I don't like the switching in my CAI302. It seems I have to turn greater
than 180 degrees before it switches and, if I roll out for a couple of seconds to shift my thermal, it will switch back to cruise mode, requiring another 180+ degrees before switching back to circling mode. ... Or maybe that's my XCSoar program. I'll have to give it a close look today if the winds aren't howling. "Andrzej Kobus" wrote in message ... On Oct 1, 12:02 pm, "Dan Marotta" wrote: Years back, I installed a simple toggle switch on top of the stick in my LS-6. Switch forward meant "Go Fast", switch back meant "Thermal". Easy and intuitive, no reaching to the panel to switch between cruise and climb mode. wrote in message ... On Sunday, September 30, 2012 9:16:24 PM UTC-4, Andrzej Kobus wrote: Can anyone tell me how CN switches from Cruise to Climb with the software available (assuming no switch installed)? In the case of my vario, it showed up with a switch already wired in. A software update came along about the same time that enabled automatic switching at 65kts. Unfortunately you can only do one or the other right now; I couldn't find a config screen in the vario to change that. The change has to be done using their profile generator program on a PC. The switch was easy to install in the panel, but it's a pain to have to fiddle with it whenever you want to start working a thermal. 65kts is just too fast in my plane for searching for lift down low (it's about MC 1.5kts for me). This does seem to be a work in progress however. I'm hoping for a circling detector at some point. -- Matt It is the 21st century why would I need switches? CAI 302 does great switching by itself and it was not designed yesterday. As a consumer I would expect ClearNav to be at least as good as CAI 302. I hope it happens. It would be nice to have a release schedule at least with things like electronic compensation and climb/run switching. I would consider these to be basic features of a modern variometer. I hope this happens soon. |
Dan, CAI 302 switches after 7s from the time it detects change in
direction (if the change continues). Since when you start turning it takes a couple of sec to get to the 40-45 deg turn so it is more likely the switch will happen in less than 90 deg but no more than 120 deg and if your turn is shallow than even in fewer degrees. If you run your vario in relative netto there is nothing you need to wait for anyway since the needle already shows you the right value provided you are flying with speed close to what you need to to climb. My experience with CAI 302 is very good. As others said it is a very good variometer. On Oct 5, 11:39*am, "Dan Marotta" wrote: I don't like the switching in my CAI302. *It seems I have to turn greater than 180 degrees before it switches and, if I roll out for a couple of seconds to shift my thermal, it will switch back to cruise mode, requiring another 180+ degrees before switching back to circling mode. *... Or maybe that's my XCSoar program. *I'll have to give it a close look today if the winds aren't howling. "Andrzej Kobus" wrote in message ... On Oct 1, 12:02 pm, "Dan Marotta" wrote: Years back, I installed a simple toggle switch on top of the stick in my LS-6. Switch forward meant "Go Fast", switch back meant "Thermal". Easy and intuitive, no reaching to the panel to switch between cruise and climb mode. wrote in message ... On Sunday, September 30, 2012 9:16:24 PM UTC-4, Andrzej Kobus wrote: Can anyone tell me how CN switches from Cruise to Climb with the software available (assuming no switch installed)? In the case of my vario, it showed up with a switch already wired in. A software update came along about the same time that enabled automatic switching at 65kts. Unfortunately you can only do one or the other right now; I couldn't find a config screen in the vario to change that. The change has to be done using their profile generator program on a PC. The switch was easy to install in the panel, but it's a pain to have to fiddle with it whenever you want to start working a thermal. 65kts is just too fast in my plane for searching for lift down low (it's about MC 1.5kts for me). This does seem to be a work in progress however. I'm hoping for a circling detector at some point. -- Matt It is the 21st century why would I need switches? CAI 302 does great switching by itself and it was not designed yesterday. As a consumer I would expect ClearNav to be at least as good as CAI 302. I hope it happens. It would be nice to have a release schedule at least with things like electronic compensation and climb/run switching. I would consider these to be basic features of a modern variometer. I hope this happens soon. |
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario | ufmechanic | Soaring | 0 | March 24th 09 05:31 PM |
Martin Mars, Performing Live In Downtown Vancouver! | Zomby Woof | Aviation Photos | 3 | January 20th 08 03:10 PM |
Martin Mars, Performing Live In Downtown Vancouver! | Zomby Woof | Naval Aviation | 2 | January 11th 08 06:10 PM |
Navy Performing Well, Keeps Eye on Future Force | Otis Willie | Naval Aviation | 0 | February 14th 05 10:06 PM |
AN-2 performing a loop | Maro_SK | Aerobatics | 1 | March 25th 04 08:18 PM |
