At 15:23 01 November 2012, Mike the Strike wrote:
I have had most conflicts when flying under cloud streets, including one in= cident a couple of years ago where I nearly collided head- on with a colleag= ue at very high closing speeds. My concern with PowerFlarm and its cheesy = antennas is that the range may not be sufficient to adequately warn me in = this scenario. The more information the unit can provide the better - that= is why I oppose use of the"stealth" mode. Mike Mike, This link to an illustration of glider sizes versus time to impact and speeds might offer reassurance about sufficiency of warning in the head on case - assuming that the PF range collision alert range is at least as good as the less powerful Swiss Flarm version. For example, with both gliders doing 108 knots towards each other on a collision course, the first PF alert would be at around 2km separation and at that distance a 15m wingspan will subtend an angle smaller than a screw head on the instrument panel. http://www.flarm.com/files/glider_shapes_en.pdf John Galloway |
Logger on PowerFlarm? | LOV2AV8 | Soaring | 7 | July 27th 12 03:18 AM |
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available | Paul Remde | Soaring | 30 | May 25th 12 11:58 PM |
PowerFLARM | Paul Remde | Soaring | 9 | November 6th 10 04:30 AM |
PowerFLARM | Greg Arnold[_2_] | Soaring | 6 | November 2nd 10 09:32 AM |
PENTAGON CONSIDERING MILITARY BUILD UP AGAINST IRAN (Scroll down to comments section - see page 2 of the comments section as well): | [email protected] | Naval Aviation | 0 | December 19th 06 08:37 PM |
