On Tuesday, October 30, 2012 5:00:04 PM UTC+1, Don Johnstone wrote:
I do not disagree with you, FLARM does help, with the emphasis on help, it does not replace or indeed lessen the necessity for a good lookout. My argument was contering the statement that, "The difference between midairs and all other cause of accidents is that it is the only type which you can do almost nothing to prevent it, except using flarm." which I think you will agree is a load of total ********. FLARM can assit the aware pilot, it is NOT the answer to preventing mid air collisions. Statically it is. Midairs, once the number 1 accident cause, are now almost nonexistent in Switzerland, since the introduction of Flarm. You can also assume that no pilot wants a midair collision and maintains good look out. But there are limitations to the human senses, as stated by Gerhard. We have to stop threating the glider pilot as a luminous all seeing perfect elite being. (paron the pun.) We make mistakes. Hundreds each flight. In fact its a human quality to err. Here is where technology helps. It maintains its constant SA and fills in our human attention gaps. - Folken |
Bravo Falken. +1 again and again! I wish we had more folks like you over here. Bravo!
On Tuesday, October 30, 2012 1:12:54 PM UTC-7, Sean F (F2) wrote:
Bravo Falken. +1 again and again! I wish we had more folks like you over here. Bravo! I second that. The problem with some folks is that they are clueless about the risks and as such are in a higher risk. They believe that the reason they did not have any midair yet is due to their good scanning technique, while in fact it is 99% luck due to the big sky theory. For a good reading on the subject of see and avoid check http://www.aviationweek.com/aw/gener...s/bca0107c.xml (this link is few years old and currently not working, hopefully temporary) Also a list of youtube videos showing how much we can trust our eyes: http://www.youtube.com/watch?v=vJG698U2Mvo -note: let it buffer all the way first, without letting it run, then watch it full screen and really count! http://videogames.yahoo.com/events/b...ion-25/1416088 -blind spot, eek... http://videogames.yahoo.com/events/b...sion-5/1400321 -relative shades http://videogames.yahoo.com/events/b...ion-14/1408013 -implied green http://videogames.yahoo.com/events/b...sion-3/1400187 -false center http://videogames.yahoo.com/events/b...ion-15/1408125 -false spiral http://videogames.yahoo.com/events/b...ion-22/1414565 -implied square http://videogames.yahoo.com/events/b...ion-19/1412692 -parallel lines http://videogames.yahoo.com/events/b...sion-6/1400351 -parallels http://videogames.yahoo.com/events/b...ion-18/1412564 -wiggling ovals |
At 17:13 30 October 2012, folken wrote:
On Tuesday, October 30, 2012 5:00:04 PM UTC+1, Don Johnstone wrote: I do not disagree with you, FLARM does help, with the emphasis on help, it does not replace or indeed lessen the necessity for a good lookout. My argument was contering the statement that, "The difference between midairs and all other cause of accidents is that it is the only type which you can do almost nothing to prevent it, except using flarm." which I think you will agree is a load of total ********. FLARM can assit the aware pilot, it is NOT the answer to preventing mid air collisions. Statically it is. Midairs, once the number 1 accident cause, are now almost nonexistent in Switzerland, since the introduction of Flarm. You can also assume that no pilot wants a midair collision and maintains good look out. But there are limitations to the human senses, as stated by Gerhard. We have to stop threating the glider pilot as a luminous all seeing perfect elite being. (paron the pun.) We make mistakes. Hundreds each flight. In fact its a human quality to err. Yes it helps, it does not provide the answer as the statement to which I objected intimated it might. The only solution is better lookout and bettter situational awareness however THAT can be achieved, not replacing them with technology. In answer to the assertion that mid-air collisions in Switzerland have been eradicated, mid air collisions are very very rare and relying on statistics with such a small sample is futile. As I recall the only mid air I can recall in Switzerland over recent year was between two FLARM equipped gliders, go figure. Here is where technology helps. It maintains its constant SA and fills in our human attention gaps. - Folken |
OK. I will stop here and let the process go along. But I think competition concerns are GREATLY outweighed by SAFETY concerns.
