On Monday, September 10, 2012 10:33:12 AM UTC-5, JohnDeRosa wrote:
The slow motion part was sychedelic! I want to see "boxing the wake"! psychedelic of course. |
![]() "JohnDeRosa" wrote in message ... On Monday, September 10, 2012 10:33:12 AM UTC-5, JohnDeRosa wrote: The slow motion part was sychedelic! I want to see "boxing the wake"! psychedelic of course. Hmmm that could be fun. I'm thinking of adding some small stabilizing device (cardboard fins?) next time I try this. Pete |
![]() Quote:
Brad. |
On Mon, 10 Sep 2012 10:41:36 -0500, Peter von Tresckow wrote:
"JohnDeRosa" wrote in message ... On Monday, September 10, 2012 10:33:12 AM UTC-5, JohnDeRosa wrote: The slow motion part was sychedelic! I want to see "boxing the wake"! psychedelic of course. Hmmm that could be fun. I'm thinking of adding some small stabilizing device (cardboard fins?) next time I try this. Pete How was the camera mounted? How far from the hook was it? I'd assumed it was strapped to the rope with wing tape or similar a few feet away from the tug's hook and that the rolling was due to the rope twisting under tension. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
![]() "Martin Gregorie" wrote in message ... On Mon, 10 Sep 2012 10:41:36 -0500, Peter von Tresckow wrote: "JohnDeRosa" wrote in message ... On Monday, September 10, 2012 10:33:12 AM UTC-5, JohnDeRosa wrote: The slow motion part was sychedelic! I want to see "boxing the wake"! psychedelic of course. Hmmm that could be fun. I'm thinking of adding some small stabilizing device (cardboard fins?) next time I try this. Pete How was the camera mounted? How far from the hook was it? I'd assumed it was strapped to the rope with wing tape or similar a few feet away from the tug's hook and that the rolling was due to the rope twisting under tension. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | I just taped the camera to the rope about 20 feet or so from the glider end of the rope. Nothing fancy, just a whole bunch of wing tape. And yes the twisting is from the hollowbraid rope coming under thension. Until I watched the video I didn't realize how much it twists when you apply tension. Pete |
On Mon, 10 Sep 2012 15:20:56 -0500, Peter von Tresckow wrote:
"Martin Gregorie" wrote in message ... On Mon, 10 Sep 2012 10:41:36 -0500, Peter von Tresckow wrote: "JohnDeRosa" wrote in message ... On Monday, September 10, 2012 10:33:12 AM UTC-5, JohnDeRosa wrote: The slow motion part was sychedelic! I want to see "boxing the wake"! psychedelic of course. Hmmm that could be fun. I'm thinking of adding some small stabilizing device (cardboard fins?) next time I try this. Pete How was the camera mounted? How far from the hook was it? I'd assumed it was strapped to the rope with wing tape or similar a few feet away from the tug's hook and that the rolling was due to the rope twisting under tension. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | I just taped the camera to the rope about 20 feet or so from the glider end of the rope. Nothing fancy, just a whole bunch of wing tape. And yes the twisting is from the hollowbraid rope coming under thension. Until I watched the video I didn't realize how much it twists when you apply tension. Somehow I doubt that just adding fins will help much since its the rope twisting. Would it help to put the camera very near the tug's hook? That should get rid of the twist but the glider may look rather small. Has anybody tried the same trick with a winch? Putting the camera near the parachute end of the shock rope may work quite well. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Monday, September 10, 2012 4:29:44 PM UTC-4, Martin Gregorie wrote:
Has anybody tried the same trick with a winch? Putting the camera near the parachute end of the shock rope may work quite well. I used a similar camera with wing tape to a winch cable (spectra) a few months back: http://www.youtube.com/watch?v=36Wb1s0tHZs Rob |
It would be interesting if you mixed some Left-Hand weave rope with some
Right-Hand weave rope... Maybe it would just all unravel ! Pete I just taped the camera to the rope about 20 feet or so from the glider end of the rope. Nothing fancy, just a whole bunch of wing tape. And yes the twisting is from the hollowbraid rope coming under thension. Until I watched the video I didn't realize how much it twists when you apply tension. Pete |
On Mon, 10 Sep 2012 20:15:37 +0000, Martin Gregorie wrote:
On Mon, 10 Sep 2012 10:41:36 -0500, Peter von Tresckow wrote: "JohnDeRosa" wrote in message ... On Monday, September 10, 2012 10:33:12 AM UTC-5, JohnDeRosa wrote: The slow motion part was sychedelic! I want to see "boxing the wake"! psychedelic of course. Hmmm that could be fun. I'm thinking of adding some small stabilizing device (cardboard fins?) next time I try this. Pete How was the camera mounted? How far from the hook was it? I'd assumed it was strapped to the rope with wing tape or similar a few feet away from the tug's hook and that the rolling was due to the rope twisting under tension. ....this time with a sig! -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Tow Rope Question | James Anderson | Soaring | 1 | July 29th 12 01:47 AM |
Rope Break | Walt Connelly | Soaring | 4 | April 12th 11 09:04 PM |
tow rope | tazman | Soaring | 9 | August 25th 10 02:30 AM |
Where to buy AmSteel tow rope? | [email protected] | Soaring | 2 | April 20th 06 02:45 AM |
11 on a Rope | Peter Seddon | Rotorcraft | 0 | May 27th 04 11:33 AM |
