SeeYou time offset
Old September 9th 12, 06:32 PM posted to rec.aviation.soaring
Greg Arnold
Default SeeYou time offset
I just downloaded version 4.31 (Sept 5, 2012 build). It defaults to a
-17 hour UTC offset, and the time setting adjustment
(Tools/Options/General/UTC Offset) does not work. Anyone else having
this problem?
Old September 9th 12, 09:11 PM posted to rec.aviation.soaring
Wojciech Scigala
this problem?
Maybe it's the wrong value set in your logger? It gets stored in the IGC
file.
To correct UTC offset for an open file, you should change it in flight
properties dialog.
WojtuÅ›
Old September 9th 12, 09:35 PM posted to rec.aviation.soaring
Greg Arnold
this problem?
file.
The time in the file is correct.
properties dialog.
Thanks, the setting in Flight Properties fixes the problem. But then
what is the purpose of the non-working setting in
Tools/Options/General/UTC Offset?
Old September 9th 12, 10:33 PM posted to rec.aviation.soaring
Wojciech Scigala
It should work if there no other setting in the file. Could you check
with a another fresh original file?
WojtuÅ›
Old September 9th 12, 10:58 PM posted to rec.aviation.soaring
Greg Arnold
I opened an OLC file, then SeeYou said he it wanted to update the
software to the latest version. After that the problem occurred.
Everything seems to be working fine now. Maybe the software update
caused the problem.
I still don't understand, however, why SeeYou has two different places
where you can change the UTC offset. A change in one place appears to
have no effect upon the other, so you can end up with two different UTC
offsets?
Old September 9th 12, 11:08 PM posted to rec.aviation.soaring
Wojciech Scigala
offsets?
"Flight properties" affects only the file you have opened - and it shall
be stored in that file if you click save button.
Tools/Options sets the default UTC offset to be used if there is none in
an opened file.
WojtuÅ›
GNS430W: Parallel offset course feature Peter R. Instrument Flight Rules 34 September 29th 07 02:25 AM
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 11:38 AM
Honda outboards offset crankshaft design - vertical shaft [email protected] Home Built 1 May 29th 06 07:00 AM
Engine Mount Tilt and Offset Barrie Gittens Home Built 7 April 21st 04 01:22 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