Good luck with this. I dont have RADAR in my glider so its not really a concern. Sean |
Apparently Don have not seen the many demonstrations and articles proving that see and avoid does not work (except in thermals when eye contact can be maintained to some extent).
Don, other then when thermaling and in the traffic pattern (which is only 20-30% of typical flight) you may as well fly blind folded and your chances for mid air will remain about the same. The problem is that many pilots believe that they can see and avoid since they always see traffic which is not on collision course without realizing that they can not see the one which will hit them. Also it will be interesting if we could put a camera in the cockpit of those claiming that they always scan to find out how much scanning they actually do during a 5 hours XC flight... Looking for lift under the clouds ahead is not considerd scanning! Ramy |
On Tuesday, October 30, 2012 2:25:20 PM UTC-7, Don Johnstone wrote:
At 17:13 30 October 2012, folken wrote: On Tuesday, October 30, 2012 5:00:04 PM UTC+1, Don Johnstone wrote: I do not disagree with you, FLARM does help, with the emphasis on help, it does not replace or indeed lessen the necessity for a good lookout. My argument was contering the statement that, "The difference between midairs and all other cause of accidents is that it is the only type which you can do almost nothing to prevent it, except using flarm." which I think you will agree is a load of total ********. FLARM can assit the aware pilot, it is NOT the answer to preventing mid air collisions. Statically it is. Midairs, once the number 1 accident cause, are now almost nonexistent in Switzerland, since the introduction of Flarm. You can also assume that no pilot wants a midair collision and maintains good look out. But there are limitations to the human senses, as stated by Gerhard. We have to stop threating the glider pilot as a luminous all seeing perfect elite being. (paron the pun.) We make mistakes. Hundreds each flight. In fact its a human quality to err. Yes it helps, it does not provide the answer as the statement to which I objected intimated it might. The only solution is better lookout and bettter situational awareness however THAT can be achieved, not replacing them with technology. In answer to the assertion that mid-air collisions in Switzerland have been eradicated, mid air collisions are very very rare and relying on statistics with such a small sample is futile. As I recall the only mid air I can recall in Switzerland over recent year was between two FLARM equipped gliders, go figure. Here is where technology helps. It maintains its constant SA and fills in our human attention gaps. - Folken I hope no one takes Don comments seriously. It is evident he doesn't know what he is talking about with gems like: midairs are very very rare, see and avoid is the only solution to midairs, flarm was designed for wave etc. Please spare us. Ramy Ramy |
Don,
In answer to the assertion that mid-air collisions in Switzerland have been eradicated, mid air collisions are very very rare and relying on statistics Switzerland is a small country. I have an incomplete list here with midairs between 2006 and 2007 in Central Europe. The list implies a lower bound of: 14 mid-airs 24 fatalities. I'm not aware of a centralised European accident database, so statistics is a bit tricky indeed, but it can theoretically be done by wading through a few 1000s of reports from various national authorities. recall in Switzerland over recent year was between two FLARM equipped gliders, go figure. http://www.bfu.admin.ch/common/pdf/2012.pdf Mid-air between an ASH 25 and a Stemme near Samedan, April 2007: 1.3 Information concerning the aircraft Motorglider HB-2XXX was fitted with a traffic and collision warning system FLARM F4 which was not operational because its UHF antenna was not mounted. [ the ASH had an operational FLARM ]. The only mid-air events I'm personally aware of where both involved aircraft had an operational FLARM on board was Finland 2011 and Uvalde 2012. FLARM helps, but it doesn't provide 100% protection. Best --Gerhard |
Logger on PowerFlarm? | LOV2AV8 | Soaring | 7 | July 27th 12 03:18 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
PowerFLARM | Paul Remde | Soaring | 9 | November 6th 10 04:30 AM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
PENTAGON CONSIDERING MILITARY BUILD UP AGAINST IRAN (Scroll down to comments section - see page 2 of the comments section as well): | [email protected] | Naval Aviation | 0 | December 19th 06 08:37 PM |
