FLARM presentation
Old October 16th 12, 02:58 PM posted to rec.aviation.soaring
Default FLARM presentation
On Monday, October 15, 2012 8:37:04 PM UTC-5, Evan Ludeman wrote:
On Monday, October 15, 2012 5:53:44 PM UTC-4, Evan Ludeman wrote:
On Oct 15, 4:43*pm, wrote:
On Monday, October 15, 2012 1:04:01 PM UTC-7, (unknown) wrote:
Andy you are correct and thank you for correcting the question. Being able to hear an alert before you "eyes on" an alert is most important.
On Monday, October 15, 2012 10:33:41 AM UTC-4, Andy wrote:
Isn't *your question is incomplete without asking for a comparison of
audio alerting?
GY
If you already have a ClearNav and were going to add a Flarm Brick, do you need a dedicated Flarm display as well on your panel, or does the ClearNav show the needed information just fine by itself? Opinions?
ClearNav flarm interface is still in development. The latest publicly
available beta is 2.2.0.25 and this has several known issues with
flarm (most apparent in a really high density flarm environment). I
am flying 2.2.0.31alpha and it's much better and quite stable, but
still does not include pcas alerts or the ability to switch flarm into
stealth mode. I'll see about getting a later version posted to the
website. We're not quite ready to say we can replace the dedicated PF
display.
Evan Ludeman on behalf of ClearNav Instruments
update: Mode C/S & ADSB almost ready for public release. Inclination is to hold off on next release until this is all tested.
Evan Ludeman for CNi
Evan:
Just to clarify: the intent of the CN development is that CN will be able to completely substitute for a dedicated flarm display. Is this correct?
Like many others, I'm staring at this pile of flarm stuff in a box, with all its (ha ha) well thought out installation options... and if I could just dispense with the display that would be fantastic. Knowing where the CN development process is going helps a lot. Nothing has to work until spring.
John Cochrane
Old October 16th 12, 06:02 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
audio alerting?
GY
ClearNav flarm interface is still in development. *The latest publicly
flarm (most apparent in a really high density flarm environment). *I
stealth mode. *I'll see about getting a later version posted to the
website. *We're not quite ready to say we can replace the dedicated PF
display.
update: *Mode C/S & ADSB almost ready for public release. *Inclination is to hold off on next release until this is all tested.
Evan:
Just to clarify: the intent of the CN development is that CN will be able to *completely substitute for a dedicated flarm display. Is this correct?
Like many others, I'm staring at this pile of flarm stuff in a box, with all its *(ha ha) well thought out installation options... and if I could just dispense with the display that would be fantastic. Knowing where the CN development process is going helps a lot. Nothing has to work until spring.
John Cochrane
Yes. CN will display all of the information and alerts provided by
powerflarm, with audio, and you can bet that we'll do a better job of
it than these tiny little displays from flarm and butterfly. This is
all nearly finished.
Old October 16th 12, 08:59 PM posted to rec.aviation.soaring
Andy[_1_]
On Oct 16, 10:02*am, Evan Ludeman wrote:
Yes. *CN will display all of the information and alerts provided by
it than these tiny little displays from flarm and butterfly. *This is
Don't have CN but curious to know if the volume of the alerting will
be automatically adjusted based on ambient noise level or (less
preferably) airspeed.
In my opinion the 302 would have been much improved by automatic
volume control.
Andy
Old October 16th 12, 10:34 PM posted to rec.aviation.soaring
guy
This is a very good point. Volume of audio warning and alerts.
The 302 has a fatal flaw with regards to the gear warning system. The
volume of the gear warning is tied to the general audio control.
Some people (I am one) turn all the audio system off except the radio
when entering the pattern for a landing. The less distractions the
better. Guess what? That means the gear warning system won't help me
if I need it.
Now I have an independent system who's volume can't be changed by me
when flying.
Guy
Old October 18th 12, 06:45 AM posted to rec.aviation.soaring
Ramy
This is a bit off topic but the comment that the 302 gear alarm is volume controlled is incorrect, at least in my installation. The gear alarm is very loud regardless of the volume control. And it already paid for itself...
Ramy
Old October 22nd 12, 05:43 AM posted to rec.aviation.soaring
bumper[_4_]
Ramy
Correct. I remember from the installation manual that alarms automatically have increased volume. I've tested it many times, though never in anger . . .
There are two paint dots on the cockpit side near the gear handle, green and red, to remind my hypoxic, dehydrated mind which way the handle should be.
bumper
Old October 22nd 12, 03:41 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Ramy
handle should be.
Here's my best simulation of my hypoxic mind: "Green means GO, so that
must be GEAR IS UP"; "Red means DANGER, so that must be GEAR IS UP".
email me)
New FES presentation video! [email protected] Soaring 0 September 17th 12 01:57 PM
EAA Presentation lanebush Soaring 1 November 10th 11 03:01 AM
Presentation Betideact General Aviation 2 January 31st 11 08:22 AM
ELT and PLB Presentation Available ContestID67 Soaring 0 October 12th 07 09:51 PM
PCC Presentation Jim Vincent Soaring 18 April 9th 04 06:07 AM
