On Tuesday, September 11, 2012 1:33:42 PM UTC-5, Herbert kilian wrote:
Soaring Cafe has published an article I wrote about the subject: http://soaringcafe.com/2012/09/whats...r-glider-wrap/ I would be interested what this forum thinks about the points made and what the potential downsides are of wrapping a glider in plastic. From my research, it should be a viable alternative to total refinishing. Herb Kilian I would call Dick Butler he can tell you about that. |
On Sep 12, 8:43*pm, wrote:
On Tuesday, September 11, 2012 1:33:42 PM UTC-5, Herbert kilian wrote: Soaring Cafe has published an article I wrote about the subject: http://soaringcafe.com/2012/09/whats...ey-fajita-or-g... I would be interested what this forum thinks about the points made and what the potential downsides are of wrapping a glider in plastic. From my research, it should be a viable alternative to total refinishing. Herb Kilian I would call Dick Butler he can tell you about that. Dick Butler's Concordia has - from the reports I've read - some control surfaces wrapped in Monocote, a shrink film used for model airplanes. This was done solely for mass reduction reasons, no gel- coat on those structures. Car wrapping films are quite different. I'm contemplating starting a field study by wrapping the (short) winglets on my LS8-18 in white glossy film and to apply it myself since I have some background. This is a non-structural component and mine are like the rest of the glider in immaculate condition. The material is available on-line and would cost around $50 for the two winglets. That's cheap enough to remove the film after 1-2 years and see what's underneath (if it holds up that long). Herb |
On 9/13/2012 12:41 PM, Herbert kilian wrote:
On Sep 12, 8:43 pm, wrote: On Tuesday, September 11, 2012 1:33:42 PM UTC-5, Herbert kilian wrote: Soaring Cafe has published an article I wrote about the subject: Snip... Herb Kilian I would call Dick Butler he can tell you about that. Dick Butler's Concordia has - from the reports I've read - some control surfaces wrapped in Monocote, a shrink film used for model airplanes. This was done solely for mass reduction reasons, no gel- coat on those structures. Car wrapping films are quite different. I'm contemplating starting a field study by wrapping the (short) winglets on my LS8-18 in white glossy film and to apply it myself since I have some background. This is a non-structural component and mine are like the rest of the glider in immaculate condition. The material is available on-line and would cost around $50 for the two winglets. That's cheap enough to remove the film after 1-2 years and see what's underneath (if it holds up that long). Herb If you ever fly from "gravelly strips" (e.g. WW-II concrete airbases tend to qualify in this neck of the woods) another area to consider wrapping might be (part of) the tailboom aft of the main wheel where - in my experience - rock damage accrues...an easy wrap, no laminar flow there to be disturbed, possible reduction in "gravel damage"... Regards, Bob W. |
Hi Bob
For your particular problem you do not need a full wrap but the following could help http://www.streckenflug.at/shop/prod...roducts_id=800 |
Wrapping an aircraft isn't new.
Back in 1983, I saw several F-104 Starfighters in white shrink-wrap material. They were to be shipped from Luke Air Force Base, Arizona, to Taiwan. The F-104's were at Luke for training German pilots. However, in the early 80's, the Luftwaffe was changing over to Tornado's and the training program, run not by the U.S. Air Force, but by Lockheed came to an end. Herbert, how's your project coming? If you want to increase the scope of the project, just shrink wrap the Cobra with LS8 inside and ship to me. I'll continue the test and you can go and get yourself a self-launcher that you've would like to have! Ray |
On Sep 15, 7:34*am, rlovinggood wrote:
Wrapping an aircraft isn't new. Back in 1983, I saw several F-104 Starfighters in white shrink-wrap material. *They were to be shipped from Luke Air Force Base, Arizona, to Taiwan. *The F-104's were at Luke for training German pilots. However, in the early 80's, the Luftwaffe was changing over to Tornado's and the training program, run not by the U.S. Air Force, but by Lockheed came to an end. Herbert, how's your project coming? *If you want to increase the scope of the project, just shrink wrap the Cobra with LS8 inside and ship to me. *I'll continue the test and you can go and get yourself a self-launcher that you've would like to have! Ray ....just shrink wrap the Cobra with LS8 inside and ship to me. Ray, I would gladly comply and ship my LS8 to you! Problem is, you wouldn't know what to do with it! (You had it coming) Herb |
I rubbed off portions of my old contest number on a glider years ago
to convert JB to JE for the new owner. The otherwise crazed gel coat looked perfect where the numbers had been. It was kind of eerie to see how much protection had been provided by that thin layer of gray lacquer. Chip Bearden ASW 24 "JB" U.S.A. |
No need to run the experiment. Just look under contest numbers on gliders and trailers. If I had a new glider with gel coat I would really look at wrapping the whole glider. I did the numbers a few years ago and total weight was only about 30 pounds or less for the wrap.
On Friday, September 14, 2012 2:35:29 PM UTC-4, Tim Taylor wrote:
An example: http://blog.aopa.org/lgfsweeps/?p=110 Darn, I was hoping for an example wrapped pilot. |
Book on Glider Refinishing | Scott Alexander | Soaring | 2 | September 3rd 08 09:08 PM |
First Glider - No Gelcoat | Waduino | Soaring | 30 | February 12th 06 06:58 AM |
First Glider no gelcoat | Doug Reeve | Soaring | 0 | February 10th 06 10:05 AM |
Glider refinishing | Janusz Kesik | Soaring | 0 | December 9th 03 05:13 PM |
Refinishing gelcoat | tango4 | Soaring | 21 | November 3rd 03 07:29 AM |
