PowerFLARM protocol version 6
Old September 3rd 12, 06:28 PM posted to rec.aviation.soaring
kirk.stant
Default PowerFLARM protocol version 6
I'm playing with my PFB (on ground near big airport) and while I'm getting good Mode A/C/S hits out to 5NM, I have yet to get an ADS-B return. Is there some special setting in the FLARMcfg file that's needed to enable ADS-B?
Also, in the DataportManual v6.00E, it talks about enabling protocol version 6 via the $PFLAC,S,NMEAOUTn,61 command (n=1 for RJ45, n=2 for Dsub9), but it also states that
"Warning: Values = 40 are volatile and not stored in EEPROM. They will revert to (Value modulo 10) at the next powerup or reset. Example: 43 reverts to 3. This is to make sure that no FLARM accidentally runs a recent version of the protocol if a legacy display or other device is connected."
So, my question (finally!) is: Do we need to enable protocol 6, and if we do, is it reset everytime back to the default? Or should we just leave the NMEAOUT command to 1 for both ports 1 and 2?
Fun stuff, kinda...
Kirk
Old September 3rd 12, 06:59 PM posted to rec.aviation.soaring
Dave Nadler
Because of FAA's lame policies and dubious technical decisions
and indecisions, adoption of ADS-B in USA is extremely slow;
well behind other more advanced countries. You won't see much
ADS-B traffic unless you're near a large airport with frequent
international flights to countries more advanced in their ADS-B
implementation.
Sorry to say...
See ya, Dave "YO electric"
Old September 3rd 12, 08:38 PM posted to rec.aviation.soaring
Andy[_1_]
Hi Kirk,
In Glendale I see ADS-B targets but not nearly as many as transponder
alone. A few of the airliners approaching KPHX on the MAIR FIVE show
as ADS-B equipped but most are not. The ADS-B targets I see are
usually arriving/departing KDVT. Not surprising that bizjets would
have it but airliners not. Quite possible that the ADS-B targets I
see out of KDVT are avionics flight test aircraft as there are several
based there.
email me if you want some screen photos.
I know that Boeing recently certified for ADS-B Out on the 777 so
expect the others will tag along slowly.
I'm using the brick and Butterfly display and have not included any
commands for port enabling or activating protocol version 6. I have
pushed put my ADS-B and PCAS altitudes way above the defaults though.
BTW in watching the local traffic I think I've identified 2 potential
software bugs in display ver 3.0 when running in "selection" mode.
1. If a target 3 character identifier is displayed, then that
identifier remains associated with all subsequently displayed targets
until the display (only) is reset.
2. With 2 ADS-B targets and a PCAS target, and the PCAS target being
the selected target, when the PCAS target drops out then no target is
selected. Would have expected one of the remaining ADS-B target to
become selected.
I'll continue to look out for these, although I think I have enough
supporting photos.
Andy
Old September 4th 12, 07:58 AM posted to rec.aviation.soaring
Ramy
Hi Kirk,
based there.
become selected.
supporting photos.
Andy
Andy, I noticed today the same issue as you described in no 1, but mostly with PCAS alerts. In other words, PCAS alert will show the same identifier as the last flarm alert I received hours ago, and that glider was nowhere near me anymore.
Other than that, PCAS seem to work very sporadic, and mostly alerts after the traffic had already passed. Not good.
Is there a place where we can enter bug reports?
Ramy
Ramy
Old September 4th 12, 03:12 PM posted to rec.aviation.soaring
Andy[_1_]
Direct email to either FLARM or Butterfly is the only option I'm aware
of.
Is anyone thinking of setting up a PowerFLARM user group?
Andy GY
Old September 4th 12, 03:14 PM posted to rec.aviation.soaring
kirk.stant
Ok, I finally picked up a couple of ADS-B targets Monday evening - first what appeared to be a bizjet, then an AA (American Airlines?) into STL.
Got the same bug where the ADS-B callsign (AA1) sticks at the bottom of the display after the track is gone. Annoying, but not a big deal.
