On 12/01/2016 22:16, Andy Blackburn wrote:
I expect the pylon-mounted sustainers with a larger prop would be the best compromise (reliable and fast deployment, minimal drag, acceptable range, low enough weight for an 18m glider to not face too much of a weight penalty. Whether it is appreciably more efficient than an FES prop would be interesting to know - my guess is they'd be a bit more efficient. FES wins for pure simplicity. If I were investing in a sustainer, my preference would also be for a pylon mounted electric unit. Pylon retraction should be as reliable as u/c retraction and time to extend/retract would not equate to significant hight loss. Once the prop is in the breeze an electric drive is equally reliable on a pylon as it is on a FES. Pylon installation in existing fuselage designs should be easier than FES and there would be fewer complications with cooling and instruments. When a pylon motor is stowed, there is less drag than there is with a folding prop and unlike FES there is very little chance of accidental damage. I am not sure what the drag/efficiency is of a FES verses a pylon + large prop once they are both running. Maybe FES has an advantage, giving it longer range? I'd rather carry batteries around than gasoline any day. Internal combustion engines (and turbines) are a recipe for lots of mechanical fiddling and maintenance in my experience. I think the biggest requirement for a sustainer is reliable starting, with minimum pilot work load and minimum hight loss. Electric has got to win every time. Now if FES technology and experience was to put into a pylon mounted electric sustainer which could be retrofitted it into any 15m or 18m fuselage originally designed to accommodate a sustainer, I might be tempted to pawn my pension.... The tricky part is that the batteries may have to go into the wings. Ian |
On Thursday, September 27, 2012 12:00:04 AM UTC+1, Chris Davison wrote:
My vote goes for the first technology that can be fitted to a Libelle! And I only want a system which can provide enough power to self-launch an 18m or larger glider, and have sufficient power left for a relight and/or a long retrieve. Which today means a combustion engine. But I have to say that if I did not want self-launch, either the FES or the Jet would seem overwhelmingly better than the Turbo. For me it would be the jet because I don't like the idea of even a little drag from the prop, and I feel uneasy about having a mechanism in front of my feet - but it would have to be a jet which gives a good rate of climb, which if I understood correctly pretty much means a JS1 or an HP304. |
Dne Ĩetrtek, 27. september 2012 02:07:47 UTC+2 je oseba waremark napisala:
On Thursday, September 27, 2012 12:00:04 AM UTC+1, Chris Davison wrote: My vote goes for the first technology that can be fitted to a Libelle! And I only want a system which can provide enough power to self-launch an 18m or larger glider, and have sufficient power left for a relight and/or a long retrieve. Which today means a combustion engine. But I have to say that if I did not want self-launch, either the FES or the Jet would seem overwhelmingly better than the Turbo. For me it would be the jet because I don't like the idea of even a little drag from the prop, and I feel uneasy about having a mechanism in front of my feet - but it would have to be a jet which gives a good rate of climb, which if I understood correctly pretty much means a JS1 or an HP304. Video of LAK17A FES takeoff using 120m of rope and Auto tow. http://www.youtube.com/watch?v=pTeNK...layer_embedded |
Luka,
Many of US glider ports have 4-5000ft paved runway. Do you think electric scooter hub motor would help FES launch 850lbs Standard glider ? Do you think , you could change shape of the batteries so we can slip them in the wings instead of water bags ? With Chinese batteries prices dropping down,and most of US gliders registered experimental,do you think you could sell FES kits for $15000 if you have at least 100 customers ? In US most of us are keeping gliders in the trailer, and trailer sits outdoors,did you think about creating solar charging system for FES batteries on the trailer ? Ryszard |
Here are my answers:
Dne petek, 28. september 2012 23:50:12 UTC+2 je oseba RW napisala: Luka, Many of US glider ports have 4-5000ft paved runway. Do you think electric scooter hub motor would help FES launch 850lbs Standard glider? Now we have 22kW in front which is plenty of power for good acceleration on paved runway. Small enough motor which could fit into hub of Tost whell, I think could not have more than 1 or maybe 2kW. You can see a video of LAK17A FES selflaunch at 400kg weight: http://www.youtube.com/watch?v=3gLH9...layer_embedded Even for selflaunch from a grass is enough power and we will also increase it in future. What is really neccesery for safe selflaunch from grass is slightly higher undercariange, which is also possible to achive, with some modifications. And this is the plan to do it! Do you think , you could change shape of the batteries so we can slip them in the wings instead of water bags ? Unfortunately this is not so simple. Check how batterie in the wings are arranged at Antares: http://nadler.com/Antares/Antares_MechanicTraining.html It can not be done in much different way, and so you need to have built in rails, to slide them in and so that they are fixed. Another issue is that wings are bending etc. On used glider all this would be science fiction... With Chinese batteries prices dropping down,and most of US gliders registered experimental,do you think you could sell FES kits for $15000 if you have at least 100 customers ? Electric system must be properly installed, so we do not support selling kits, as we can not be sure that instalation would be done properly. There is only very little choice for suitable batteries (capacity, size, weight, and C ratings) which are still expensive. With bigger series I am sure price could drop considerably. In US most of us are keeping gliders in the trailer, and trailer sits outdoors,did you think about creating solar charging system for FES batteries on the trailer ? This is possible and it was done already by solar and wind generators by other companyes, but it would higher the price, especially if there are buffer batteries in trailer like it was done at those solutions. To take batteries out and charging them on the grid is the cheapest and the safest way. But onyl at FES this is possible as there are only two 15kg batterie boxes, and they are easy to take out and install back. Storage of batteries is prefared at room temperatures. If trailer is standing on hot sun, than temperature inside is higher and this is not good for time life of batterie packs. Ryszard |
Front Electric Sustainer | Dan Marotta | Soaring | 28 | January 31st 13 01:32 AM |
would an electric sustainer be practical | Brad[_2_] | Soaring | 7 | July 24th 09 06:29 PM |
Which Came First, the Santa Monica Airport, Or Those Who Chose To Build Their Homes Adjacent To It? | Larry Dighera | Piloting | 16 | May 7th 07 10:34 PM |
BAF or CEF? I chose BAF. | Paul Tomblin | Instrument Flight Rules | 0 | October 23rd 04 04:33 PM |
DG goes the sustainer option. | Paul | Soaring | 25 | June 4th 04 12:16 AM |
