Actually it is not 10 hours worth....its about 4 hours worth.
The "rated" 9 AH is rated at .05C or 450 ma. If you run at 800 ma, that's about .1C.....so you don't get half the time, you get way less than half........... Also they rate the batteries as "dead" at 10.5 volts, but for glider equipment, once you get down to 11.5 or so, stuff doesn't work well. Actually anything under 12 volts means time to recharge.....below 10.5 volts and battery damage can occur. For an 800 ma draw, the proper battery would be 16 AH.....this in theory would last 20 hours, and leave you at 10.5 volts.....probably 10 hours to stay above 11.5... Cookie At 03:30 24 September 2012, Mike the Strike wrote: The 9A.h batteries I use would have a rated capacity of about 8A.h at a current of 0.8A - that's about ten hours' worth. Dropping the temperature to freezing will drop that to about 7 to 8 hours - still more than you're getting. Also remember that the current drawn by some devices may increase as the voltage drops. I'd suggest checking your current draw at a range of battery voltages. If your charger's ok, it sounds like your battery isn't. Mike |
Battery Power | Mike McCarron[_2_] | Soaring | 13 | September 27th 12 06:22 PM |
battery power regulator | Tony V | Soaring | 17 | August 10th 11 05:39 AM |
Oshkosh Camping - Battery Power | Tom McQuinn | Owning | 3 | June 11th 07 12:19 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
battery charger to get through Piper power port? | Kyler Laird | Owning | 16 | March 20th 05 12:08 AM |
