Remote thermal detection
Old October 24th 12, 12:26 AM posted to rec.aviation.soaring
Bill D
Default Remote thermal detection
Even with PowerFLARM on "stealth" pilots may soon have another way to find the next thermal. The DARPA "One Shot" initiative will develop a rifle scope which uses LIDAR to detect and correct for crosswind "windage". The Israeli Soreq Nuclear Research Center has already been granted a patent on the LIDAR technology.
http://www.accurateshooter.com/optic...ar-laserscope/
https://www.fbo.gov/utils/view?id=1c...0d40d64c7cc251
Rotate the 'scope 90 degrees and you have a thermal detector which directly reads vertical velocity. Presumably, if the system can be miniaturized to fit in a rifle scope and be powered by man-packable batteries, fitting it into a sailplane shouldn't be that difficult - costs aside.
Old October 24th 12, 01:03 AM posted to rec.aviation.soaring
son_of_flubber
I expect that this technology will be deployed on Skynet Drones (UAVs) before it reaches sailplanes.
Old October 24th 12, 02:20 AM posted to rec.aviation.soaring
Brad[_2_]
I did some consulting work for a small company making VR headgear to
be used for training purposes. I mentioned to him about the
possibility of tweaking the device so that it would pick up
"thermals". He seemed to think it could be done.
Of course the display would need to be re-designed for our use, but it
sure would be cool. I suspect it isn't too far on the tech horizon for
us glider guiders.
Brad
Old October 24th 12, 04:32 AM posted to rec.aviation.soaring
Liam
On Oct 23, 4:26*pm, Bill D wrote:
Even with PowerFLARM on "stealth" pilots may soon have another way to find the next thermal. *The DARPA "One Shot" initiative will develop a rifle scope which uses LIDAR to detect and correct for crosswind "windage". *The Israeli Soreq Nuclear Research Center has already been granted a patent on the LIDAR technology.
http://www.accurateshooter.com/optic...0d40d64c7cc251
Rotate the 'scope 90 degrees and you have a thermal detector which directly reads vertical velocity. *Presumably, if the system can be miniaturized to fit in a rifle scope and be powered by man-packable batteries, fitting it into a sailplane shouldn't be that difficult - costs aside.
The Israeli solution, iirc, uses speckle backscatter from the target,
not aerosol backscatter, so you'd have to have a buddy fly about half
a kilometer beside you and look for thermals in between.
Old October 24th 12, 08:57 AM posted to rec.aviation.soaring
Roel Baardman
My money would be on a Particle Image Velocimetry (PIV) based
solution.
Largely because this is technology which is extremely widely used
(every laser mouse does it in hardware).
I've heard about model airplanes using it to stabilize bank angle
(more speed = lower wing).
Roel
Old October 24th 12, 10:50 AM posted to rec.aviation.soaring
solution.
Optical mice use integrated circuits like the Agilent ADNS-2620:
http://www.datasheetcatalog.org/data...cyqglz0hcy.pdf
So, unless you can form a 2D image of the particles'
velocity and have the ic process that image, I don't
see how you would do it.
Quite possible. Many years ago I saw one of the
optical mice in the form or a ring on a finger.
With the appropriate focussing distance, the room
itself was used as a mouse pad.
Old October 24th 12, 11:35 AM posted to rec.aviation.soaring
waremark
solution.
http://www.datasheetcatalog.org/data...yqglz0hcy..pdf
Whatever the tech ultimately used to achieve this, what will it do to the sport? I know some people thought flight computers would ruin the sport, then GPS, then moving maps, but thus far it is still far from ruined. But visible thermals sounds like the biggest step yet towards reducing the challenge. What do others think?
Old October 24th 12, 12:50 PM posted to rec.aviation.soaring
Tony[_5_]
solution.
it will turn a flight that previously would've gone 300km into a 500km flight. would probably lead to a huge increase in the number of pilots flying cross country and in contests. records would start falling everywhere. i can't wait
Old October 24th 12, 01:58 PM posted to rec.aviation.soaring
Roel Baardman
biggest step yet
I think it actually doesn't matter what people think. Technology
will become available for the masses sooner or later, which will
challenge both pilots and contest organisers to think outside the
box.
Pilots will have to deal with more (sources of) information, and
will have to prioritize.
Contest organizers must find new ways to challenge pilots.
Besides this, the question is if remote detection will change the
field a lot. The same arguments hold for this as for the discussion
about powerFLARM I think.
Personally I am an aerobatic gliderpilot (and there's no tech for us
at all!), so this doesn't affect me directly. The only advantage is
that I can probably glide further when I decide to go cross-country
one day.
Old October 24th 12, 04:21 PM posted to rec.aviation.soaring
I wrote a short Soaring Magazine article a while ago, thinking about what thermal detectors might mean,
http://faculty.chicagobooth.edu/john..._detectors.mht
or link from
http://faculty.chicagobooth.edu/john...dex.htm#corner
Short version: Even a wingspan range would make a huge difference. Flying airplanes without engines will never be easy. Thermal detectors could dramatically improve the sporting experience, as they could mean the end of gaggling, leeching, team flying, etc. And think about how nice it would be at the end of the day to know for sure that there aren't any thermals left so you'd better stop trying and land.
John Cochrane
Possible remote thermal finder? bildan Soaring 12 January 23rd 11 05:35 PM
Thermal Forcasting -Thermal index gldrgidr Soaring 6 November 27th 10 10:26 PM
Idea for product - LMS method of traffic detection joe smith Products 0 March 6th 07 01:34 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
Air traffic detection question FISHnFLY Aviation Marketplace 19 April 2nd 04 01:08 PM