With my antenna in the car (hanging from the mirror), I'm getting initial PCAS hits at about 3 miles, but they then hang on until reaching the 5 mile PCAS limit set in the config file (9250m). It does seem that the PFB has a delay identifying and displaying PCAS track at first.
On first look, I would say the Butterfly people need to tweak their PCAS display a bit for the US market: the distance ring needs to be thicker (and green if no conflict (above/below), the altitude font needs to be bigger, and it would be nice if there was a digital readout of range on the side.
I would like a single beep when the display changes to show traffic and whenever a new track is displayed, then maybe 3 beeps when traffic gets close enough to be a threat.
Also, a nice enhancement would be the capability to display local time in the center of the display (below the UTC time, in a bigger font) when not on the radar display. Add a config to set UTC offset, and choice of 12 or 24 hour clock. And make that goofy red butterfly smaller!
As previously mentioned in another thread somewhere - it's definitely worth your time to play with this thing on the ground before flying with it - too bad there isn't a simulation mode to show all the various displays.
Kirk
66
Old September 4th 12, 03:34 PM posted to rec.aviation.soaring
Andy[_1_]
On Sep 4, 7:14*am, "kirk.stant" wrote:
Glad you see ADS-B targets now.
re"On first look, I would say the Butterfly people need to tweak their
thicker (and green if no conflict (above/below), "
The PCAS range ring goes red when indicating a conflict. Thanks to
the local helicopter traffic I have photos of that. Trouble is that,
when the conflict exist, the range ring is very small and not very
attention getting. It does not auto scale change and perhaps it
should.
I have also seen the dedicated warning screen for a helicopter
overflight. Maybe that one was ADS-B out equipped. Unfortunately was
not fast enough to get a picture.
To really understand how this display works we either need much better
documentation or a PC based simulator that can drive the display
directly. I'm thinking of setting up a few static test cases but
don't plan on taking on anything more ambitious than that.
Andy (GY)
Old September 4th 12, 06:11 PM posted to rec.aviation.soaring
kirk.stant
On Tuesday, September 4, 2012 9:34:43 AM UTC-5, Andy wrote:
" The PCAS range ring goes red when indicating a conflict. Thanks to the local helicopter traffic I have photos of that. Trouble is that, when the conflict exist, the range ring is very small and not very attention getting."
That's what I'm seeing too. And the red sometimes turns to black after awhile, then becomes red again when it refreshes the target info, apparently.
Bottom line - the warning cues for a near (altitude & slant range) PCAS target are poor at present, but should be fixable.
Hope Butterfly and/or PowerFLARM USA is reading this.
Kirk
66
Old September 5th 12, 05:28 PM posted to rec.aviation.soaring
Brad[_2_]
So, my question (finally!) is: *Do we need to enable protocol 6, and if we do, is it reset everytime back to the default? Or should we just leave the NMEAOUT command to 1 for both ports 1 and 2?
Fun stuff, kinda...
Kirk
Over the weekend I noticed 2 targets showed up on my Portable PF
screen; one was a large triangle with a +99 and the other was a
smaller triangle with just an up arrow next to it. There was no glider
traffic in the area (with PF). I went to the Flarm Screen on my LK8000
and saw the aircraft were cruising about 30,000+ feet. I though
something must be wrong until I looked up and to the NE where there
were 2 sets of contrails basically matching what the info PF was
showing.
It was kinda cool to see this, but do I need to know this kind of
info?
Brad
Old September 5th 12, 05:50 PM posted to rec.aviation.soaring
Andy[_1_]
info?
What do you have the range and altitude limits set to for each target
type? Can't you decide what is displayed and what is not?
Andy (GY)
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
SW developers: FLARM protocol version 6 reminder Dave Nadler Soaring 0 May 24th 12 02:49 PM
Any news on the "brick" version of PowerFlarm from the SSA convention? Andrzej Kobus Soaring 7 February 8th 12 04:29 PM
Bizjet protocol JS Soaring 5 September 4th 06 06:29 AM
