LiFePO4 battery technolocy
Old October 15th 12, 03:49 PM posted to rec.aviation.soaring
Default LiFePO4 battery technolocy
My RC friends who use LiFePO4 swear by them. They handle high amperage drain and can be charged at higher amperage than other battery technology. They are not as popular in RC as they are heavier and larger than equal LiPo amperage. These differences are not a concern for sailplane use.
And of most importance, LiFePO4 cells do not have the explosion/fire risk of LiPo cells if charged incorrectly. FWIW,all LiPo cells I've seen are flat and thin and rectangular. All the LiFePO4 I've seen are cylindrical.
Absolutely, Lipo cells require balance maintenance. I cannot confirm but have read LiFePO4 cells are self balancing when connected in series and do not require an on board balance circuit or an external balancing plug.Please do your own due diligence.
Other than K2, all the LiFePO4 packs I've seen were home made packs using cylindrical cells taken from DeWalt tool power packs. It is my understanding the DeWalt cells are actually A123 brand LiFePO4 cells.
This is an outstanding battery and charger forum. http://www.rcgroups.com/batteries-and-chargers-129/
Safe flights.
Old October 15th 12, 06:25 PM posted to rec.aviation.soaring
This is an outstanding battery and charger forum. http://www.rcgroups..com/batteries-and-chargers-129/
Safe flights.
There are tons of non-cylindrical LiFePo4 batteries here
http://www.hobbyking.com/hobbyking/store/index.rc
They make cells of all types of cell numbers and capacities. I tried them in the past for RC use and they were not very reliable then(2-3 years ago).
The prices are modest since they sell the naked cells with balance charge plug and power leads. You need your own charger but they can also be had at Hobbyking. Note that they have a warehouse in the USA.
Old October 16th 12, 01:13 AM posted to rec.aviation.soaring
Yes J7, you are correct. However the flat rectangular cells offered by HobbyKing and are lower amperage cells and not suitable to soaring amperage requirements unless you combined multiple packs in parallel. This is too complicated for my likes.
My interest is having only four cells wired in series providing 10, 12, or better yet 15 amps such as these examples.
RAS moderators and et al please note. In no way am I endorsing the following products or trying to sell them. Information is for reference only.
http://www.ebay.com/itm/4PCS-12V-LiF...e m33752e1ec6
http://www.ebay.com/itm/4PCS-12V-LiF...e m33753e0bb2
http://www.ebay.com/itm/4PCS-12V-LiF...e m337698b7ad
The 10 amp and 12 amp cells should fit in existing battery wells. The 15 amps cells will probably require battery well modification.
LiFePO4 cells certainly are the "now" technology and in my opinion offer the best performance and longevity for the buck today.
Got juice?
Safe flights.
Old October 16th 12, 02:44 PM posted to rec.aviation.soaring
Got juice?
My RC friends who use LiFePO4 swear by them. They handle high amperage drain and can be charged at higher amperage than other battery technology.. They are not as popular in RC as they are heavier and larger than equal LiPo amperage. These differences are not a concern for sailplane use.
Safe flights.
Dear Unknown,
Here is the battery I just ordered with the intent to replace my 10Ah NiMH battery dedicated to the transponder. It is ready for usage, no soldering except for the fuse and the plug.
http://www.hobbyking.com/hobbyking/s...dproduct=20645
This is a 8400mAh 4S cell with a 30C discharge rate, you can fry your eggs on the discharge of that thing (over 200A).
Old October 16th 12, 04:06 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
http://www.ebay.com/itm/4PCS-12V-LiF...Cells-38120S-1...
http://www.ebay.com/itm/4PCS-12V-LiF...Cells-38140S-1...
http://www.ebay.com/itm/4PCS-12V-LiF...Cells-40152S-1...
Got juice?
Absolutely, Lipo cells require balance maintenance. I cannot confirm but have read LiFePO4 cells are self balancing when connected in series and do not require an on board balance circuit or an external balancing plug..Please do your own due diligence.
This is an outstanding battery and charger forum. * *http://www..rcgroups.com/batteries-and-chargers-129/
Safe flights.
They make cells of all types of cell numbers and capacities. *I tried them in the past for RC use and they were not very reliable then(2-3 years ago).
The prices are modest since they sell the naked cells with balance charge plug and power leads. *You need your own charger but they can also be had at Hobbyking. *Note that they have a warehouse in the USA.
Dear Unknown,
Here is the battery I just ordered with the intent to replace my 10Ah NiMH battery dedicated to the transponder. *It is ready for usage, no soldering except for the fuse and the plug.http://www.hobbyking.com/hobbyking/s...dproduct=20645
I've fooled around with RC model batteries enough to know that I will
never put one of these in my full scale glider. In addition to
chemistry -- we'll presume for the moment that the HK LiFePO4
batteries are discharge & overcharge safe -- there's the issue of
short circuit protection *in* the battery pack. K2 puts all the
balance circuitry and such inside a sealed box where the connections
can be strain relieved, solidly anchored and protected in a way that
simply cannot be done in a hobby pack like this.
Electrically, I like your idea. But mechanically I think it needs to
be more robust.
Evan Ludeman / T8
Old October 16th 12, 06:40 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 10/16/2012 8:06 AM, Evan Ludeman wrote:
Dear Unknown, Here is the battery I just ordered with the intent to
will never put one of these in my full scale glider. In addition to
to be more robust.
THe HobbyKing pack is designed toys that don't have people in them. I'd
have more confidence in it if it had a battery management system built
into it and there was a datasheet listing the manufacturer, charging
requirements, cycle life, etc.
email me)
Old October 16th 12, 04:57 PM posted to rec.aviation.soaring
Dear Herbert:
Referenced pack looks good.
A K2 12 V x 10 amp LiFePO4 battery is +/- 151mm long, 65mm wide, and 98mm high.
Depending on how you stacked them, 2 of the referenced HobbyKing packs wired in parallel could be +/- 150mm long x 52mm wide x 140mm high with a good 1/2" of room on the side to "store" the extra wiring. If you can manage the additional 1-5/8" height, you are now sporting almost 17 amps per battery well.
(Note to self...reminded again engineers usually know what they are talking about.)
Got juice?
Safe flights.
Dear Unknown,
LiFePO4 batteries JS Soaring 26 October 15th 12 02:51 PM
LiFePO4 battery ASM Soaring 4 December 6th 11 07:00 PM
Battery 6ah vs. more Roy Clark, \B6\ Soaring 27 April 27th 08 05:01 PM
Battery Connectors Paul Remde Soaring 9 April 9th 06 06:39 PM
Battery for gliders Udo Rumpf Soaring 23 January 19th 05 04:13 PM
