PowerFLARM leeching comments
Old October 22nd 12, 12:35 AM posted to rec.aviation.soaring
Default PowerFLARM leeching comments
On Saturday, October 20, 2012 5:52:55 PM UTC-4, Dave Nadler wrote:
On Saturday, October 20, 2012 5:30:05 PM UTC-4, Don Johnstone wrote:
... I was very uncomfortable with the concept of instructing
pilots to lessen the efficiency of an anti-colision assistance device.
Stealth mode in no way lessens the efficacy of FLARM anti-collision.
It gives you warnings when there is a collision hazard regardless.
Hope that is clear,
Best Regards, Dave
Dave,
it is clear, and while your statement is probably technically accurate, it isn't entirely correct. Any mode that reduces the pilot's situational awareness also degrades safety to some extent. Stealth mode by definition does exactly that. The OC fatality scenario is a case where stealth mode might not provide enough warning to assess the situation and take appropriate action, whereas the 'full' mode probably would. Just my $0.02
Frank (TA)
Old October 22nd 12, 12:41 AM posted to rec.aviation.soaring
Evan Ludeman[_4_]
pilots to lessen the efficiency of an anti-colision assistance device..
Hope that is clear,
Best Regards, Dave
Dave,
it is clear, and while your statement is probably technically accurate, it isn't entirely correct. *Any mode that reduces the pilot's situational awareness also degrades safety to some extent. Stealth mode by definition does exactly that. *The OC fatality scenario is a case where stealth mode might not provide enough warning to assess the situation and take appropriate action, whereas the 'full' mode probably would. *Just my $0.02
Frank (TA)
See pg 19 of the PowerFlarm Dataport Specification for details about
how stealth mode works.
It's he http://tinyurl.com/8ne9cjx
Stealth mode does not change the anti-collision functionality of
PowerFlarm at all. You'll get the get the same 25 seconds warning,
which is plenty.
Evan Ludeman / T8
Old October 22nd 12, 02:52 AM posted to rec.aviation.soaring
Hope that is clear,
Best Regards, Dave
Dave,
Frank (TA)
which is plenty.
Evan Ludeman / T8
"Plenty" is interesting. Let's all remember, flarm is not a "collision avoidance" device. It is a "collision warning" device. You still have to find the other glider, avoid it, and not run in to anyone else while you're doing that. Don't just bank away from the collision threat, make sure there isn't a new collision threat.
If glider A is a collision threat, glider B is off to your side and not a collision threat, will flarm show glider B in stealth mode? No, I gather. If you suddenly bank towards glider B to avoid glider A...
And it doesn't always give 25 seconds warning, especially if carbon fuselages are blocking signals. Gliders have collided when both had operating flarm systems. Norway and Uvalde.
A stealth mode is far from obviously a good idea, if it only shows imminent collision threats. The operation and reliability of such a mode have to be really bulletproof. Which, given power flarm's recent history with range issues, software updates, antenna updates etc., would seem to be something one would want a lot of real world experience with. But how do we get real world experience and find out its actual limitations?
It's interesting how many reports we're getting of pilots who saw collision threats with flarm. But we obviously don't know about the failures until they hit each other. And how do we learn about the failures under stealth mode. Can of worms here.
John Cochrane
Old October 22nd 12, 04:28 AM posted to rec.aviation.soaring
Ramy
Stealth mode in no way lessens the efficacy of FLARM anti-collision..
Hope that is clear,
Best Regards, Dave
Dave,
Frank (TA)
which is plenty.
Evan Ludeman / T8
John Cochrane
I agree with John. I find the situational awareness as important as the collision alert. Also, not sure where the 25 sec came from, but when I was on a head on with another glider at 17K both of us flying above 100 knots TAS, the warning we got was more like 10 seconds, just enough to react and bank away. We never saw each other until we banked away, but luckily we saw each other on flarm radar 5 miles away giving us plenty time to be alerted and be prepared to change course. I sure hope no one will fly in stealth mode.
Ramy
Old October 22nd 12, 06:03 AM posted to rec.aviation.soaring
Brad[_2_]
It gives you warnings when there is a collision hazard regardless..
Hope that is clear,
Best Regards, Dave
Dave,
Frank (TA)
It's he *http://tinyurl.com/8ne9cjx
PowerFlarm at all. *You'll get the get the same 25 seconds warning,
which is plenty.
Evan Ludeman / T8
If glider A is a collision threat, glider B is off to your side and not a collision threat, will flarm show glider B in stealth mode? No, I gather.. *If you suddenly bank towards glider B to avoid glider A...
