Gather local wind data
Old September 24th 12, 03:43 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Gather local wind data
As Tony said, we can have really inacurate forecasts here. Mainly because our closest sounding sites are either the other side of the Marfa Dry Line, far enough upwind that even though there are no obvious airmass boundaries, the airmass is definitely different (look at OLC posts from Hinton, OK versus Sunflower on 7-20-2012), or far downwind into the armpit of the soaring world (Topeka, KS). A local sounding is really needed to know what might happen.
As for hiring an ultralight, that would probably cost at least as much each time as a helium balloon. And remember. We are in Kansas. The reason I was thinking of using kites is because the wind blows. Lots. And many days, the ultralight pilot will either not be available or willing to go. I have a couple of hundred dollars worth of kites and high strength line. Now, I just need a small data package to put onboard!
Those are neat loggers, but I didn't see one that measures pressure (altitude). Without that, you have nothing. What we are really looking for is "will it go to at least 3000?" The day's Tony mentioned were 5000 MSL, or 3500 AGL. With a saounding to even 3000, we would know what we would be up against.
I sense the technology is available now, but maybe just not for a mass market. Hoping Andres is still watching this thread.
Steve
Old September 24th 12, 06:09 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Here's one that's not as convenient, perhaps, but does measure altitude
and temperature, plus GPS and more if you want it.
$70 logger
$38 20k altimeter sensor
$11 temperature sensor
http://www.eagletreesystems.com/MicroPower/micro.htm
The model rocket people have this kind of stuff, and a 3000 agl rocket
might be a cheap and reliable way to put the instruments up where you
want them. Retrieving in a wind would involve a chase, but they also
have locators of various types to help find it. There is likely a model
rocket society somewhere near you that could help.
Here is a rocket logger: altitude, temperature - $80
http://www.perfectflite.com/sl100.html
It has two chute deployment altitudes - small chute at the top of the
launch, bigger one near the ground, so drift is minimized.
email me)
Old September 24th 12, 02:25 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Monday, September 24, 2012 12:10:39 AM UTC-5, Eric Greenwell wrote:
Here is a rocket logger: altitude, temperature - $80 http://www.perfectflite.com/sl100.html
May have to get one of those. But again rockets are not the way to go for recurring cost. As I recall from talking with one of our local rocket guys, they are $30 and up per shot. Don't mind a few more bucks to get started, but hate recurring costs.
Thanks for the searching, Eric. If I get one, I will let you know how the kite flying and data collecting goes. That one might have issues, as the launch, climb, and recovery of the kite will likely be more than 9 minutes. Reeling in 7000 feet of like takes a bit of time!
Steve
Old September 24th 12, 05:48 PM posted to rec.aviation.soaring
Dan Marotta
Steve,
Would XCSkies work for your needs? I see, looking at the map for
Hutchinson, that you should be getting lift up to 2,000' AGL right now!
"Steve Leonard" wrote in message
Steve
Old September 24th 12, 06:02 PM posted to rec.aviation.soaring
Tony[_5_]
On Monday, September 24, 2012 11:48:37 AM UTC-5, Dan Marotta wrote:
Steve, Would XCSkies work for your needs? I see, looking at the map for Hutchinson, that you should be getting lift up to 2,000' AGL right now! "Steve Leonard" wrote in message ... On Monday, September 24, 2012 12:10:39 AM UTC-5, Eric Greenwell wrote: Here is a rocket logger: altitude, temperature - $80 http://www.perfectflite.com/sl100.html May have to get one of those. But again rockets are not the way to go for recurring cost. As I recall from talking with one of our local rocket guys, they are $30 and up per shot. Don't mind a few more bucks to get started, but hate recurring costs. Thanks for the searching, Eric. If I get one, I will let you know how the kite flying and data collecting goes. That one might have issues, as the launch, climb, and recovery of the kite will likely be more than 9 minutes. Reeling in 7000 feet of like takes a bit of time! Steve
xcskies is still a model based forecast. when the model is broken it doesn't matter if dr. jack or xcskies is interpreting the data it still will be wrong.
Old September 25th 12, 12:00 AM posted to rec.aviation.soaring
Papa3[_2_]
Yeah, but...
It seems to me that the models are more often wrong about the parts of the forecast that wouldn't be "fixed" by a local sounding.
There are obviously times (e.g. exact timing of a frontal passage) which can make a difference between a soarable day at the local airport and playing golf, but in such cases a morning sounding wouldn't matter. Similarly, we can have a perfectly good boundary layer in place but a pesky short-wave aloft produces a alto-cu layer just where we didn't need it, killing our heating. Again, that one wouldn't be caught by the local sounding. Same for advection of some slightly drier air that takes our day for 3/8 Cu to blue.
I'd be curious if Dan Gudgel or Walt Rogers would weigh in on this one. Maybe I'll just ask :-)
P3
Old September 24th 12, 06:00 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
time!
Maybe use the old kite flyers trick of sending the instrument pack up
the string in a little pod with a sail, once the kite is at altitude.
Or, reverse it: have the pod slide down the string from the kite after
it's up, and have even quicker access to the data.
email me)
Old September 24th 12, 06:53 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
On Monday, September 24, 2012 12:00:59 PM UTC-5, Eric Greenwell wrote:
Maybe use the old kite flyers trick of sending the instrument pack up the string in a little pod with a sail, once the kite is at altitude. Or, reverse it: have the pod slide down the string from the kite after it's up, and have even quicker access to the data.
-- Eric Greenwell
Well, the package would have to be on the second kite in my system. It seems that one kite on 1000 feet of string got to about 800 feet based on the altimeter watch that was used in initial testing. Adding another 1000 feet of string only got about 400 feet more altitude. Bigger kite needed. But, what to do with the smaller one, since the money was invested? Tie it to the main line on a 100 or so foot tether, and let it help in lifting the line. So, I won't have a 7000 foot long, clear shot up the line. I did learn some interesting dynamics of an intermediate, line lifting kite, though.
Interested in seeing the dynamic of a powered winch to reel the line in. Will have the effect of increased wind speed for the kites, so they should climb a little higher. First attempts were with people grabbing the line and walking it towards the reel (yes, the first 200 feet or so of the line was only 4-6 feet off the ground when we had, I believe, 3000 feet of line). I have seen what this line put on a Home Depot Extension cord reel does over time. I now have a big mess of kite string, as it contracted and split the ends off of the reel!
Steve
Old September 24th 12, 10:29 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Talking to these guys may give some pointers to what can be done:
http://www.kiterecord.org/kiterecord/
They've had a single kite up to 10,466 ft, but it was a big one: 16 m^2
I also remember hearing that US meterologists got the top kite in a
string to 25,000 ft in the late 1930s, but can't find a reference to
quote.
I'd say that a rocket instrument package would be a good starting point
because its light: put it under a fairly large Rogallo-type kite and fly
it on light, low drag line (Spectra or Kevlar?) and you should get the
height you want. Light and low drag and large are all important since the
kit's lift must support the weight of the whole rig as well as offsetting
the drag of line and kite. Some sort of winch would be good too, even if
its only a geared (multiplier) sea-fishing reel.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Historical Wind Data for LKV? GARY BOGGS Soaring 6 November 23rd 11 03:34 PM
Fwd: Planets Gather on May 5 and May 17, 2000 [email protected] Owning 4 February 8th 09 02:40 PM
Fwd: Planets Gather on May 5 and May 17, 2000 [email protected] Piloting 5 January 27th 09 06:34 PM
Local Navy families gather in Sarasota Otis Willie Naval Aviation 0 December 24th 05 11:36 PM
