command in you config file: $debug_out,fat,scheduler|config|baro|rf|gps|pffsm, all After power up has completed wait a couple of minutes then remove the USB device. Plug the USB device into a computer and open the file PFCxxxxx.txt (where xxxxx is the serial number of your brick) with a text editor. Don't look for the file by date as the file date defaults to Jan 2010. The configuration data is all there for your enjoyment. Regarding HEX/Octal etc - There are 10 types of people in this world, those that understand binary and those that don't. Andy, GY |
On Sunday, August 26, 2012 11:53:49 AM UTC-7, Andy wrote:
On Saturday, August 25, 2012 10:53:42 PM UTC-7, brianDG303 wrote: 2. There is also no way to confirm that the setup actually set up. So is it working or not? It is easy to see if the parameters specifications that you uploaded has been accepted by the brick. Include this command in you config file: $debug_out,fat,scheduler|config|baro|rf|gps|pffsm, all After power up has completed wait a couple of minutes then remove the USB device. Plug the USB device into a computer and open the file PFCxxxxx.txt (where xxxxx is the serial number of your brick) with a text editor. Don't look for the file by date as the file date defaults to Jan 2010. The configuration data is all there for your enjoyment. Regarding HEX/Octal etc - There are 10 types of people in this world, those that understand binary and those that don't. Andy, GY Hi Andy, I appreciate your response, it is very helpful. Question, can you clarify the following instruction from the CONFIG file: # Write a debug log file to micro-SD card during flight. # Brick ignores this if you remove USB stick (you must remove USB stick # for flight) $debug_out,fat,scheduler|config|baro|rf|gps|pffsm, all I am having a difficult time understanding "Brick ignores this if you remove USB stick (you must remove USB stick for flight)" because that seems to say you have to have the stick in and the stick out during the flight. ?? Also a suggestion. An instruction in the CONFIG file says: # Find your aircraft's "Mode S code". # Unfortunately, FAA gives it in "Octal" notation. # Since the late 1970's nobody in the world uses Octal. Except FAA. # So, we didn't program Octal input support. # So, you need to convert the FAA's foolish Octal into hex: # - In LibreOffice, use the conversion function =OCT2HEX(0751243) # - In Microsoft Excel, Tools AddIns enable Analysis Toolpak, # and then use =OCT2HEX as in LibreOffice (its always harder # with Microsoft - "Where do you want to waste time today ?"). OK, so I don't have LibreOffice and my version of Excel doesn't have the Toolpak. It took a bit longer to find a converter online than one would expect, but here is an example, perhaps PF-USA could just mention it or link to it from their website: http://www.digitconvert.com/ Again, thanks for your help, I'll give it a try. Brian |
On Sun, 26 Aug 2012 15:59:40 -0700 (PDT), brianDG303
wrote: ..... long reference deleted OK, so I don't have LibreOffice and my version of Excel doesn't have the Toolpak. It took a bit longer to find a converter online than one would expect, but here is an example, perhaps PF-USA could just mention it or link to it from their website: http://www.digitconvert.com/ Again, thanks for your help, I'll give it a try. Brian Recall the post from Dan Daly a few message earlier in this thread. A much easier route to your Mode S code in hex format. =========== First two steps can be combined if you use http://www.avionictools.com/icao.html; this gives both hex and octal (dunno why you'd need the octal for FLARM) addresses directly for N- and C- registrations. Stuff that into your PF - which you have to configure anyway to tell it it's in a glider - and register it on FLARMnet. Took a few seconds for me today. Now, if I could only figure out where to put the flarmnet file for it to read into my Brick... Dan ========= |
On Sunday, August 26, 2012 6:10:13 PM UTC-7, Bob Gibbons wrote:
Now, if I could only figure out where to put the flarmnet file for it to read into my Brick... The Brick doesn't care about flarmnet. You can't load the flarmnet file to the brick. It is the display device that uses the flarmnet file. I have posted instructions on loading the Butterfly display with flarmnet in the flarmnet thread. The documentation seems to suggest that loading the flarmnet file to the display from the brick usb port will be supported in the future. The Butterfly remote display is also plug and play compatible with the portable and can provide flarmnet support for that device. BTW anyone with a Windows PC has an Octal to Hex converter. Just open the supplied calculator in scientific view. Select Oct, enter the octal ICAO address, press HEX, read the HEX address. Andy, GY |
On Aug 25, 10:36*pm, wrote:
See here for my cable.https://sites.google.com/site/threeu...terfly-display 3U Damn, that's complicated. No wonder people are shying away from doing this. All you need is a scrap 4 wire telephone lead, a 7pin D Sub connector and a couple of AA cells. If you want to take the power from the brick then add an RJ-11 coupler and use the supplied RJ-45 / RJ-11 cable. Even if your computer doesn't have a legacy serial port most pilots probably have a USB to serial dongle to support their other toys. The display data output is +/- approx 5 volts and the input accepts the signal from a standard serial port. Butterfly display manual indicates direct connection to the PC serial port is acceptable. I made my cable more complicated by providing the abilty to switch the display data lines between the PC port and the Brick but that's not needed. A similar simple cable, without the power source, can be used to talk to the brick using a standard PC terminal emulation program. Andy GY |
On Aug 29, 9:21*am, Andy wrote:
All you need is a scrap 4 wire telephone lead, a 7pin D Sub connector and a couple of AA cells. 9 pin of course. - I hope I fly better than I type. |
contest number question | Gary Emerson | Soaring | 22 | February 9th 18 04:15 PM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
PowerFLARM | Paul Remde | Soaring | 9 | November 6th 10 04:30 AM |
Contest Number Removal | Roy Bourgeois | Soaring | 4 | March 31st 07 09:12 PM |
Pitts Number 1 registration number | Mirco | Aerobatics | 3 | December 4th 04 11:50 AM |