A stealth mode is far from obviously a good idea, if it only shows imminent collision threats. *The operation and reliability of such a mode have to be really bulletproof. Which, given power flarm's recent history with range issues, software updates, antenna updates etc., would seem to be something one would want a lot of real world experience with. But how do we get real world experience and find out its actual limitations?
John Cochrane
Ramy
Ramy,
How did you know which direction to bank? I've not flown with the unit
enough to get a feel for what evasive moves to make. So far when I've
been warned I've seen the other aircraft and can react accordingly.
Thanks,
Brad
Old October 22nd 12, 06:26 AM posted to rec.aviation.soaring
Ramy
Hope that is clear,
Best Regards, Dave
Dave,
Frank (TA)
which is plenty.
Evan Ludeman / T8
If glider A is a collision threat, glider B is off to your side and not a collision threat, will flarm show glider B in stealth mode? No, I gather. *If you suddenly bank towards glider B to avoid glider A...
John Cochrane
Ramy
Ramy,
Thanks,
Brad
I should mention that we were also talking to each other on the radio. The whole time we were closing on each other I was waiting to see him but when the collision alert and the audio alarm started showing him at 12 ocklock same altitude I just decided the bank to the right while radioing to him that I am doing so, and he banked to the right as well. This was the first time for both of us to see each other, very eye opening as we both knew there is traffic ahead and were scanning for it yet we couldn't see each other as we were a non moving target. I figured banking right is the standard procedure with head on traffic, if not, it should be the protocol when flarm warns of traffic at 12 oclock. Diving or pulling my not work since both pilots may do the same thing, but both banking right will do the trick.
Ramy
Old October 23rd 12, 04:34 AM posted to rec.aviation.soaring
Andy[_1_]
Don't forget that FLARM traffic orientation is relative to your TRACK not your HEADING. In other words traffic at 12 O'clock on your FLARM display will not be at your nose if you are flying with a crosswind.
The correct direction to turn in a head on situation was discussed at length and heatedly in UK RAS a couple of years ago. If after years of usage they couldn't agree, how can you be so sure?
I asked years ago if US PowerFLARM would be integrated with other available sensors to provide a useful heading referenced display but the question fell on stony ground.
Andy
Old October 22nd 12, 12:20 PM posted to rec.aviation.soaring
Dave Nadler
No, I gather.
Correct.
And especially if pilots have not followed sensible practice
installing the antennas, or used antennas with no radiation
downwards. Speak to your fellow pilots when you see this,
it could be your life...
gratuitous obnoxious comment snipped
... would seem to be something one would want a lot of real world
One could possibly pay attention to foreign experience, where many
thousands of FLARM have been deployed for years, instead of
provincially continually reinventing the wheel...
Just a far-out idea, wishful thinking no doubt...
Old October 22nd 12, 03:30 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Hope that is clear,
Best Regards, Dave
Dave,
Frank (TA)
which is plenty.
Evan Ludeman / T8
John Cochrane
If there's a comm problem between flarm transceivers, then the operating mode simply doesn't matter. One advantage of the open mode is that it provides a means to test the system performance without aerial jousting. And yeah, I see a lot of carbon gliders (V2's mainly) with really spotty contact.
Short warning time when comm is established probably reflects maneuvering, i.e. a course conflict that arose "unexpectedly". For high speed head on traffic, "maneuvering" doesn't necessarily mean much. A small heading/glide slope change is all it would take.
T8
Old October 22nd 12, 06:04 PM posted to rec.aviation.soaring
Perhaps this is a good summary of the various opinions skeptical of stealth mode:
Collision avoidance is enhanced by situational awareness, of gliders that you are not actually on a collision path towards. This is especially true of "carbon gliders with spotty contact." If you know there are 5 gliders in the gaggle, and where the ones you can't see are, you're less likely to miss one, or no know what to do when an alert goes off, than if they are all blanked from the screen. This does seem like a "real world" difficulty of stealth mode.
(And Dave, sorry for "gratuitous obnoxious comments." You are doing heroic work with Flarm, and hearing only the complaints when things aren't already perfect.)
John Cochrane
Logger on PowerFlarm? LOV2AV8 Soaring 7 July 27th 12 03:18 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Paul Remde Soaring 9 November 6th 10 04:30 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
PENTAGON CONSIDERING MILITARY BUILD UP AGAINST IRAN (Scroll down to comments section - see page 2 of the comments section as well): [email protected] Naval Aviation 0 December 19th 06 08:37 PM
