Cost of Crop damage from glider landing in farmer's field?
Old September 17th 12, 07:18 PM posted to rec.aviation.soaring
ProfChrisReed
Default Cost of Crop damage from glider landing in farmer's field?
I always begin with the apology:
"I'm terribly sorry, but I've had to land my glider in your field." (though note I'm from the UK, where "Sorry" is the proper response to someone treading on your foot).
This makes two points: I know I'm being a nuisance, but I really had no choice.
Then I usually say something like "I don't think I've caused much/any damage, but you'll want to take a look." Once it's obvious that I've not destroyed the field, the conversation about removing the aircraft is usually very pleasant, and I've been lent tow vehicles/given a hand/etc.
It helps if you know enough about farming to show that you won't cause further damage, e.g. that you'll drive only on the tractor wheelings so as not to compact the soil, and so on.
Things can be different at ridge sites, where there are often known safe landing fields and a standard fee because they get used many times a year - the local club briefs visitors on those here.
All the other advice is good, but I've found that starting with the acknowledgment that you're an unwanted visitor is what's needed to form a good relationship.
Off Field Landing in 2-33 on video nimbus[_2_] Soaring 15 July 16th 12 04:28 PM
field landing Bill Bullimore[_2_] Soaring 2 December 16th 10 03:48 AM
Off-Field landing Casey Wilson Piloting 14 January 13th 06 04:13 AM
Alternator field cycling & alternator damage Nathan Young Owning 7 November 14th 04 09:02 PM
B-17 Belly Landing-How much damage? Matt Wiser Military Aviation 0 May 8th 04 10:28 PM
