PowerFLARM leeching comments
Old October 30th 12, 03:06 PM posted to rec.aviation.soaring
Default PowerFLARM leeching comments
Don,
I fully agree that maintaining a good lookout at all times
is a good basis for see-and-avoid.
However, we believe that even the best pilot may occasionally fail to detect traffic.
There are a number of human factors which affect perception
(distraction, selective attention, target merging into background, target not
moving wrt. background, etc).
We have a presentation where on one slide we listed the situations where FLARM
has potentially better and/or earlier chances to detect traffic than the human eye.
These situations a
- Head-on and converging course (both gliders in cruise), especially in the
presence of clouds, snow fields etc.
- One glider circling, another one approaching the same thermal.
- Two gliders circling in opposite directions (yes, we know this shouldn't happen...)
As you say, the fewer gliders in a thermal, the more helpful FLARM can be.
FLARM does help in wave, but the indicated relative bearing to the threat may be strongly biased by wind.
Needless to say, whenever a FLARM warning occurs, the pilot should immediately
try to make visual contact with the threat.
In the Classic FLARM manual, we write:
"Under no circumstances should a pilot or crewmember adopt different tactics or deviate from the normal principles of safe airmanship."
I think that summarizes it quite nicely.
Best
--Gerhard
Old October 30th 12, 03:42 PM posted to rec.aviation.soaring
Kimmo Hytoenen
Gerhard,
fully agree with you, but would like to add one situation where
FLARM is useful. When there is someone on your under or
above, in position where you cannot see the other plane, flying
into the same direction. Can be cloudstreet, competition or just
a friend of your's you fly with.
The LED based FLARM displays used in Europa can only show
one target. If there are several planes around you, this display
does not give you very good situation awareness. That caused
here a midair of two FLARM equipped gliders year ago.
The powerflarm has graphical display, that shows several
targets around you. It also has two receivers and antennas, so
the situation of the midair I mentioned should not occur again.
There was no FLARM warning - looks like the carbon fuselages
dampen the radio signal, and the gliders approached each
others from the dipole antenna's blind spots.
-kimmo
(English language summary on page VII)
http://www.turvallisuustutkinta.fi/Satellite?
blobtable=MungoBlobs&blobcol=urldata&SSURIapptype= BlobSer
ver&SSURIcontainer=Default&SSURIsession=false&blob key=id&
blobheadervalue1=inline;%20filename=Tutkintaselost us%20B1_
2011L.pdf&SSURIsscontext=Satellite%20Server&blobwh ere=134
2016078074&blobheadername1=Content-
Disposition&ssbinary=true&blobheader=application/pdf
At 15:06 30 October 2012, wrote:
Don,
fail to
detect traffic.
background, target
not
situations where
FLARM
than the
human eye.
These situations a
especially in the
thermal.
shouldn't
happen...)
FLARM can be.
the threat
should
immediately
different
airmanship."
Best
--Gerhard
Old October 30th 12, 03:58 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
Don,
detect traffic.
not
FLARM
human eye.
These situations a
shouldn't
happen...)
be.
immediately
Best
--Gerhard
Gerhard
I do not disagree with you, FLARM does help, with the emphasis on help, it
does not replace or indeed lessen the necessity for a good lookout. My
argument was contering the statement that, "The difference between midairs
and all other cause of accidents is that it is the only type which you can
do almost nothing to prevent it, except using flarm." which I think you
will agree is a load of total ********. FLARM can assit the aware pilot, it
is NOT the answer to preventing mid air collisions.
In Europe we do have, or some of us do, the LX8000 which does give the
radar display, however it takes time to see all the other gliders, time
which would be beter spent looking out.
Old October 30th 12, 05:13 PM posted to rec.aviation.soaring
folken
Statically it is. Midairs, once the number 1 accident cause, are now almost nonexistent in Switzerland, since the introduction of Flarm.
You can also assume that no pilot wants a midair collision and maintains good look out. But there are limitations to the human senses, as stated by Gerhard.
We have to stop threating the glider pilot as a luminous all seeing perfect elite being. (paron the pun.) We make mistakes. Hundreds each flight. In fact its a human quality to err.
Here is where technology helps. It maintains its constant SA and fills in our human attention gaps.
