On Sunday, September 2, 2012 11:44:38 AM UTC-7, (unknown) wrote:
When you lift the tip of the main wing panel to pull it out of the trailer, how many pounds are you lifting? And what is the total piece weight of the DD inboard wing panel? Total weight is 215lbs I believe. I haven't ever stepped on a scale while picking up either the wing tip or the root. I'd guess the split is like 130lb/85lb or something like that between the root and the tip. It's heavy, but mostly it is awkward. There is a lot of weight on the trailing edge once you rotate flat. Then for the person at the tip, the height is very high given the dihedral. When Julie and I rig, the tip is at about shoulder height for her. |
On Tuesday, September 4, 2012 1:32:18 AM UTC-4, Morgan wrote:
Total weight is 215lbs I believe. I haven't ever stepped on a scale while picking up either the wing tip or the root. I'd guess the split is like 130lb/85lb or something like that between the root and the tip. It's heavy, but mostly it is awkward. There is a lot of weight on the trailing edge once you rotate flat. That means the hinge-point for the wing-saddle is incorrectly positioned. If the rigging aid is properly designed, there should be almost no rotation force once the wing is ~level. Which unit is this one ? Then for the person at the tip, the height is very high given the dihedral. When Julie and I rig, the tip is at about shoulder height for her. Thanks, Best Regards, Dave |
That means the hinge-point for the wing-saddle is incorrectly positioned. If the rigging aid is properly designed, there should be almost no rotation force once the wing is ~level. Which unit is this one ? Sorry, conflated statements. I was purely speaking to the balance of the Duo wing when manually assembling the glider. The CG is aft of the spar a bit. I also have to make sure when you have extra helpers that they don't lift on the leading edge or on the leading edge side of the handle at the tip. Nothing like trying to manage the root of the wing and then have another 20lbs of torque applied. The reason I would buy the XC version of the wing rigger was in order to ensure proper balance on the rigger. It doesn't meet your requirement for being able to easily adjust the height without going under the wing or crouching. |
Wing assembly dollies | Udo | Soaring | 1 | December 2nd 10 02:51 AM |
USED One person assembly rig | Tim Mara | Soaring | 0 | May 1st 10 03:13 PM |
assembly wing dolly Anoucement | Udo Rumpf[_2_] | Soaring | 2 | January 13th 09 06:53 PM |
Saturn IB S-IB Stage Thrust Structure Assembly at Michoud Assembly Facility 6974931.jpg | [email protected] | Aviation Photos | 0 | April 11th 07 02:45 AM |
USAFE commander: 86th Airlift Wing will divide for combat, support operations | Otis Willie | Military Aviation | 0 | November 27th 03 11:31 PM |
