Another stall spin
Old September 10th 12, 04:18 AM posted to rec.aviation.soaring
Andrew[_13_]
Default Another stall spin
I see the sailplane spin recovery procedure in the EASA
certification specs is
ailerons neutral
full opposite rudder
stick forward until rotation stops
centralise rudder and ease out of the dive
I'd guess any flap change that manufacturers recommend is more
in preparation for the likely high speeds in the dive.
http://www.easa.europa.eu/agency-mea...certification-
specifications/CS-22/Consolidated%20version%20CS-
22%20Amdt%202.pdf
At 02:54 10 September 2012, Eric Greenwell wrote:
On 8/30/2012 1:15 PM, Bob Whelan wrote:
Indeed, assuming no other changes/inputs, reducing flap
deflection
reduces lift, the glider will settle (increasing the AoA, as -
thanks
to gravity and trim forces - the plane/wing tries to regenerate
lost lift and return to a non-changing-acceleration state), and
stall speed (assuming no change in G load) increases. Kinda
makes for
a strong argument to not put oneself in the position of NEEDing
to
dump flaps (reducing the wing's camber and effective AoA) to
prevent
a spin when close to the ground, eh?
"Settling" is more of an issue at 50 feet on final, than at spin
starting at pattern altitude.
When thermalling or on final, I can change from positive to
neutral or
some negative flap, and the settling is minimal. Because it is
effective, quick to do, and loses less altitude, I think doing near
ground is safer than the standard procedure.
Eric Greenwell - Washington State, USA (change ".netto" to ".us"
to
email me)
Old September 10th 12, 04:42 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
ailerons neutral
No need to guess, as the flight manual for my ASH 26 E (and my ASW 20 B
before) is clear:
"Furthermore, spin recovery will be achieved more quickly if the flap
deflection is reduced. It is advisable to reduce circling flap to the
neutral flap setting."
email me)
Old September 10th 12, 06:44 AM posted to rec.aviation.soaring
Andrew[_13_]
the value of the procedure in the EASA certification spec is that its
a 'guaranteed spin recovery method' for gliders so certified. So
personally I treat it with great respect, and rigorously teach that
procedure. With anything else, one is a test pilot. However,
manufacturer's suggestions are certainly welcome.
ailerons neutral
more
ASW 20 B
before) is clear:
flap
to
email me)
It's Da' Spin,Boss! Da' Spin! [email protected] Home Built 8 November 19th 08 10:28 PM
Stall/ Spin testing the RV-12 cavelamb himself[_4_] Home Built 3 May 14th 08 07:01 PM
Glider Stall Spin Video on YouTube ContestID67 Soaring 13 July 5th 07 08:56 AM