- Folken
Old October 30th 12, 08:12 PM posted to rec.aviation.soaring
Sean F (F2)
Bravo Falken. +1 again and again! I wish we had more folks like you over here. Bravo!
Old October 31st 12, 05:30 AM posted to rec.aviation.soaring
Ramy
I second that.
The problem with some folks is that they are clueless about the risks and as such are in a higher risk. They believe that the reason they did not have any midair yet is due to their good scanning technique, while in fact it is 99% luck due to the big sky theory.
For a good reading on the subject of see and avoid check
http://www.aviationweek.com/aw/gener...s/bca0107c.xml (this link is few years old and currently not working, hopefully temporary)
Also a list of youtube videos showing how much we can trust our eyes:
http://www.youtube.com/watch?v=vJG698U2Mvo
-note: let it buffer all the way first, without letting it run, then
watch it full screen and really count!
http://videogames.yahoo.com/events/b...ion-25/1416088
-blind spot, eek...
http://videogames.yahoo.com/events/b...sion-5/1400321
-relative shades
http://videogames.yahoo.com/events/b...ion-14/1408013
-implied green
http://videogames.yahoo.com/events/b...sion-3/1400187
-false center
http://videogames.yahoo.com/events/b...ion-15/1408125
-false spiral
http://videogames.yahoo.com/events/b...ion-22/1414565
-implied square
http://videogames.yahoo.com/events/b...ion-19/1412692
-parallel lines
http://videogames.yahoo.com/events/b...sion-6/1400351
-parallels
http://videogames.yahoo.com/events/b...ion-18/1412564
-wiggling ovals
Old October 30th 12, 09:25 PM posted to rec.aviation.soaring
Don Johnstone[_4_]
it
midairs
can
pilot,
it
almost
by
Gerhard.
perfect
Yes it helps, it does not provide the answer as the statement to which I
objected intimated it might. The only solution is better lookout and
bettter situational awareness however THAT can be achieved, not replacing
them with technology.
In answer to the assertion that mid-air collisions in Switzerland have been
eradicated, mid air collisions are very very rare and relying on statistics
with such a small sample is futile. As I recall the only mid air I can
recall in Switzerland over recent year was between two FLARM equipped
gliders, go figure.
- Folken
Old October 31st 12, 02:24 AM posted to rec.aviation.soaring
Sean F (F2)
OK. I will stop here and let the process go along. But I think competition concerns are GREATLY outweighed by SAFETY concerns.
Good luck with this. I dont have RADAR in my glider so its not really a concern.
Sean
Old October 31st 12, 03:19 AM posted to rec.aviation.soaring
Ramy
Apparently Don have not seen the many demonstrations and articles proving that see and avoid does not work (except in thermals when eye contact can be maintained to some extent).
Don, other then when thermaling and in the traffic pattern (which is only 20-30% of typical flight) you may as well fly blind folded and your chances for mid air will remain about the same. The problem is that many pilots believe that they can see and avoid since they always see traffic which is not on collision course without realizing that they can not see the one which will hit them. Also it will be interesting if we could put a camera in the cockpit of those claiming that they always scan to find out how much scanning they actually do during a 5 hours XC flight... Looking for lift under the clouds ahead is not considerd scanning!
Ramy
Old October 31st 12, 05:37 AM posted to rec.aviation.soaring
Ramy
it
midairs
can
pilot,
it
almost
by
Gerhard.
perfect
gliders, go figure.
- Folken
I hope no one takes Don comments seriously. It is evident he doesn't know what he is talking about with gems like: midairs are very very rare, see and avoid is the only solution to midairs, flarm was designed for wave etc. Please spare us.
Ramy
Ramy
Logger on PowerFlarm? LOV2AV8 Soaring 7 July 27th 12 03:18 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM Paul Remde Soaring 9 November 6th 10 04:30 AM
PowerFLARM Greg Arnold[_2_] Soaring 6 November 2nd 10 09:32 AM
PENTAGON CONSIDERING MILITARY BUILD UP AGAINST IRAN (Scroll down to comments section - see page 2 of the comments section as well): [email protected] Naval Aviation 0 December 19th 06 08:37 PM
